Ammann Tandem Roller ARX 12 to ARX 20 Original Manual 1201281 2012
Brand: Ammann
Type of Machine: Tandem Roller
Type of Manual: Original Manual, Wiring Diagram, Hydraulic Diagram
Model: Ammann ARX 12, ARX 16, ARX 16 K, ARX 20 Tandem Roller
Engine: Yanmar 3TNV76/Euromot 3A - EPA Inter 4
Serial Number: 13000-
Book ID: 1201281
Publication Date: 2012
Number of Pages: 150 Pages
1 General
1.1 About This Manual
1.1.1 Target Audience
1.1.2 Purpose
1.1.3 Overview Of Customer Documentation
1.1.4 Validity Of The Manual
1.1.5 Storage Of The Manual
1.1.6 Technical Changes
1.1.7 Copyrights
1.1.8 Spare Parts
1.2 Structure Of The Manual
1.2.1 Orientation On The Roller
1.2.2 Warnings
2 Product Description
2.1 Identification Of The Roller
2.1.1 Machine Types
2.2 Product Data
2.2.1 Dimensions
2.2.2 Specifications
2.3 Roller Designation
2.3.1 Identification Plate
2.4 Intended Use
2.4.1 Intended Purpose Of The ARX 1
2.4.2 Requirements For The Roller Driver
2.4.3 Application Limits
2.5 Inappropriate Use
2.5.1 Disclaimer
3 Safety Information
3.1 General Work Safety
3.2 Roller Operation
3.2.1 Shear Points
3.3 Rollover Bar (Rops)
3.4 Noise Levels
3.5 Safety Labels On The Machine
3.5.1 Warning Stickers
3.5.2 Notice Stickers
3.6 Vibration Hazard
3.6.1 Whole-Body Vibrations
4 Structure And Function
4.1 Component Overview
5 Operating And Display Elements
5.1 Instrument Panel
5.1.1 Switch Functions
5.1.2 Control Lamps
5.1.3 Control Lamp Functions
5.2 Error Code
5.2.1 Display Upon Start-Up
5.2.2 Displays During Operation
6 Commissioning
6.1 Commissioning
6.1.1 Roller With Pneumatic Wheel (Combined Roller)
7 Operation
7.1 Rollover Bar (Rops)
7.1.1 Folding The Rops Upward
7.2 Driver’s Seat
7.2.1 Safety Information
7.2.2 Adjusting The Driver's Seat
7.3 Protection Against Vandalism
7.4 Starting The Engine
7.4.1 Ignition Switch
7.4.2 Starting The Engine
7.5 Driving And Braking
7.5.1 Setting The Operating Speed (Vibration Frequency)
7.5.2 Driving
7.6 Work Gear / Transport Gear
7.7 Turning Off The Engine
7.8 Parking Brake
7.9 Seat Switch
7.9.1 Opening The Seat Switch
7.9.2 Closing The Seat Switch
7.10 Emergency Stop
7.10.1 Initiating An Emergency Stop
7.10.2 Releasing The Emergency Stop
7.11 Locking Brake
7.12 Sprinkling
7.12.1 Checking Water Level
7.12.2 Refilling With Water
7.12.3 Switching On Continuous Sprinkling
7.12.4 Switch On Interval Sprinkling
7.13 Simple/Double Vibration
7.13.1 Vibration On / Off
7.14 Vibration Automation
7.14.1 Manual Vibration
7.14.2 Automatic Vibration
8 Options
8.1 Edge Cutter
8.1.1 Presetting Edge Cutter
8.1.2 Operation Of The Edge Cutter
8.1.3 Disks
8.2 2 Operating Levers
8.3 Rear Work Light And Revolving Warning Light
8.4 Revolving Warning Light
8.4.1 Switching On The Revolving Warning Light
8.4.2 Positions Of The Revolving Warning Light
8.4.3 Replacing The Bulb
8.5 Roof
8.5.1 Transport With Rops Folded Down
8.5.2 Fitting / Removing The Roof
8.5.3 Transport With Rops Folded Up
8.5.4 Removing The Tarpaulin
8.6 Reversing Alarm
8.7 Battery Cut-Off Switch
8.7.1 Switching Battery Cut-Off Switch On / Off
8.8 Anti-Adhesive
8.8.1 Switching On Anti-Adhesive
8.8.2 Advantages Of Anti-Adhesive
8.8.3 Anti-Adhesive Designations
9 Maintenance
9.1 General Safety Instructions
9.1.1 Battery Safety Instructions
9.2 General Information About Maintenance
9.3 Maintenance ARX 1
9.3.1 Maintenance Plan
9.4 Maintenance Check Sheet
9.5 Towing
9.6 Opening The Hood
9.7 Engine Compartment Overview
9.8 Fuel (Diesel)
9.8.1 Checking Fuel Level
9.8.2 Refueling
9.8.3 Draining Fuel
9.8.4 Cleaning The Fuel Tank
9.8.5 Fuel Filter Element
9.8.6 Water Separator Filter Element
9.9 Engine Oil
9.9.1 Checking The Engine Oil Level
9.9.2 Topping Up The Engine Oil
9.9.3 Draining Engine Oil
9.9.4 Replace The Engine Oil Filter
9.10 Hydraulic Oil
9.10.1 Checking The Hydraulic Oil Level
9.10.2 Topping Up Hydraulic Oil
9.10.3 Draining The Hydraulic Oil
9.10.4 Cleaning The Hydraulic Oil Cooler
9.10.5 Replacing The Hydraulic Oil Filter
9.10.6 Replacing The Ventilation Filter
9.11 Emptying The Water Tank
9.11.1 Cleaning Accessories
9.11.2 Emptying The Water Tank
9.12 Coolant
9.12.1 Checking Coolant Level
9.12.2 Topping Up Coolant
9.12.3 Cleaning The Radiator
9.13 Functional Check
9.13.1 Sprinkler System
9.13.2 Roller Drum Scraper
9.13.3 Tire Pressure
9.13.4 Air-Intake Filter
9.13.5 Seat Contact And Emergency Stop
9.13.6 Brakes (Brake Test)
9.13.7 Pendulum Support
9.13.8 Articulated Joint
9.14 Lubricating Steering Cylinder, Bearing
9.15 Lubricant Table
9.16 Consumables
9.17 Tightening Torques
9.18 Cleaning The Roller
10 Repair
10.1 Battery
10.1.1 Replacing The Battery
10.1.2 Starting With Another Battery (Jumpering)
10.1.3 Charging The Battery Using A Battery Charger
10.1.4 Long-Term Storage
10.2 Fuses
10.2.1 Engine Compartment Fuses
10.2.2 Steering Column Fuses
10.3 Replacing Bulbs
10.3.1 Replacing Bulbs At The Front
10.3.2 Replacing Bulbs At The Rear
10.4 Gas Strut
10.4.1 Replacing Gas Struts
11 Storage
11.1 Storage
11.1.1 Short-Term Storage
11.1.2 Long-Term Storage
11.2 Winterization (Risk Of Freezing)
11.2.1 Draining The Water Tank And Sprinkler
11.2.2 Removing The Water Filter
12 Transport
12.1 Transport
12.1.1 Joint Protection
12.1.2 Lifting At The 1-Point Lifting Eye
12.1.3 Securing The Roller On The Transporter
12.1.4 Center Of Gravity
13 Disposal
13.1 Introduction
13.2 Removal And Depressurization Of The Gas Struts
14 Appendix
14.1 Wiring Diagram, ARX 1
14.1.1 Key For ARX 1 Wiring Diagram
14.2 Hydraulics Diagram, ARX 1
14.2.1 Key For ARX 1 Hydraulics Diagram
14.3 Hydraulics Diagram, ARX 1 K
Brand: Ammann
Book ID: 1201281
1 General
1.1.2 Purpose
1.1.7 Copyrights
1.1.8 Spare Parts
1.2.2 Warnings
2.1.1 Machine Types
2.2 Product Data
2.2.1 Dimensions
2.4 Intended Use
2.5.1 Disclaimer
3.2.1 Shear Points
3.4 Noise Levels
5.1.2 Control Lamps
5.2 Error Code
6 Commissioning
6.1 Commissioning
7 Operation
7.2 Driver’s Seat
7.5.2 Driving
7.8 Parking Brake
7.9 Seat Switch
7.10 Emergency Stop
7.11 Locking Brake
7.12 Sprinkling
8 Options
8.1 Edge Cutter
8.1.3 Disks
8.5 Roof
8.6 Reversing Alarm
8.8 Anti-Adhesive
9 Maintenance
9.5 Towing
9.8 Fuel (Diesel)
9.8.2 Refueling
9.8.3 Draining Fuel
9.9 Engine Oil
9.10 Hydraulic Oil
9.12 Coolant
9.16 Consumables
10 Repair
10.1 Battery
10.2 Fuses
10.4 Gas Strut
11 Storage
11.1 Storage
12 Transport
12.1 Transport
13 Disposal
13.1 Introduction
14 Appendix
- Ammann ASC 70, 110, 150, 200, 250 Service Manual
- Ammann AV23-2, AV26-2 Spare Parts List
- Ammann ASC 100 Spare Parts List
- AMMANN Tandem Roller AV85-2 AV85-2K AV95-2 AV95-2K Workshop Manual
- Ammann ASC 70 / ASC 90 / ASC 110 / ASC 150 / ASC 200 / ASC 250 Cummins Tier II Workshop Manual
- Ammann AV12-2,AV16-2,AV20-2,AV16-2K instruction
- Ammann AP240 H Cummins Workshop Manual
- Ammann Roller ASC 70 to ASC 250 Cummins Tier II Diagrams and Workshop Manual
- AMMANN VH 850 and VH 950 Workshop Manual
- AMMANN ARX 110 Spare Parts Catalog
- AMMANN ARX 90 Workshop manual
- Ammann ARX 12/16/16K/20 Spare Parts Catalogue
- Ammann ar 65 1b40 Instruction Manual
- AMMANN VH 250/ VH 350 Workshop Manual
- AMMANN Vibrating Roller ASC100 Operating Manual
