Atlas Copco MineTruck MT2010 Service Guide 9852178701a EN
Brand: Atlas Copco
Type of Manual: Service Guide
Model: Atlas Copco MT2010 Truck
Part Number: 9852178701a
Publication Date: 2006
Number of Pages: 212 Pages
Chapter 1: Introduction To The Mt2010
Vehicle Description
Hazard Protection
Vehicle Graphics
Service Guide Safety Alerts
Time Saver Messages
Chapter 2: Safety Awareness
Protect Yourself And Your Coworkers
Primary Safety Procedures
Park In Relaxed-Mode
Master Switch
Articulation Safety Lock
Dump Box Safety Support
Relieving Hydraulic Pressure
Relaxed-Mode Procedures
General Safety Procedures
A Well-Maintained Vehicle Is A Safer Vehicle
Personal Protection
Hydraulic Fluid
Vehicle Guards
Tools And Receptacles
Dump Box Caution
Parking The Mine Truck
Burn, Fire, And Explosion Prevention
Electrical Hazards
Coolant Hazards
Flammable Liquids & Debris
Ether Starting Fluid
Vehicle Labeling
Cabin Rops And Fops
Seat Belts
Tyre And Wheel Safety
Tyre Inflation Cage
Wheel Assembly
Lifting The Vehicle With A Floor Jack
Front Axle Jack Points
Rear Axle Jack Points
Lifting The Vehicle With A Crane
Side View Of Lift Points
Transporting The Mine Truck
Chapter 3: Preventive Maintenance
Service Management
Rugged Usage Requirements
High Torque Settings Require Specialty Tools
Independent Oil Analysis
Hourmeter Display
Record Keeping
Management Of Driver Inspection & Reporting
Shift Inspection Checklist
Atlas Copco Service Kits
Shift Report
Check Before Starting Engine
Comments
Check After Starting Engine
Comments
Maintenance Intervals
As Required
Every Day At Each Shift
Daily Lube Items
Every 125 Hours Of Operation
Every 500 Hours Of Operation
Every 250 Hours Of Operation
Every 2,000 Hours Of Operation
Every 5,000 Hours Of Operation
Every 1,000 Hours Of Operation
Engine Air Filter Restriction Indicator
Engine Air Filters
Hydraulic Tank
Service Procedures By Interval
As Required Service
Radiators & Coolers
Fuel Cooler
Engine Radiator & Front Grille Coolers
Structural Integrity
Circuit Breakers And Fuses
Daily/Shift Requirements
Fire Extinguisher
Daily Lube Points
Auto Lube And Remote Lube
Fluid Leaks
Fuel Level
Fuel/Water Separator
Engine Oil
Engine Coolant
Air Filter Evacuator Valve
Transmission Oil
Cold Oil Check
After Start-Up Check
Hot Oil Check
Hydraulic Oil Reservoir
Tyres
Air Intake Primary Filter Element
Air Intake And Exhaust
Primary (Outer) Filter
Precleaner
Differential And Planetaries
Planetary
Driveline Slip-Joints
Hydraulic Hoses
Fire Suppression System
Batteries
Hydraulic Tank Breather & Filter
Steering And Dump Cylinders
Autolube System (Optional)
Lube System Connectors
Engine Oil And Filters
Changing The Engine Oil
Engine Oil Drain
Engine Oil Filters
Fuel Filters
Engine Coolant
Transmission/Engine Stall Speeds
Fuel Hoses And Tubing
Engine Fan Assembly
Radiators & Coolers
Front Coolers
Fuel Cooler
Transmission Oil Filters
Transmission Oil Cooler
Oil Testing
Differentials
Planetaries
Drivelines
Driveline Universal-Joint
Dump Cylinders
Mine Truck Frame
Dump Box
Dump And Steering Cycle Times
Specified Steering Times
Specified Dumping Cycle Times
Articulation Joints
Engine Mounts
Radiators
Transmission Oil
Exhaust System
Exhaust Purifier
Exhaust Heat Shielding
Differential & Planetaries
Planetary
Hydraulic Tank
Inspection Cover
Hydraulic Oil Tank Breather
System Pressures
V-Belts
Sahr Brakes
Air Intake And Exhaust Systems
Engine Cooling System
Engine And Transmission Mounts
Fuel Lines
Coolant Hoses
Intake Hoses
Hydraulic Hoses
Oil Coolers
Chapter 4: Power Unit
Engine Support Systems
Fuel System
Fuel System Components
Fuel System Operation
Fuel/Water Separator And Filter
Fuel Pump
Lubrication System
Oil Pump
Oil Filters
Engine Oil Dipstick & Fill Tube
Engine Oil Pressure Gauge
Electronic Unit Injectors (Eui) And Engine
Control Module (Ecm)
Cooling System Function
Coolant Recommendations
Corrosion Inhibitor For Engine Cooling
Air Intake System
Purpose Of The Air Intake System
Air Cleaner
Air Intake System Removal
Reinstalling The Intake Tubes
Engine Air Filters
Exhaust System
Exhaust Silencers & Purifiers
Turbocharger
Removal And Replacement Of Major Components
Vehicle Preparation
Exhaust System
Removal Of The Exhaust System
Replacement Of Exhaust System
Turbocharger
Radiator Cooling Package
Removing The Cooling Package
Cooling Package Reinstallation
Tube And Shell Cooler Removal
Tube And Shell Cooler Replacement
Fuel System
Removing Fuel Filter
Replacing Fuel Filter
Removing Fuel Valves And Lines
Reinstalling Fuel Valves And Lines
Engine Package
Engine Removal Steps
Engine Replacement
Chapter 5: Power Train
Power Train Components
Shift Selector
Torque Converter
Lock-Up Clutch
Drivelines
Universal Joint Bearings
Driveshaft Support Bearings
Primary Reduction
Secondary Reduction
Wheels And Tires
Road Maintenance
Tyre Inspection & Maintenance
Wheel Inspection & Maintenance
Recommended Tyre Pressures
Over-Inflation Results In
Under-Inflation Results In
Static Loaded Radius
Tyre Size Example:
Driving Practices
Drivers Can Reduce Tyre Costs By
Mounting And Storage
Component Removal And Replacement
Vehicle Preparation
Transmission Removal
Transmission Installation
Drivelines
Phasing The Driveline
Installing The Driveshaft
Yokes And Bearing Mounts
Installing Driveline Guards
Driveline Removal & Installation
Removal:
Installation:
Axle Removal Preparation Steps
Front Axle Removal
Front Axle Replacement
Rear Axle Removal
Rear Axle Replacement
Sahr Brakes
Disassembly
Cleaning And Inspection
Housing, Covers, Etc
Piston And Housing Seals
Assembly Of The Sahr Brakes
Tyre Removal & Replacement
Changing Tires
Demounting And Mounting
Demounting
Inspection
Mounting And Inflating
Wheel Nut Torque
Operating Precautions
Recapping
Chapter 6: Main Frame
Introduction
Power Frame
Hood Removal
Hood Replacement
Load Frame
Dump Box
Lifting Eyes
Installing Lifting Eyes
Dump Box Removal
Dump Box Replacement
The Load & Power Frame Connection
Separation
Reconnection
Articulation Pins
Pin Removal
Pin Installation
Stops
Steering Stops
Dump Box Guides
Front Axle Oscillating Stops
Chapter 7: Hydraulic Systems
Introduction
Hydraulic System Components
Cylinders
Dump Cylinders
Steering Cylinders
Accumulators
Accumulator Pre-Charge
Hydraulic Pumps
Hydraulic Gear Pumps
Hydraulic Valves
Charge Valve
Brake Solenoid Valve
Dump Control Valve
Main Relief Function
Load Check Valve Function
Steering Control Valve
Steering Main Control Valve
Steering Pilot Control Valve
Priority Valve
Adjust The Priority Valve As Follows:
Hoses And Tubing
Hydraulic Tank
Hydraulic Tank Suction Filter
Hydraulic Filtration
Off-Line Hydraulic Filters
Brakes
Hydraulic System Operation
Dump System
Box Up
Box Float
Box Power Down
Over-Pressure Protection
Park Brake System
Charging Mode
Non-Charging Mode
Brakes Released
Brakes Applied
Service Brake Operation
Park Brake Operation
Hydraulic Maintenance
Servicing After Overhaul
Oil Level In Reservoir
Importance Of Cleanliness
Hydraulic Oil Changes
Oil Storage And Handling
Prevention Of Foaming
Hydraulic Oil Change After Failure
Hydraulic Tank Inspection
Repair
Suction Filter
Changing The Filter Element
Servicing Filters And Strainers
Establishing A Schedule
Brake Pedal Adjustment
Adjustment Of Pedal Deadband
Cylinder Inspection
Adjusting Cylinder Packing
Hydraulic Component Removal And Replacement
105
Pump Priming
Priming The Steering/Dump Pump
Priming The Brake Pump
Bleeding The Brakes
Valve Relief Settings
Adjusting The Pressure
Dump Cylinders
Dump Cylinder Removal
Dump Box Cylinder Installation
Steering Cylinders
Steering Cylinder Installation
Accumulators
Brake Accumulator
Brake Accumulator Removal
Transmission Accumulator Removal
Accumulator Replacement
Hydraulic Pumps
Pump Removal
Pump Installation
Valves
Valve Removal
Valve Replacement
Charge Valve Cartridge Removal/Service
Hydraulic Manifolds
Manifold Replacement
Hoses And Tubing
Assembling Fittings To Hoses
System Pressure
Accumulator Cycling
Dump Box Performance
Steering Control
Brake System Pressure Settings
Chapter 8: Electrical Systems
Circuit Schematics
Electrical Ladder Diagram
Electrical Wiring Diagram
Electrical System Components
Wiring Harness
Master Switch (Battery Isolation)
Component Box
Circuit Breakers
Battery
Starter
Cabin Controls
Vehicle Driving Lights
Horn
Vehicle Computerized Control Units
Programmable Logic Controller
Engine Control Module
System Sensors
Turbo Boost Sensor
Fuel Pressure Sensor
Oil Pressure Sensor
Coolant Pressure Sensor
Crankcase Pressure Sensor
Coolant Temperature Sensor
Fuel Temperature Sensor
Air Temperature Sensor
Oil Temperature Sensor
Coolant Level Sensor
Throttle Position Sensor
Diagnostic Interfaces
Diagnostic Data Reader
Check Engine And Stop Engine Lights
Communication Links
Data Collection Unit
Gauges
The Mini-Message Center
Mini-Message Center Codes
General Maintenance Information
Arc Welding
Computerized Diagnostic Systems
Plc Codes
Batteries
Installation
Periodic Service
Cable Terminals And Hold Downs
Battery Fluid
Tropical Climates
Factors Affecting Battery Life
Detecting Potential Failures
Visual Inspection
Hourmeter Reading
Testing
Cell Charge Test: Hydrometer
Cell Charge Test: Capacity Tester
Cell Charge Test: Booster Cables
Storage Of Lead Acid Batteries
Alternators
Slip Rings
Transducers
Engine Sensors
Starter
Batteries
Battery Removal
Battery Replacement
Alternator Removal
Alternator Replacement
Chapter 9: Controls & Indicators
Introduction
Diagnostic Coupler
Hand Controls
Steering Control
Dump Control
Park Brake Switch
Sahr Brake Override System
Brake Release
Dual-Purpose Hand Pump
Component Box
Foot Controls
Sahr Brake Pedal
Throttle Control
Driver’s Seat Controls
Armrest Controls
Backrest Control
Seat Height Adjustment
Front / Rear Seat Adjustment Control
Operator Weight Control
Chapter 10: Optional Systems
Emergency Use
In The Event Of Fire
Fire Suppression Components
Actuator
Cartridge Receiver
Dry Chemical Tank
Nozzles
Portable Fire Extinguisher
General Maintenance
Monthly
Semi-Annual
Chapter 11: Troubleshooting Strategies
Symptoms And Solutions
Engine Symptoms
Drivelines
Wheels And Tyres
Articulation
Sahr Brakes
Park Brake
Chapter 12: Vehicle Specifications
Performance Related Data
Vehicle Weight Range
Operating Times
Steering And Oscillation
Speed (Loaded)
Hydraulic Pressure
Brake Pressure
Tyres
Capacities
Converter
Hydraulic Tank
Fluids And Lubrication
Diesel Fuel Quality And Selection
Fuel Oil Selection Chart
General Fuel Classification
Engine Coolant Specifications
Lubricating Oil Specifications
Grease
Ambient Temperature Charts
Acw Hydraulic Fluid
Torque Specifications
Use The Correct Tool For The Job
Torque Values By Component
Alternator To Engine
Articulation Pins
Driveline U-Joints
Engine Mounts
Engine Radiator
Hydraulic Filter
Sahr Brakes
Transmission Mounts
Torque Values By Bolt Size & Thread
Scope
Definitions
High Strength
Tolerances
Unified Coarse Thread
Unified Fine Thread
Unified Fine Thread
Metric Coarse Thread
Torque Values For Electrical Connectors
Terminal Block Wire Connections
Deutsch Connectors With Bulk Head Nut
Binding Screws & Slotted Screws
Iso Switch Nut
Connectors With Hexagonal Socket Screws
Harting Connectors With Screw Terminals
Brand: Atlas Copco
Vehicle Description
Hazard Protection
Vehicle Graphics
Time Saver Messages
Master Switch
Personal Protection
Hydraulic Fluid
Vehicle Guards
Dump Box Caution
Electrical Hazards
Coolant Hazards
Vehicle Labeling
Cabin Rops And Fops
Seat Belts
Tyre Inflation Cage
Wheel Assembly
Service Management
Hourmeter Display
Record Keeping
Shift Report
Comments
Comments
As Required
Daily Lube Items
Engine Air Filters
Hydraulic Tank
As Required Service
Radiators & Coolers
Fuel Cooler
Fire Extinguisher
Daily Lube Points
Fluid Leaks
Fuel Level
Engine Oil
Engine Coolant
Transmission Oil
Cold Oil Check
Hot Oil Check
Tyres
Precleaner
Planetary
Hydraulic Hoses
Batteries
Engine Oil Drain
Engine Oil Filters
Fuel Filters
Engine Coolant
Engine Fan Assembly
Radiators & Coolers
Front Coolers
Fuel Cooler
Oil Testing
Differentials
Planetaries
Drivelines
Dump Cylinders
Mine Truck Frame
Dump Box
Articulation Joints
Engine Mounts
Radiators
Transmission Oil
Exhaust System
Exhaust Purifier
Planetary
Hydraulic Tank
Inspection Cover
System Pressures
V-Belts
Sahr Brakes
Fuel Lines
Coolant Hoses
Intake Hoses
Hydraulic Hoses
Oil Coolers
Fuel System
Fuel Pump
Lubrication System
Oil Pump
Oil Filters
Air Intake System
Air Cleaner
Engine Air Filters
Exhaust System
Turbocharger
Vehicle Preparation
Exhaust System
Turbocharger
Fuel System
Engine Package
Engine Replacement
Shift Selector
Torque Converter
Lock-Up Clutch
Drivelines
Primary Reduction
Secondary Reduction
Wheels And Tires
Road Maintenance
Tyre Size Example:
Driving Practices
Vehicle Preparation
Drivelines
Removal:
Installation:
Front Axle Removal
Rear Axle Removal
Sahr Brakes
Disassembly
Changing Tires
Demounting
Inspection
Wheel Nut Torque
Recapping
Introduction
Power Frame
Hood Removal
Hood Replacement
Load Frame
Dump Box
Lifting Eyes
Dump Box Removal
Separation
Reconnection
Articulation Pins
Pin Removal
Pin Installation
Stops
Steering Stops
Dump Box Guides
Introduction
Cylinders
Dump Cylinders
Steering Cylinders
Accumulators
Hydraulic Pumps
Hydraulic Valves
Charge Valve
Dump Control Valve
Priority Valve
Hoses And Tubing
Hydraulic Tank
Brakes
Dump System
Box Up
Box Float
Box Power Down
Park Brake System
Charging Mode
Non-Charging Mode
Brakes Released
Brakes Applied
Repair
Suction Filter
Cylinder Inspection
105
Pump Priming
Bleeding The Brakes
Dump Cylinders
Steering Cylinders
Accumulators
Brake Accumulator
Hydraulic Pumps
Pump Removal
Pump Installation
Valves
Valve Removal
Valve Replacement
Hydraulic Manifolds
Hoses And Tubing
System Pressure
Accumulator Cycling
Steering Control
Circuit Schematics
Wiring Harness
Component Box
Circuit Breakers
Battery
Starter
Cabin Controls
Horn
System Sensors
Turbo Boost Sensor
Oil Pressure Sensor
Communication Links
Gauges
Arc Welding
Plc Codes
Batteries
Installation
Periodic Service
Battery Fluid
Tropical Climates
Visual Inspection
Hourmeter Reading
Testing
Alternators
Slip Rings
Transducers
Engine Sensors
Starter
Batteries
Battery Removal
Battery Replacement
Alternator Removal
Introduction
Diagnostic Coupler
Hand Controls
Steering Control
Dump Control
Park Brake Switch
Brake Release
Component Box
Foot Controls
Sahr Brake Pedal
Throttle Control
Armrest Controls
Backrest Control
Emergency Use
Actuator
Cartridge Receiver
Dry Chemical Tank
Nozzles
General Maintenance
Monthly
Semi-Annual
Engine Symptoms
Drivelines
Wheels And Tyres
Articulation
Sahr Brakes
Park Brake
Operating Times
Speed (Loaded)
Hydraulic Pressure
Brake Pressure
Tyres
Capacities
Converter
Hydraulic Tank
Grease
Acw Hydraulic Fluid
Articulation Pins
Driveline U-Joints
Engine Mounts
Engine Radiator
Hydraulic Filter
Sahr Brakes
Transmission Mounts
Scope
Definitions
High Strength
Tolerances
Unified Fine Thread
Unified Fine Thread
Iso Switch Nut
- Atlas Copco Workshop Manuals Pack
- Atlas Copco ROC L6(25) / L6(30) / L8(25) / L8(30) operation manual
- Atlas Copco XA 60, 80, 120, 160 DD y XAS
- Atlas Copco Instruction Manual for Portable Compressors XRHS 486 Md XRHS 396 Md XRVS 466 Md XRV
- Atlas Excavator 1304 Hydraulic and Wiring Diagram
- Atlas Copco Instruction book for compressors GA11 - GA15 - GA18 - GA22
- Atlas Copco Instruction Manual and Parts List for Portable Compressors XRVS455 Md
- Atlat Copco XAHS 146 Dd - XATS 156 Dd - XA(S) 186 Dd - XAVS 166 Dd - XAHS 186 Dd Operation Manual
- Atlas Copco DM45 Parts Catalog
- Atlas Copco ROC D7-11 Technical Training Circuit Diagram Parts Manual
- Atlas Copco Stationary Air Compressors ZR, ZT 55 Parts Manual
- Atlas Copco Scooptram ST1030 Diagrams & Drawings
- Atlas Copco ROCKET BOOMER S1D Spare Parts Catalogue
- Atlas Copco Instruction Manual XAMS 407 CD XAMS 850 CD7; XATS 377 Cd
- Atlas Copco Scooptram ST1030 Service manual
