American Lincoln Sweeper Scrubber 7765 Parts Lists & Options
Brand: American-Lincoln
Type of Machine: 7765 Sweeper Scrubber
Type of Manual: Parts Lists & Options
Model: 505-255, 505-256, 505-257, 505-258, 505-259, 505-260
Form Number: Pl28600416
Serial Number: 754378
Date: 2006
Number Of Pages: 133 Pages
Main Frame (Variable Dump)
Main Frame (Manual Dump)
Main Broom Assembly
Main Broom Lift Linkage
Side Broom Assy. (Variable Dump)
Broom and Brush Chamber Door
Hopper System (Manual Dump)
Hopper System (Variable Dump)
Hopper Filter and Impeller
Hopper Control Valve & Hopper Dump Linkage (Variable Dump)
Scrub Deck and Brushes
Rear and Side Squeegees
Squeegee Lift
Swing Squeegee Support
Solution Tank
Solution Feed Linkage
Recovery Tank
Recovery Tank Lid
Vacuum Motor & Float
Front Wheel and Brake
Brake Linkage
Rear Wheel
For/Rev Control – GM 3.0
For/Rev Control – GM 3.0 - Foot Pedal Assy.
For/Rev Control – Mitsubishi
Operator Compartment
Hydraulic Hose System (Variable Dump)
Suction & Return Hoses (Variable Dump)
Hydraulic Hose System (Manual Dump)
Suction & Return Hoses (Manual Dump)
Main Broom Motor and Fittings
Side Broom Motor and Fittings
Scrub Motors and Fittings
Squeegee and Scrub Deck Cylinders and Fittings
Power Steering, Hopper Dump & Hopper Lift Cyl’s and Fittings
Rear Wheel Motor and Fittings
Hydraulic Reservoir, Filter, and Fittings
Drive Pump and Fittings
Vacuum Motor and Fittings
Dust Control Impeller and Fittings
Power Steering Unit and Fittings
Main Control Valve and Fittings
Return Manifold and Fittings (Variable Dump)
Return Manifold and Fittings (Manual Dump)
Cylinder Control Valve and Fittings
Auxiliary Pump and Fittings - GM 3.0
Auxiliary Pump and Fittings – Mitsubishi
Battery
Engine Cover
Fuel Tank (Gas)
GM 3.0 Liter Gas Engine (Air Filtration System)
GM 3.0 Liter LP Engine (Air Filtration System)
GM 3.0 Liter Engine - Gas & LP (Supports, Brackets)
GM 3.0 Liter Engine - Gas & LP (Exhaust System)
GM 3.0 Liter Engine - Gas & LP (Fan, Radiator Hoses)
Fuel Tank (LP)
Mitsubishi S4Q2 Diesel Engine (Fan, Exhaust, Hoses)
Mitsubishi S4Q2 Diesel Engine (Supports, Brackets, Throttle)
Mitsubishi S4Q2 Diesel Engine (Fuel System)
Mitsubishi S4Q2 Diesel Engine (Air Filtration System)
Fuel Tank (Diesel)
Radiator Assembly
CE Kit
Steering and Instrument Panel
Instrument Panel Connections
Machine Harness Wiring Diagram
Machine Connection Diagram
GM 3.0 Liter Frame Side Connection Diagram
Mitsubishi S4Q2 Frame Side Connection Diagram
Hydraulics Schematic (Variable Dump)
Hydraulics Schematic (Manual Dump)
Electrical Schematic
Date: 2006
Main Broom Assembly
Squeegee Lift
Solution Tank
Recovery Tank
Recovery Tank Lid
Brake Linkage
Rear Wheel
Battery
Engine Cover
Fuel Tank (Gas)
Fuel Tank (LP)
Fuel Tank (Diesel)
Radiator Assembly
CE Kit
- Ingersoll Rand Vibratory Compactors DD24 Parts Manual
- Ingersoll Rand SD-100 Schematic, Repair & Troubleshooting Manual 2022
- Kalmar Reach Stackers 40-45T DRF 400-450 Maintenance Manual
- Bell Equipment B35D & B40D Repair manual Dumptruck ( Articulated )
- Ingersoll Rand Vibratory Compactors SD-100D C Parts Manual
- ZF – ERGOPOWER TRANSMISSION 4 WG-130/160 Service
- Bell Articulated Dump Truck B25D B30D 6x6 Repair Manual
- PALFINGER PC 2300 Hydraulic Crane Spare Parts List
- PALFINGER PC 1300 Hydraulic Crane Spare Parts List
- Parts catalog Isuzu 3LA1, 3LB1, 3LD1
- Hamm 3516, 3518 ,3520 ,3516 P, 3518 P ,3520 P Spare parts List
- HATZ Diesel 2W35,3W35,3W35T,4W35,4W35T Workshop Manual
- PALFINGER PC 3300 Hydraulic Crane Spare Parts List
- Schwing Service Training - Training Manual
- Bell Equipment B35D & B40D operation test manual Dumptruck ( Articulated )
