Atlas Copco Minetruck MT2010 Operators Manual 9852178613 RU
Language: Russian
Brand: Atlas Copco
Type of Machine: Minetruck
Model: Atlas Copco MT2010 Minetruck
Part Number: 9852178613
Publication Date: 2007
Number of Pages: 60 Pages
Chapter 1: Introduction To Mt2010
Vehicle Description
Operator Warnings
Time Saving Ways
Vehicle Identification
Left Side
Right Side
Chapter 2: Awareness Of Safety Precautions
Safety Signs
Safety Decals And Their Locations
To Avoid Accidents
Personal Protective Equipment
How To Operate
Vehicles
Roll Over Protective Structure (Rops) And Falling Object Protective Structure (Fops)
Keeping Your Vehicle In Good Working Order Improves Its Reliability
Vehicle Readiness
Starting And Driving
Parking The Mining Truck
Preventing Burns, Fires, And Explosions
System Mt2010 Fire Extinguishing System
Manual Fire Extinguishing System
Automatic Fire Extinguishing System
Safety Precautions During
Maintenance
Personal Protective Equipment During
Maintenance
Hydraulic Fluid
Parking The Dump Truck With
Power Units Switched Off
Main Switch (Battery Isolation Switch)
Safety Lock For The Articulated
Joint
Body Support
Vehicle Safety Equipment
Tools And Containers For Draining
Fluids
Body
Tire And Wheel Safety
Wheel Assembly
Chapter 3: Controls And Indicators
Introduction
Parking Brake Button
Indicator Panel
Warning Signs
Indicator Panel Settings
Indicator Panel Gauges
Hour Meter
Gear Gauge (Optional)
Switches And Controls
Torque Converter Lock-Up Switch
Parking Brake Switch/Indicator
Circuit Breakers
Horn Button
On/Off/Start Switch
Jake Brake (Engine Braking)
Light Switches
Main Switch (Battery Disconnect)
Automatic Engine Protection Interlock
Parking Brake Test Switch (Optional)
Manual Controls
Body Control
Teletram Unloading Control (Optional)
Steering
Gearbox Control
Electronic Gearbox Control
Pedal Controls
Sahr Brake Pedal
Accelerator Pedal
Various Auxiliary Controls
Hand Brake Pump
Sahr Brake Interlock Switch
System Actuators Extinguisher
Fire Detection System
Delay/Reset Button
Diagnostic Leds
Operator Seat
Seat Belts
Chapter 4: Operating Instructions
Vehicle Inspection
Safety Checks
Maintenance Checks
Pre-Start Checks
Post-Start Checks And Tests
Engine Starting
Start-Up Diagnostic Display
Engine Starting
Vehicle Lights
Checking For Fluid Leaks
Sahr Brake Test: Single Solenoid System
Parking Brake Test
Service Brake Test
Sahr Brake Test: Redundant Solenoid System
Backup Brake Test Switch
System Test Parking Brake In
Position 1
Checking The Parking Brake System In
Position 2
Checking The Service Brakes
Checking The Body Operation
Checking The Hot Oil Level In
The Transverter
Controlling The Mt2010 Dump Truck
Parking And Turning Off
The Engine
Operation
Procedure For Warming Up
The Vehicle Before Operation
Engine Warning Lamps
Check Engine Lamp - Yellow
Stop Engine Lamp - Red
Low Oil Temperature / High
Oil Temperature - Red Lamp
Using The Sahr Parking Brake Release System
General Driving Rules
Loading And Unloading The Body
Other Operating Instructions
Quick Start Engine
Towing The Vehicle
Transporting The Vehicle
Instructions For Loading Onto A Trailer
Chapter 5: Preventive
Maintenance
Vehicle Maintenance By The Driver
Record Keeping
Maintenance Plates According To
Standard Iso
Driver Control And Reporting
Shift Inspection Chart
Maintenance Intervals
As Required
Daily/Shift Check
Component Lubrication Chart
Daily Lubricated Items
Atlas Copco Vehicle Maintenance Kits
Daily Maintenance
As Required Maintenance
Engine Air Filter Flow Restriction Indicator
Daily/Shift Requirements
Cab, Body, Frame And Hoses
Engine Oil
Adding Engine Oil
Transmission Oil
Primary Fuel Filter/Water Separator
Hydraulic Oil Filter Restriction Indicator
Hydraulic Tank
Fire Extinguisher
Tires
Engine Drive Belts
Air Cleaner Unloader Valve
Vehicle Lights
Daily Lubrication Points
Chapter 6: Vehicle
Specifications
Performance Specifications
Fluids And Lubricating Oils
Diesel Fuel Quality And Selection Guidelines
Diesel Fuel Selection Chart
Engine Coolant
Specifications
Specifications Lubricating Oil
Lubricating Grease
Ambient
Air Temperature Charts
Atlas Copco
Wagner Hydraulic Fluid
Tightening Torque Specifications
Choose The Right Tools For The
Job
Selecting Tightening Torque By Bolt Size And Thread Type
Electrical
Connection Tightening Torques
