Atlas Copco Power ROC D55 System Description
- Download this document, you need 200 Gallons
Type: pdf
Pages: 42
General – PowerROC D55 ......................................................................................................................... 3
Hydraulic pumps......................................................................................................................................... 4
Pilot pressure .............................................................................................................................................. 4
Return oil and oil cooler ............................................................................................................................. 5
Electrical system general ..............................................................................................................................6
General........................................................................................................................................................ 6
Battery charging ......................................................................................................................................... 6
Main fuse .................................................................................................................................................... 6
Seat switch.................................................................................................................................................. 6
PCB(Print circuit board)........................................................................................................................ 6
Electrical supply ......................................................................................................................................... 7
ECM (Caterpillar)....................................................................................................................................... 8
Control panel .............................................................................................................................................. 8
Diesel engine ..................................................................................................................................................9
Battery switch, ON ..................................................................................................................................... 9
Ignition position.......................................................................................................................................... 9
Start position............................................................................................................................................... 9
ECM overview.......................................................................................................................................... 10
Engine speed............................................................................................................................................. 10
Control instrumentation ............................................................................................................................ 11
Switches and sensors that automatically and manually stop the diesel engine......................................... 11
Switches and sensors that only indicate a fault......................................................................................... 11
Pumps & Pilot Pressure..............................................................................................................................13
Pump 1 and Pump 2 pressure settings ...................................................................................................... 13
Pumps 3 .................................................................................................................................................... 14
Pumps 4 and 5........................................................................................................................................... 16
Pilot pressure ............................................................................................................................................ 16
Cooling fans .................................................................................................................................................18
Tramming ....................................................................................................................................................20
Reverse warning ....................................................................................................................................... 20
Tramming high/low speed ........................................................................................................................ 20
Positioning....................................................................................................................................................21
Positioning ................................................................................................................................................ 21
Positioning during tramming and drilling................................................................................................. 21
Track oscillation ....................................................................................................................................... 22
Air System & Compressor..........................................................................................................................23
Air System................................................................................................................................................ 23
Compressor............................................................................................................................................... 24
Instrumentation & fault indication............................................................................................................ 25
Oil pre-heating.............................................................................................................................................26
Drilling functions.........................................................................................................................................27
Activation of drilling functions................................................................................................................. 27
Drill rotation ............................................................................................................................................. 27
Drill feed................................................................................................................................................... 28
Rapid feed................................................................................................................................................. 29
Threading and un-threading...................................................................................................................... 30
Impact ....................................................................................................................................................... 30
HECL, DTH hammer lubrication system.................................................................................................31
Dust collector, DCT.....................................................................................................................................32
DCT hydraulic system.............................................................................................................................. 32
DCT filter cleaning................................................................................................................................... 33
DCT air system......................................................................................................................................... 33
Table of contents
2
DCT adjustable parameters....................................................................................................................... 33
Rod Handling System, RHS 102 ................................................................................................................34
Rod transfer .............................................................................................................................................. 35
Carousel rotation....................................................................................................................................... 37
Rod grippers ............................................................................................................................................. 38
Drill steel supports & suction hood .......................................................................................................... 39
Breakout table........................................................................................................................................... 39
Water mist system (Option) .......................................................................................................................40
Water-mist system 400 Litres................................................................................................................... 40
Spray greasing system.................................................................................................................................41
Function.................................................................................................................................................... 41
Type: pdf
Pages: 42
Table of contents
2
- Atlas Copco Workshop Manuals Pack
- Atlas Copco ROC L6(25) / L6(30) / L8(25) / L8(30) operation manual
- Atlas Copco XA 60, 80, 120, 160 DD y XAS
- Atlas Copco Instruction Manual for Portable Compressors XRHS 486 Md XRHS 396 Md XRVS 466 Md XRV
- Atlas Excavator 1304 Hydraulic and Wiring Diagram
- Atlas Copco Instruction book for compressors GA11 - GA15 - GA18 - GA22
- Atlas Copco Instruction Manual and Parts List for Portable Compressors XRVS455 Md
- Atlat Copco XAHS 146 Dd - XATS 156 Dd - XA(S) 186 Dd - XAVS 166 Dd - XAHS 186 Dd Operation Manual
- Atlas Copco DM45 Parts Catalog
- Atlas Copco ROC D7-11 Technical Training Circuit Diagram Parts Manual
- Atlas Copco Stationary Air Compressors ZR, ZT 55 Parts Manual
- Atlas Copco Scooptram ST1030 Diagrams & Drawings
- Atlas Copco ROCKET BOOMER S1D Spare Parts Catalogue
- Atlas Copco Instruction Manual XAMS 407 CD XAMS 850 CD7; XATS 377 Cd
- Atlas Copco Scooptram ST1030 Service manual
