Hyundai
86
176,834
Antonio Carraro TR7600 TR7600 Infinity Diagnostic Workshop Manual 47307233 2023
Brand: Antonio Carraro
Type of Manual: Diagnostic Workshop Manual, Wiring Diagrams, Hydraulic Diagram
Model: Antonio Carraro 97 Series
97A565 - TR 7600 Infinity
97B165 - TR 7600 Infinity
Part Number: 47307233
Publication Date: 2023
Number of Pages: 211 Pages
01. Safety Regulations
01.1 Symbols Used​
01.2 General Precautions​
01.3 Prior To Maintenance​
01.4 Reference Operators​
01.5 Personal Protective Equipment​
19. Diagnostics
19.1 Information​
19.2 Diagnostics​
19.3 Midac Error Codes (Dtc)​
19.4 Multi-Function Instrument Error Codes (Dtc)​
19.5 Reset Service Interval​
19.6 Teaching Mode​
25. Changing The Battery
(Common Rail Engines)
25.1 Technical Specifications​
25.2 Information On Charging​
25.3 Changing The Battery​
90. Assemblies - Schematics
90.1 Assemblies​
90.2 Functional Diagrams​
90.3 Wiring Diagrams​
01.1 Symbols Used​
19.1 Information​
19.1.1 Midac - Transmission Control Unit​
19.1.2 Fuses And Relays​
19.2 Diagnostics​
19.2.1 Warning Messages On The Multifunction Display​
19.2.2 Problems At Engine Start-Up Phase​
19.2.3 Hydrostatic Unit Problems​
19.2.4 Problems In The Pto And Differential Units​
19.2.5 Power Lift Unit Problems​
19.2.6 Clutch, Brake And Steering Units Problems​
19.2.7 Electrical System Problems​
19.2.8 Cab Unit Problems​
19.6 Teaching Mode​
19.6.1 Description​
19.6.2 Type A Procedure​
19.6.3 Type B Procedure​
Models Srx - Sx - Mach4 - Tony Sr (10900-9900-8900 Common Rail) - Sr 7600 Infinity​
90.1 Assemblies​
90.1.1 Flexible Coupling​
90.1.2 Front Transmission​
90.1.3 Central Transmission​
90.1.4 Hydrostatic Unit Assembly​
90.1.5 Rear Transmission Assembly​
90.1.6 Front Axle Dimensions​
90.1.7 Rear Axle Dimensions​
90.1.8 Front Axle Assembly​
90.1.9 Rear Axle Assembly​
90.2.1 Functional Diagram Of The Transmission​
90.2.2 Brakes Diagram​
90.2.3 Brakes Diagram (With Superbrake Device)​
90.2.4 Steering Device Hydraulic Diagram (With Spool Valve)​
90.2.5 Steering Device Hydraulic Diagram (With Joystick)​
90.2.6 Hydrostatic Hydraulic Diagram​
90.2.7 Services Hydraulic Diagram​
90.2.8 Services Functional Diagram​
90.2.9 Lifting Hydraulic Diagram (Joystick On-Off + Suspension)​
90.2.10 Lifting Hydraulic Diagram (Joystick On-Off + Suspension) (With Higher Capacity Pump)​
90.2.11 Lifting Hydraulic Diagram (Proportional Joystick + Suspension)​
90.2.12 Lifting Hydraulic Diagram (Proportional Joystick + Suspension) (With Higher Capacity Pump)​
90.2.13 Lifting Hydraulic Diagram (Proportional Joystick + Suspension + Sfc)​
90.2.14 Lifting Hydraulic Diagram (3 Lever Spool Valve + Sfc)​
90.2.15 Lifting Hydraulic Diagram (3 Lever Spool Valve + Sfc+ Continuous Flow)​
90.2.16 Lifting Hydraulic Diagram (3 Lever Spool Valve + Continuous Flow)​
90.2.17 Front Lifting Hydraulic Diagram (On-Off Joystick)​
90.2.18 Front Lift Hydraulic Diagram (Proportional Joystick)​
90.2.19 Front Lifting Hydraulic Diagram (3 Lever Spool Valve + Sfc)​
90.2.20 A.C.S. Hydraulic Diagram (Automatic Clean System)​
90.2.21 Trailer Braking Hydraulic Diagram (Joystick) (Italy)​
90.2.22 Trailer Braking Hydraulic Diagram (Joystick) (Italy)​
90.2.23 Trailer Braking Hydraulic Diagram (Spool Valve) (Italy)​
90.2.24 Trailer Braking Hydraulic Diagram (Spool Valve + Continuous Flow) (Italy)​
90.3.1 Functional Wiring Diagram (Phase 3b)​
90.3.2 Functional Wiring Diagram (Phase 5)​
90.3.3 Engine Line Wiring Diagram (Model 97a565) (Phase 3b)​
90.3.4 Engine Line Wiring Diagram (Model 97b165) (Phase 5)​
90.3.5 Dashboard Line Wiring Diagram​
90.3.6 Engine Line Wiring Diagram (Model 97a565) (Phase 3b)​
90.3.7 Engine Line Wiring Diagram (Model 97b165) (Phase 5)​
90.3.8 "Superbrake" Wiring Diagram​
90.3.9 A.C.S. Wiring Diagram (Automatic Clean System)​
90.3.10 Hydraulic Braking Wiring Diagram (Italian Approval Only)​
90.3.11 On-Off Joystick Wiring Diagram (Part 1)​
90.3.12 On-Off Joystick Wiring Diagram (Part 2)​
90.3.13 Proportional Joystick Wiring Diagram​
90.3.14 Proportional Joystick Power Supply Wiring Diagram​
90.3.15 Wiring Diagram For Suspension With Proportional Joystick​
90.3.16 "Frame" Version Wiring Diagram​
90.3.17 "Cab" Version Wiring Diagram​
