Audi MMI3G High (HNav) MMI 3GP (HN+) 6.33.1 + Activator Europe 2021-2022
Audi MMI3G High (HNav) MMI 3GP (HN+) 6.36.0 8R0051884KL - 2023 Europe + Activator
Car list:
For those with a BOSE system
You cannot update the BOSE amplifier. By updating BOSE - you can get a lot of problems with subsequent settings and parameterization of BOSE. What should be done?
- Next, insert your media (CD or SD) into the head of the MMI. Everything is ready for updating.
Important! The update takes about 40 minutes, so it’s recommended to either start the car or connect an additional charger to the battery during the update.
Here is the same as with the update. Copy the cards to the root of the memory card. Insert the card into MMI. Press SETUP + RETURN and perform the same actions as during the update. Cards will be loaded for several hours, so be patient. After the cards are loaded, they will work for 5 minutes and will be blocked. Then you need to activate. Unzip the previously downloaded archive with the card activator and put it in the root of the memory card. Next is the usual update procedure. Press SETUP + RETURN, etc.
If you have problems installing the cards, you can first remove the old cards from the MMI hard drive, and then install new ones. How to do this, read on.
The "hidden" menu is activated, go to it by pressing and holding the SETUP + CAR buttons.
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
Car list:
- A1
- A4 S4 B8 2008 -
- A4 ALLROAD 2010 -
- A5 S5 CAB 2010 -
- A5 S5 COUPE/SPORTBACK 2008 -
- A6 S6 2009 -
- A6 ALLROAD 2007 -
- A7
- A8 S8 2008 -
- Q3
- Q5 2009 -
- Q7 2010 -
- RS5 2010 -
- RS6 2008, 2011
- For HN+ SYSTEMS and to be able to copy the maps on SDHC 32GB CARD the following FOLDER has to be DELETED under folder \pkgdb\ DELETE LIT1-3.
- For HNav SYSTEMS and to be able to copy the maps on SDHC 32GB CARD the following FOLDER has to be DELETED under folder \pkgdb\ DELETE LIT3GP1-4.
- Use WinRAR 5.8 or newer.
- Remove all connectors and wires from the BOSE amplifier.
- Pull out the optics connector.
- Loop the pulled out optical connector with a plug with an optical ring for the MOST optical bus (part No. 4E0973802).
- Hold SETUP + RETURN until the version of your firmware appears.
- We select a source from which we will be updated.
- We see the firmware version to which we will update click on it.
- Choose a standard.
- We see a list of what we will have and what will not be updated. We go down and click Start download.
- Here we are told that the process should not be interrupted. Therefore, it is advisable to either start the car or connect to additional power, in order to be sure that the battery does not sit down during the firmware. If ready - then click Start.
- The update process has begun. During the upgrade, MMI will reboot.
- And so the update has completed and we see the list. Opposite each block should be either OK or -. Scroll down and click Continue.
- Check the firmware version and see that the version has been successfully updated!
- Activate the "user mode"
- Delete old cards.
- Delete the section with navigation data.
- As a result, go to "SETUP" -> "Settings" -> "Software version" and see in the line "version of the navigation database" empty. We have successfully deleted the old cards and can again try to fill in the new ones.
- Audi Map HNav 6.33.1 8R0051884JD - 2021/2022
- Audi Map HN+ 6.33.1 8R0051884JD - 2021/2022
- Activator 3GP 6.24.2
- Torrent Magnet Link
- Audi Firmware archive
- Delphi/AuTocom 2013.2 with update 1 [Activation, CDP, CDP+,ADP186,SDP]
- Mitchell OnDemand 2015 + Mitchell Manager Torrent
- Autocom/delphi 2013.1 Full
- AutoCom/Delphi 2013.3 Activator!!!! Also Including My Delphi 2013.3 Super Easy Installer by SuperS
- Delphi/Autocom 2013.R3 How to install
- Autocom & Delphi 2013 R1 Activator patch Works Fine
- Autocom 2013 R2 Full
- TachoSoft Mileag Calculator 25.9 - 2016 full
- Autocom CDP 2013.R1 FULL
- KG Vivid Workshop DATA ATI v.10.2 + Instruction
- Autocom CDP+ Delphi 2014.Release 1 Update Full
- DELPHI DIAMAND [02.2016]
- Delphi><Autocom Keygen 2013.3 Xml file activator
- Autocom - Delphi 2012.3 Full
- NYO4 calculator Torrent
