Support
Cleaner
196
95,228,782
#21
@Dear mod,
I was opening the files, which I mostly concerned 1404KZW, but I couldn't open it though I've already tried some PCs,
btw, the graphics can not use on all catalogues, can't see any drawing ?
Hope you could help,
Picture attached
Thanks so much
Dear friend, please try to install on Window 7 Ultimate, I've checked, it works fine, check photo below:
Caubectt93
50
#22
Dear Mod,
Thank for your support,
But I haven't still opened 1404KZW, previous error occured.
Please check properly 1404KZW catalogue.
Thank you in advance
Caubectt93
50
#24
Okay. I'll try once again, thanks so much mod.
by the way, I have now a problem with 1404KZW, brief description as follow:
Hi-rail part, thanks to this part, the vehicle is able to run on the railway.
but now, it's faulty, normally cylinder of Hi-rail push to lift machine in order to run on the railway and cylinder retracts to travel by tire wheel.
Retracting is working well all the time
but Pushing is working intermittently, sometimes okay but sometimes not pushing.
The electrical system is fine because when I press the button, afterward hearing the noise from the pump and relay sounds "tick".
I supposed that the valve control cylinder directly has failures.
Could you kindly give me some advices and go further we can add Whatsapp to fix this error. I'll pay you as you request.
Thank you and looking forward to hearing from you.
Support
Cleaner
196
95,228,782
#25
Check your conversation my friend!
Caubectt93
50
#26
Dear Ad,
Thanks for your enthusiastic support,
The problem here's we have to click the link in ATLAST-TEREX CD spare part catalogue, then download.
Then get two files fomatted zar, we select two files and extract simultaneously. (don't forget passwords also in that file).
Use Poweriso (if you don't have CD drive), to extract *.mdf
I still use it on Win 10 64bit environment. works well. good luck.
Thanks a lot
Support
Cleaner
196
95,228,782
#27
Dear Ad,
Thanks a lot
Thank you so much for your feedback, we hope it's useful for your work, regards!
Caubectt93
50
#28
Dear all,
I am reparing Atlas excavator model: KZW1404;
Has Anyone here electrical drawing, hydraulic drawing for workshop manual services ?
