Alfa Romeo Giulia RWD 2025 Engine L4-2.0L Turbo Wiring Diagram
Brand: Alfa Romeo
Model: Alfa Romeo Giulia RWD
Engine: L4-2.0L Turbo
Publication Date: 2025
Number of Pages: 350 Pages
Electrical (OE)
Brand: Alfa Romeo
Electrical (OE)
Antilock Brakes _ Traction Control Systems
(Antilock Brakes _ Traction Control Systems) - Brake System
Antitheft and Alarm Systems
(Antitheft and Alarm Systems) - Vehicle Theft Security System
Automatic Transmission_Transaxle
(Automatic Transmission_Transaxle) - Transmission (A_T)
Auxiliary Cabin Heater
(Auxiliary Cabin Heater) - Cabin Heater System
Auxiliary Input _ Output Jack, Entertainment System
(Auxiliary Input _ Output Jack, Entertainment System) - Media Port
Auxiliary Power Outlet
(Auxiliary Power Outlet) - Power Outlets
Brakes and Traction Control
(Brakes and Traction Control) - Brake System
Charging System
(Charging System) - Starting_Charging System - 2.0L
Collision Avoidance and Parking Assist Systems
(Collision Avoidance and Parking Assist Systems) - Back-Up Camera
(Collision Avoidance and Parking Assist Systems) - Blind Spot Monitor System
(Collision Avoidance and Parking Assist Systems) - Park Assist System
(Cooling System) - Cooling System - 2.0L
Cruise Control
(Cruise Control) - Adaptive Speed Control System - Early Build
(Cruise Control) - Adaptive Speed Control System - Late Build
(Cruise Control) - Speed Control System
Data Link Connector
(Data Link Connector) - Data Link Connector
Emergency Contact Module
(Emergency Contact Module) - Emergency Response Assistance System
Emission Control Systems
(Emission Control Systems) - Catalyst Monitor System - 2.0L
Evaporative Emissions System
(Evaporative Emissions System) - Evaporative Emissions System - 2.0L
Exhaust Gas Recirculation
(Exhaust Gas Recirculation) - EGR System - 2.0L
Fuel Door
(Fuel Door) - Fuel Door
Garage Door Opener Transmitter
(Garage Door Opener Transmitter) - Universal Transmitter
Heated Glass Element
(Heated Glass Element) - Defogger System
Heating and Air Conditioning
(Heating and Air Conditioning) - A_C Control System - 2.0L
(Heating and Air Conditioning) - HVAC System
Ignition System
(Ignition System) - Ignition System - 2.0L
Information Bus
(Information Bus) - CAN C Bus System
(Information Bus) - CAN CH Bus System
(Information Bus) - CAN IHS Bus System
(Information Bus) - CAN Private Bus System
(Information Bus) - LIN Bus Systems
Instrument Panel, Gauges and Warning Indicators
(Instrument Panel, Gauges and Warning Indicators) - Message Systems
Keyless Entry
(Keyless Entry) - Passive Entry System
Lighting and Horns
(Lighting and Horns) - Back-Up Lamps System
(Lighting and Horns) - Fog Lamps System
(Lighting and Horns) - Headlamps System - Base
(Lighting and Horns) - Headlamps System - Premium
(Lighting and Horns) - Horns
(Lighting and Horns) - Interior Lighting
(Lighting and Horns) - Park Lamps System
(Lighting and Horns) - Stop Lamps System
(Lighting and Horns) - Turn Signal Lamps System
Memory Positioning Systems
(Memory Positioning Systems) - Memory Seat System - Base
(Memory Positioning Systems) - Memory Seat System - Premium
Mirrors
(Mirrors) - Electrochromatic Mirror System
(Mirrors) - Power Mirrors
Navigation System
(Navigation System) - Navigation System
Parking Brake System
(Parking Brake System) - Electric Parking Brake System
Power and Ground Distribution
(Power and Ground Distribution) - Additional PDC Fuses_Relay - Miscellaneous
(Power and Ground Distribution) - Auxiliary PDC Fuses_Relays - ASD (2.0L)
(Power and Ground Distribution) - Auxiliary PDC Fuses_Relays - Miscellaneous (2.0L)
(Power and Ground Distribution) - Front PDC Fuses_Relays - Fused Ignition
(Power and Ground Distribution) - Fuses - Battery - Electrical Diagram (Battery Distribution Unit)
(Power and Ground Distribution) - Fuses - Battery - Electrical Diagram (Body Control Module)
(Power and Ground Distribution) - Fuses - Battery - Electrical Diagram (Front)
(Power and Ground Distribution) - Fuses - Battery - Electrical Diagram (Post Remote Jump Positive)
(Power and Ground Distribution) - Fuses - Battery - Electrical Diagram (Rear)
(Power and Ground Distribution) - Fuses_Relays - Fused Ignition
(Power and Ground Distribution) - Fuses_Relays - Miscellaneous
(Power and Ground Distribution) - Grounds - G001A_G001B
(Power and Ground Distribution) - Grounds - G003A_G003B
(Power and Ground Distribution) - Grounds - G008A_G008B
(Power and Ground Distribution) - Grounds - G021A_G021B_G022
(Power and Ground Distribution) - Grounds - G031_G032
(Power and Ground Distribution) - Grounds - G041A_G041B_G042A_G042B
(Power and Ground Distribution) - Grounds - G053A_G055_G904
(Power and Ground Distribution) - Grounds - Miscellaneous
(Power and Ground Distribution) - Rear PDC Fuses_Relays - Miscellaneous
Power Locks
(Power Locks) - Decklid_Liftgate - Lock System
(Power Locks) - Door Lock System
Powertrain Management
(Powertrain Management) - Catalyst Monitor System - 2.0L
(Powertrain Management) - EGR System - 2.0L
(Powertrain Management) - Evaporative Emissions System - 2.0L
(Powertrain Management) - Fuel Control System - 2.0L
(Powertrain Management) - Fuel Delivery System - 2.0L
(Powertrain Management) - Ignition System - 2.0L
(Powertrain Management) - Intake Air System - 2.0L
(Powertrain Management) - Throttle Control System - 2.0L
(Powertrain Management) - Turbo Charger System - 2.0L
Radio, Stereo, and Compact Disc
(Radio, Stereo, and Compact Disc) - Audio System - Base
(Radio, Stereo, and Compact Disc) - Audio System - Premium 1
(Radio, Stereo, and Compact Disc) - Audio System - Premium 2
(Radio, Stereo, and Compact Disc) - Engine Sound Enhancement System
Restraints and Safety Systems
(Restraints and Safety Systems) - Restraint Systems - Except Export
(Restraints and Safety Systems) - Restraint Systems - Export
Seats
(Seats) - Heated Seat System - Front
(Seats) - Heated Seat System - Rear
(Seats) - Memory Seat System - Base
(Seats) - Memory Seat System - Premium
Spoilers, Flaps, and Air Dams
(Spoilers, Flaps, and Air Dams) - Active Aero Front Splitter
Starting System
(Starting System) - Starting_Charging System - 2.0L
Steering Wheel
(Steering Wheel) - Heated Steering Wheel System
Steering
(Steering) - Electric Power Steering (EPS) System
Sunroof _ Moonroof
(Sunroof _ Moonroof) - Sunroof System
Suspension Control ( Automatic - Electronic )
(Suspension Control ( Automatic - Electronic )) - Active Damping System
Tire Monitoring System
(Tire Monitoring System) - Tire Pressure Monitoring (TPM) System
Towing _ Trailer System
(Towing _ Trailer System) - Trailer Tow System
Trunk _ Liftgate
(Trunk _ Liftgate) - Decklid_Liftgate - Lock System
Voice Activation Module
(Voice Activation Module) - Hands Free System
Voice Activation System
(Voice Activation System) - Hands Free System
Windows
(Windows) - Windows
Wiper and Washer Systems
(Wiper and Washer Systems) - Wiper_Washer Systems
Electrical - Interactive Color (Non OE)Antilock Brakes _ Traction Control Systems
(Antilock Brakes _ Traction Control Systems) - Anti-Lock Brakes
(Antitheft and Alarm Systems) - Anti-Theft - Forced Entry Circuit
(Antitheft and Alarm Systems) - Anti-Theft - Passive Entry Circuit
Body Control Module
(Body Control Module) - Body Computer
Cellular Phone
(Cellular Phone) - Cellular Phones
(Collision Avoidance and Parking Assist Systems) - Blind Spot Monitoring Circuit
(Collision Avoidance and Parking Assist Systems) - Parking Assistant Circuit
(Collision Avoidance and Parking Assist Systems) - Rear View Camera Circuit
Cruise Control
(Cruise Control) - Cruise Control
Doors, Hood and Trunk
(Doors, Hood and Trunk) - Trunk, Tailgate, Fuel Doors - Deck Lid Release Circuit
Headlamp
(Headlamp) - Headlights - Headlamps Circuit (Base)
(Headlamp) - Headlights - Headlamps Circuit (Premium)
(Headlamp) - Headlights - Headlamps Leveling Circuit
(Heating and Air Conditioning) - Air Conditioning - Automatic A_C Circuit
Horn
(Horn) - Horns
Information Bus
(Information Bus) - Computer Data Lines
(Instrument Panel, Gauges and Warning Indicators) - Instrument Cluster - Instrument Cluster Circuit
(Instrument Panel, Gauges and Warning Indicators) - Instrument Cluster - Overhead Console Circuit
(Instrument Panel, Gauges and Warning Indicators) - Warning Systems
Lighting and Horns
(Lighting and Horns) - Exterior Lights - Backup Lamps Circuit
(Lighting and Horns) - Exterior Lights - Exterior Lamps Circuit
(Lighting and Horns) - Exterior Lights - Trailer Tow Circuit
(Lighting and Horns) - Interior Lights - Courtesy Lamps Circuit
(Lighting and Horns) - Interior Lights - Instrument Illumination Circuit
(Memory Positioning Systems) - Memory Systems - Memory Mirrors Circuit
(Memory Positioning Systems) - Memory Systems - Memory Seat Circuit (Base)
(Memory Positioning Systems) - Memory Systems - Memory Seat Circuit (Premium)
Mirrors
(Mirrors) - Mirrors
Navigation System
(Navigation System) - Navigation - Navigation Circuit (Base)
(Navigation System) - Navigation - Navigation Circuit (Premium 1)
(Navigation System) - Navigation - Navigation Circuit (Premium 2)
(Parking Brake System) - Electric Parking Brake Circuit
(Power and Ground Distribution) - Ground Distribution
(Power and Ground Distribution) - Power Distribution
Power Locks
(Power Locks) - Door Locks
Power Steering
(Power Steering) - Electronic Power Steering
(Powertrain Management) - Engine Controls
Radiator Cooling Fan
(Radiator Cooling Fan) - Cooling Fans
(Radio, Stereo, and Compact Disc) - Sound Systems - Base
(Radio, Stereo, and Compact Disc) - Sound Systems - Premium 1
(Radio, Stereo, and Compact Disc) - Sound Systems - Premium 2
Rear Defogger
(Rear Defogger) - Defogger
(Restraints and Safety Systems) - Supplemental Restraints
Seats
(Seats) - Seats - Front Heated Seats Circuit
(Seats) - Seats - Rear Heated Seats Circuit
Starting and Charging
(Starting and Charging) - Starting_Charging - Charging Circuit
(Starting and Charging) - Starting_Charging - Starting Circuit
Steering Wheel
(Steering Wheel) - Heated Steering Wheel Circuit
Sunroof _ Moonroof
(Sunroof _ Moonroof) - Power Tops
(Suspension Control ( Automatic - Electronic )) - Electronic Suspension - Active Aero Front Splitter Circuit
(Suspension Control ( Automatic - Electronic )) - Electronic Suspension - Active Damping Circuit
Transmission and Drivetrain
(Transmission and Drivetrain) - Shift Interlock - Shift Interlock Circuit
(Transmission and Drivetrain) - Transmissions - A_T Circuit
(Transmission and Drivetrain) - Transmissions - AWD Circuit
Windows
(Windows) - Power Windows
- ELearn Manuale Tecnico D'officina - Alfa Romeo GT
- ELearn Manuale Tecnico D_officina - Alfa Romeo 159
- Alfa Romeo Stelvio Technical Information Service Manual
- Alfa Romeo 156 workshop manual
- Alfa Romeo Workshop Manual 1995-2005
- Alfa Romeo Alfetta Haynes Workshop Manual
- Workshop and service manual for Alfa 147
- Alfa Romeo Classics Workshop and Users Manual
- [Free download] Alfa Romeo 155 repair manuals (Check Panel)
- Alfa Giullietta all Electric Scheme in English
- All about Alfa Service Manual
- Alfa Romeo 155 TS Aspirato engine parts disassembly
- Alfa Giullietta Electric scheme (ENG)
