Alfa Romeo Tonale AWD 2025 Engine L4-1.3L Turbo Plugin Hybrid Wiring Diagram
Brand: Alfa Romeo
Model: Alfa Romeo Tonale AWD
Engine: L4-1.3L Turbo Plugin Hybrid
Publication Date: 2025
Number of Pages: 365 Pages
Electrical (OE)
Antilock Brakes _ Traction Control Systems​
(Antilock Brakes _ Traction Control Systems) - Brake System - PHEV​
(Antilock Brakes _ Traction Control Systems) - Brake System​
Antitheft and Alarm Systems​
(Antitheft and Alarm Systems) - Vehicle Theft Security System​
Automatic Transmission_Transaxle​
(Automatic Transmission_Transaxle) - Transmission - 948TE​
Auxiliary Input _ Output Jack, Entertainment System​
(Auxiliary Input _ Output Jack, Entertainment System) - Media Port​
Auxiliary Power Outlet​
(Auxiliary Power Outlet) - Power Outlets​
Brakes and Traction Control​
(Brakes and Traction Control) - Brake System - PHEV​
(Brakes and Traction Control) - Brake System​
Charging System​
(Charging System) - Starting_Charging System - 2.0L​
Collision Avoidance and Parking Assist Systems​
(Collision Avoidance and Parking Assist Systems) - Back-Up Camera​
(Collision Avoidance and Parking Assist Systems) - Blind Spot Monitor System​
(Collision Avoidance and Parking Assist Systems) - Park Assist System​
(Collision Avoidance and Parking Assist Systems) - Surround View Camera System​
Communications Control Module​
(Communications Control Module) - Telematics Communication​
Cooling System​
(Cooling System) - Cooling System - 1.3L​
(Cooling System) - Cooling System - 2.0L​
Cruise Control​
(Cruise Control) - Adaptive Speed Control System​
(Cruise Control) - Speed Control System - 1.3L​
(Cruise Control) - Speed Control System - 2.0L​
Data Link Connector​
(Data Link Connector) - Data Link Connector​
Emission Control Systems​
(Emission Control Systems) - Catalyst Monitor System - 1.3L​
(Emission Control Systems) - Catalyst Monitor System - 2.0L​
Evaporative Emissions System​
(Evaporative Emissions System) - Evaporative Emissions System - 1.3L​
(Evaporative Emissions System) - Evaporative Emissions System - 2.0L​
Exhaust Gas Recirculation​
(Exhaust Gas Recirculation) - EGR System - 2.0L​
Fuel Door​
(Fuel Door) - Fuel Door - PHEV​
(Fuel Door) - Fuel Door​
Heated Glass Element​
(Heated Glass Element) - Defogger System​
Heating and Air Conditioning​
(Heating and Air Conditioning) - A_C Control System - 2.0L​
(Heating and Air Conditioning) - Cabin Heater System​
(Heating and Air Conditioning) - HVAC System​
Ignition System​
(Ignition System) - Ignition System - 1.3L​
(Ignition System) - Ignition System - 2.0L​
Information Bus​
(Information Bus) - CAN C - EPT Bus System​
(Information Bus) - CAN C Bus System - 1.3L​
(Information Bus) - CAN C Bus System - 2.0L​
(Information Bus) - CAN CH Bus System​
(Information Bus) - CAN IHS Bus System​
(Information Bus) - CAN Private Bus System​
(Information Bus) - Ethernet Bus System​
(Information Bus) - LIN Bus Systems​
Instrument Panel, Gauges and Warning Indicators​
(Instrument Panel, Gauges and Warning Indicators) - Message Systems​
Keyless Entry​
(Keyless Entry) - Passive Entry System​
Lighting and Horns​
(Lighting and Horns) - Back-Up Lamps System​
(Lighting and Horns) - Headlamps System​
(Lighting and Horns) - Horns​
(Lighting and Horns) - Interior Lighting​
(Lighting and Horns) - Park Lamps System​
(Lighting and Horns) - Stop Lamps System​
(Lighting and Horns) - Turn Signal Lamps System​
Memory Positioning Systems​
(Memory Positioning Systems) - Memory Seat System​
Mirrors​
(Mirrors) - Mirrors - Exterior​
(Mirrors) - Mirrors - Interior​
Parking Brake System​
(Parking Brake System) - Electrical Parking Brake System - PHEV​
(Parking Brake System) - Electrical Parking Brake System​
Power and Ground Distribution​
(Power and Ground Distribution) - Auxiliary PDC Fuses - Battery​
(Power and Ground Distribution) - Auxiliary PDC Fuses_Relays - Miscellaneous​
(Power and Ground Distribution) - Auxiliary PDC Fuses_Relays - Run​
(Power and Ground Distribution) - Front PDC Fuses_Relays - Main (1.3L)​
(Power and Ground Distribution) - Front PDC Fuses_Relays - Main (2.0L)​
(Power and Ground Distribution) - Front PDC Fuses_Relays - Miscellaneous (1.3L)​
(Power and Ground Distribution) - Front PDC Fuses_Relays - Miscellaneous (2.0L)​
(Power and Ground Distribution) - Front PDC Fuses_Relays - Run​
(Power and Ground Distribution) - Fuses - Battery - Electrical Diagram (Battery Distribution Unit)​
(Power and Ground Distribution) - Fuses - Battery - Electrical Diagram (Module - Body Control)​
(Power and Ground Distribution) - Fuses - Battery - Electrical Diagram (Power Distribution Center - Front)​
(Power and Ground Distribution) - Fuses - Battery - Electrical Diagram (Power Distribution Center - Rear)​
(Power and Ground Distribution) - Fuses_Relays - Run​
(Power and Ground Distribution) - Grounds - G001A_G001B_G003A_G008A_G008E​
(Power and Ground Distribution) - Grounds - G007E_G088A_G088B_G904​
(Power and Ground Distribution) - Grounds - G022A_G023A_G023B​
(Power and Ground Distribution) - Grounds - G041A_G041B_G042A​
(Power and Ground Distribution) - Grounds - G056A_G087A_G087B_G106A​
(Power and Ground Distribution) - Grounds - Miscellaneous​
(Power and Ground Distribution) - Rear PDC Fuses_Relays - Miscellaneous​
Power Locks​
(Power Locks) - Decklid_Liftgate Lock System​
(Power Locks) - Door Lock System​
Powertrain Management​
(Powertrain Management) - Catalyst Monitor System - 1.3L​
(Powertrain Management) - Catalyst Monitor System - 2.0L​
(Powertrain Management) - EGR System - 2.0L​
(Powertrain Management) - Evaporative Emissions System - 1.3L​
(Powertrain Management) - Evaporative Emissions System - 2.0L​
(Powertrain Management) - Fuel Control System - 1.3L​
(Powertrain Management) - Fuel Control System - 2.0L​
(Powertrain Management) - Fuel Delivery System - 1.3L​
(Powertrain Management) - Fuel Delivery System - 2.0L​
(Powertrain Management) - Ignition System - 1.3L​
(Powertrain Management) - Ignition System - 2.0L​
(Powertrain Management) - Intake Air System - 1.3L​
(Powertrain Management) - Intake Air System - 2.0L​
(Powertrain Management) - Throttle Control System - 1.3L​
(Powertrain Management) - Throttle Control System - 2.0L​
(Powertrain Management) - Turbo Charger System - 1.3L​
(Powertrain Management) - Turbo Charger System - 2.0L​
Radio, Stereo, and Compact Disc​
(Radio, Stereo, and Compact Disc) - Audio System - Base​
(Radio, Stereo, and Compact Disc) - Audio System - Premium​
Restraints and Safety Systems​
(Restraints and Safety Systems) - Restraint Systems​
Seats​
(Seats) - Heated Seat System​
(Seats) - Memory Seat System​
Starting System​
(Starting System) - Starting System - PHEV​
(Starting System) - Starting_Charging System - 2.0L​
Steering Wheel​
(Steering Wheel) - Heated Steering Wheel System​
Steering​
(Steering) - Electric Power Steering (EPS) System​
Sunroof _ Moonroof​
(Sunroof _ Moonroof) - Sunroof_Power Top System​
Suspension Control ( Automatic - Electronic )​
(Suspension Control ( Automatic - Electronic )) - Active Damping System​
Tire Monitoring System​
(Tire Monitoring System) - Tire Pressure Monitoring (TPM) System​
Transfer Case​
(Transfer Case) - Transfer Case​
Trunk _ Liftgate​
(Trunk _ Liftgate) - Power Liftgate System​
Voice Activation Module​
(Voice Activation Module) - Hands Free System​
Voice Activation System​
(Voice Activation System) - Hands Free System​
Windows​
(Windows) - Windows​
Wiper and Washer Systems​
(Wiper and Washer Systems) - Wiper_Washer Systems​
Electrical - Interactive Color (Non OE)
(Antilock Brakes _ Traction Control Systems) - Anti-Lock Brakes - Except Hybrid​
(Antilock Brakes _ Traction Control Systems) - Anti-Lock Brakes - Hybrid​
(Antitheft and Alarm Systems) - Anti-Theft - Forced Entry Circuit​
(Antitheft and Alarm Systems) - Anti-Theft - Passive Anti-theft Circuit​
Body and Frame​
(Body and Frame) - Active Body Work - Grille Shutter Circuit​
(Body and Frame) - Active Body Work - Pedestrian Alert Circuit​
Body Control Module​
(Body Control Module) - Body Computer​
(Collision Avoidance and Parking Assist Systems) - Around Vision Camera Circuit​
(Collision Avoidance and Parking Assist Systems) - Blind Spot Monitoring Circuit​
(Collision Avoidance and Parking Assist Systems) - Parking Assistant Circuit​
Cruise Control​
(Cruise Control) - Cruise Control​
Doors, Hood and Trunk​
(Doors, Hood and Trunk) - Trunk, Tailgate, Fuel Doors - Deck Lid Release Circuit​
(Doors, Hood and Trunk) - Trunk, Tailgate, Fuel Doors - Power Liftgate Circuit​
Headlamp​
(Headlamp) - Headlights​
(Heating and Air Conditioning) - Air Conditioning - Automatic A_C Circuit​
Horn​
(Horn) - Horns​
Information Bus​
(Information Bus) - Computer Data Lines​
(Instrument Panel, Gauges and Warning Indicators) - Instrument Cluster - Instrument Cluster Circuit​
(Instrument Panel, Gauges and Warning Indicators) - Instrument Cluster - Overhead Console Circuit​
(Instrument Panel, Gauges and Warning Indicators) - Warning Systems​
Lighting and Horns​
(Lighting and Horns) - Exterior Lights - Backup Lamps Circuit​
(Lighting and Horns) - Exterior Lights - Exterior Lamps Circuit​
(Lighting and Horns) - Interior Lights - Courtesy Lamps Circuit​
(Lighting and Horns) - Interior Lights - Instrument Illumination Circuit​
(Memory Positioning Systems) - Memory Systems - Memory Mirrors Circuit​
(Memory Positioning Systems) - Memory Systems - Memory Seat Circuit​
Mirrors​
(Mirrors) - Mirrors - Automatic Day_Night Mirror Circuit​
(Mirrors) - Mirrors - Power Mirrors Circuit​
Navigation System​
(Navigation System) - Navigation - Navigation Circuit (Base)​
(Navigation System) - Navigation - Navigation Circuit (Premium)​
(Navigation System) - Navigation - Telematics Circuit​
(Parking Brake System) - Electric Parking Brake Circuit​
(Power and Ground Distribution) - Ground Distribution​
(Power and Ground Distribution) - Power Distribution​
Power Locks​
(Power Locks) - Door Locks​
Power Steering​
(Power Steering) - Electronic Power Steering​
(Powertrain Management) - Engine Controls - Engine Controls Circuit​
(Powertrain Management) - Engine Controls - Hybrid System Circuit​
Radiator Cooling Fan​
(Radiator Cooling Fan) - Cooling Fans​
(Radio, Stereo, and Compact Disc) - Sound Systems - Base​
(Radio, Stereo, and Compact Disc) - Sound Systems - Premium​
Rear Defogger​
(Rear Defogger) - Defogger​
(Restraints and Safety Systems) - Supplemental Restraints​
Seats​
(Seats) - Seats - Heated Seats Circuit​
(Seats) - Seats - Lumbar Circuit​
(Seats) - Seats - Passenger Power Seat Circuit​
Starting and Charging​
(Starting and Charging) - Starting_Charging - Charging Circuit​
(Starting and Charging) - Starting_Charging - Starting Circuit​
Steering Wheel​
(Steering Wheel) - Heated Steering Wheel Circuit​
Sunroof _ Moonroof​
(Sunroof _ Moonroof) - Power Tops​
(Suspension Control ( Automatic - Electronic )) - Electronic Suspension​
Transmission and Drivetrain​
(Transmission and Drivetrain) - Shift Interlock - Shift Interlock Circuit​
(Transmission and Drivetrain) - Transmissions - A_T Circuit​
(Transmission and Drivetrain) - Transmissions - Transfer Case Circuit​
Windows​
(Windows) - Power Windows​
(Wiper and Washer Systems) - Wiper_Washer​
