Antonio Carraro Tigre 4800F Engine-Transmission Workshop Manual 47308183 2023
Brand: Antonio Carraro
Type of Manual: Engine-Transmission Workshop Manual
Model: Antonio Carraro 17 Series 17A828 - Tigre 4800F Tractor
Parts Number: 47308183
Publication Date: 2023
Number of Pages: 175 Pages
01. Safety Regulations
4800
01.1 Symbols Used
01.2 General Precautions
01.3 Preliminary Maintenance Operations
01.4 Reference Operators
01.5 Personal Protective Equipment
02. Technical Information, Refuelling, Lubrication02.1 Introduction To The Manual
02.2 Rules Of Reference
02.3 Conversion Tables
02.4 General Warnings For Replacement Of Components
02.5 Torque Settings
02.6 Lubricant Table
02.7 Table Of Sealants
02.8 Table Of Degreasers
02.9 Filling
02.10 Location Of Greasing Points
04. Engine4800
04.1 Troubleshooting
04.2 Radiator Removal And Reconnection
04.3 Engine Removal And Reconnection
05. Clutch05.1 Introduction
05.2 Clutch Disc
05.3 Adjusting The Pedal Travel
07. Front Transmission07.1 Removing And Reconnecting The Front Transmission
07.2 Disassembly And Assembly Of The Transmission Box
07.3 Bevel Gear Reset
07.4 Disassembly And Assembly Of The Differential
08. Central Transmission08.1 Central Transmission Disconnection
08.2 Central Transmission Reconnection
09. Rear Transmission09.1 Removing And Reconnecting The Rear Transmission
09.2 Gearbox Disassembly And Assembly
09.3 Differential Unit
90. Assemblies - Schematics90.1 Transmission Assemblies
01.1 Symbols Used
02.2.1 Symbols Used
02.2.2 Abbreviations Used
02.2.3 Hydraulic Symbols
Sealing Rings
02.9 Filling
02.9.1 Mechanical Engine
02.9.2 Common Rail Engine
02.9.3 Transmission
02.9.4 Front Reduction Gears
02.9.5 Rear Reduction Gears
02.9.6 Brakes - Clutch
02.10.1 Common Rail Engine
02.10.2 Front Pto
02.10.3 Front Transmission - Actio Tm
02.10.4 Central Transmission
02.10.5 Axles - Steering
02.10.6 - Brake Control - Clutch Control
02.10.7 Accelerator Control
02.10.8 Front Lifting
02.10.9 Rear Lifting
02.10.10 Reversible Drive System (Rgstm)
02.10.11 Track
02.10.12 Electrical Contacts
02.10.13 Control Cables
04.2.1 Radiator Removal
04.2.2 Radiator Reconnection
04.3.1 Engine Removal
04.3.2 Engine Connection
05.1 Introduction
05.1.1 Foreword
05.1.2 Technical Data
05.1.3 Description Of Friction Clutch
05.1.4 Troubleshooting
05.2 Clutch Disc
05.2.1 Disconnecting The Clutch
05.2.2 Inspection Of Clutch
05.2.3 Reconnecting The Clutch
07.1.1 Removing The Front Transmission
07.1.2 Reconnecting The Front Transmission
07.2.1 Disassembly Of The Transmission Box
07.2.2 Assembly Of The Transmission Box
07.3.1 Adjusting Clearance Between Crown Wheel And Pinion
07.3.2 Differential Box Bearing Preloading
07.4.1 Differential Disassembly
07.4.2 Differential Assembly
07.4.3 Reconnecting The Axle
09.1.1 Removing The Rear Transmission
09.1.2 Reconnecting The Rear Transmission
09.3.1 Differential Unit Assembly
09.3.2 Bevel Gear Reset
09.3.3 Disassembly And Assembly Of The Differential
90.1.1 Front Transmission
90.1.2 Front Differential
90.1.3 Rear Differential
90.1.4 Central Transmission
90.1.5 Rear Transmission Assembly (With Pto Clutch)
90.1.6 Front Axle Assembly (Without Drive Disengagement)
90.1.7 Front Axle Assembly (With Drive Disengagement)
90.1.8 Rear Axle Assembly
90.1.9 Brake Drum Assembly
90.1.10 Front Axle Dimensions
90.1.11 Rear Axle Dimensions
90.1.12 Functional Diagram Of The Transmission
- Antonio Carraro Axle 20.19 Repair Manual CA357358 2005 PT
- Antonio Carraro Axle 20.29S Spare Parts Catalog
- Antonio Carraro Axle 26.20M TB172 Spare Parts List CA355195 2002 IT FR
- Antonio Carraro Axle 26.22 Spare Parts List CA356033 IT EN
- Antonio Carraro Axle 26.25M TB172 Repair Manual CA357147 2001 IT EN
- Antonio Carraro Axle 26.43M Spare Parts List CA355793 2004 IT EN
- Antonio Carraro Axle 28.22 Spare Parts Catalog CA356032 IT EN
- Antonio Carraro Axle 28.28UP-180 Spare Parts List CA355125 1999 IT EN
- Antonio Carraro Axle 28.32M Spare Parts Catalog
- Antonio Carraro Axle 28.36M Spare Parts Catalog CA355094 1998 IT EN
- Antonio Carraro Axle 28.43M Service Manual CA357118 2001 IT EN
- Antonio Carraro Axles Spare Parts List EN IT
- Antonio Carraro Ergit ES Series 5400 TC to 6400 TN Technical Support Handbook
- Antonio Carraro Front Axle 28.43M FR Repair Manual CA270263 2012 IT EN
- Antonio Carraro Front-Rear Axle 26.27M Repair Manual CA270294 2013 ES
