Alfa Romeo Giulia RWD 2023 Engine V6-2.9L Turbo Wiring Diagram
Brand: Alfa Romeo
Model: Alfa Romeo Giulia RWD
Engine: V6-2.9L Turbo
Publication Date: 2023
Number of Pages: 334 Pages
Electrical (OE)
Accessories and Optional Equipment​
(Accessories and Optional Equipment) - Emergency Response Assistance System​
Antilock Brakes _ Traction Control Systems​
(Antilock Brakes _ Traction Control Systems) - Brake System​
Antitheft and Alarm Systems​
(Antitheft and Alarm Systems) - Vehicle Theft Security System​
Automatic Transmission_Transaxle​
(Automatic Transmission_Transaxle) - Transmission (A_T)​
Auxiliary Input _ Output Jack, Entertainment System​
(Auxiliary Input _ Output Jack, Entertainment System) - Media Port​
Auxiliary Power Outlet​
(Auxiliary Power Outlet) - Power Outlets​
Brakes and Traction Control​
(Brakes and Traction Control) - Brake System​
Charging System​
(Charging System) - Starting_Charging System (2.0L)​
(Charging System) - Starting_Charging System (2.9L)​
Collision Avoidance and Parking Assist Systems​
(Collision Avoidance and Parking Assist Systems) - Back-Up Camera​
(Collision Avoidance and Parking Assist Systems) - Blind Spot Monitor System​
(Collision Avoidance and Parking Assist Systems) - Park Assist System​
Cooling System​
(Cooling System) - Cooling System (2.0L)​
(Cooling System) - Cooling System (2.9L)​
Cruise Control​
(Cruise Control) - Adaptive Speed Control System​
(Cruise Control) - Speed Control System​
Data Link Connector​
(Data Link Connector) - Data Link Connector​
Differential Lock​
(Differential Lock) - Electronic Limited Slip Differential System (2.9L)​
Emission Control Systems​
(Emission Control Systems) - Catalyst Monitor System (2.0L)​
(Emission Control Systems) - Catalyst Monitor System (2.9L)​
Evaporative Emissions System​
(Evaporative Emissions System) - Evaporative Emissions System (2.0L)​
(Evaporative Emissions System) - Evaporative Emissions System (2.9L)​
Exhaust Gas Recirculation​
(Exhaust Gas Recirculation) - EGR System (2.0L)​
Fuel Door​
(Fuel Door) - Fuel Door​
Garage Door Opener Transmitter​
(Garage Door Opener Transmitter) - Universal Transmitter​
Heated Glass Element​
(Heated Glass Element) - Defogger System​
Heating and Air Conditioning​
(Heating and Air Conditioning) - A_C Control System (2.0L)​
(Heating and Air Conditioning) - A_C Control System (2.9L)​
(Heating and Air Conditioning) - Cabin Heater System​
(Heating and Air Conditioning) - HVAC System​
Ignition System​
(Ignition System) - Ignition System (2.0L)​
(Ignition System) - Ignition System (2.9L)​
Information Bus​
(Information Bus) - CAN C Bus System​
(Information Bus) - CAN CH Bus System​
(Information Bus) - CAN IHS Bus System​
(Information Bus) - CAN Private Bus System​
(Information Bus) - LIN Bus Systems​
Instrument Panel, Gauges and Warning Indicators​
(Instrument Panel, Gauges and Warning Indicators) - Message Systems​
Keyless Entry​
(Keyless Entry) - Passive Entry System​
Lighting and Horns​
(Lighting and Horns) - Back-Up Lamps System​
(Lighting and Horns) - Fog Lamps System​
(Lighting and Horns) - Headlamps System (Base)​
(Lighting and Horns) - Headlamps System (Premium)​
(Lighting and Horns) - Horns​
(Lighting and Horns) - Interior Lighting​
(Lighting and Horns) - Park Lamps System​
(Lighting and Horns) - Stop Lamps System​
(Lighting and Horns) - Turn Signal Lamps System​
Mirrors​
(Mirrors) - Electrochromatic Mirror System​
(Mirrors) - Power Mirrors​
Navigation System​
(Navigation System) - Navigation System​
Parking Brake System​
(Parking Brake System) - Electric Parking Brake System​
Power and Ground Distribution​
(Power and Ground Distribution) - Additional PDC Fuses_Relay - Miscellaneous​
(Power and Ground Distribution) - Auxiliary PDC Fuses_Relays - ASD (2.0L)​
(Power and Ground Distribution) - Auxiliary PDC Fuses_Relays - Miscellaneous (2.0L)​
(Power and Ground Distribution) - Auxiliary PDC Fuses_Relays - Miscellaneous (2.9L)​
(Power and Ground Distribution) - Front PDC Fuses_Relays - ASD (2.9L)​
(Power and Ground Distribution) - Front PDC Fuses_Relays - Fused Ignition​
(Power and Ground Distribution) - Fuses - Battery - Electrical Diagram​
(Power and Ground Distribution) - Fuses_Relays - Fused Ignition​
(Power and Ground Distribution) - Fuses_Relays - Miscellaneous​
(Power and Ground Distribution) - Grounds - G001A_G001B​
(Power and Ground Distribution) - Grounds - G003A_G003B​
(Power and Ground Distribution) - Grounds - G008A_G008B​
(Power and Ground Distribution) - Grounds - G021A_G021B_G022​
(Power and Ground Distribution) - Grounds - G031_G032​
(Power and Ground Distribution) - Grounds - G041A_G041B_G042A_G042B​
(Power and Ground Distribution) - Grounds - G053A_G055_G904​
(Power and Ground Distribution) - Grounds - Miscellaneous​
(Power and Ground Distribution) - Rear PDC Fuses_Relays - Miscellaneous​
Power Locks​
(Power Locks) - Decklid_Liftgate (Lock System)​
(Power Locks) - Door Lock System​
Powertrain Management​
(Powertrain Management) - Active Exhaust System (2.9L)​
(Powertrain Management) - Catalyst Monitor System (2.0L)​
(Powertrain Management) - Catalyst Monitor System (2.9L)​
(Powertrain Management) - EGR System (2.0L)​
(Powertrain Management) - Evaporative Emissions System (2.0L)​
(Powertrain Management) - Evaporative Emissions System (2.9L)​
(Powertrain Management) - Fuel Control System (2.0L)​
(Powertrain Management) - Fuel Control System (2.9L)​
(Powertrain Management) - Fuel Delivery System (2.0L)​
(Powertrain Management) - Fuel Delivery System (2.9L)​
(Powertrain Management) - Ignition System (2.0L)​
(Powertrain Management) - Ignition System (2.9L)​
(Powertrain Management) - Intake Air System (2.0L)​
(Powertrain Management) - Intake Air System (2.9L)​
(Powertrain Management) - Throttle Control System (2.0L)​
(Powertrain Management) - Throttle Control System (2.9L)​
(Powertrain Management) - Turbo Charger System (2.0L)​
(Powertrain Management) - Turbo Charger System (2.9L)​
Radio, Stereo, and Compact Disc​
(Radio, Stereo, and Compact Disc) - Audio System (Base)​
(Radio, Stereo, and Compact Disc) - Audio System (Premium 1)​
(Radio, Stereo, and Compact Disc) - Audio System (Premium 2)​
(Radio, Stereo, and Compact Disc) - Engine Sound Enhancement System​
Restraints and Safety Systems​
(Restraints and Safety Systems) - Restraint Systems (Except Export)​
(Restraints and Safety Systems) - Restraint Systems (Export)​
Roof and Associated Components​
(Roof and Associated Components) - Sunroof System​
Seats​
(Seats) - Heated Seat System (Front)​
(Seats) - Heated Seat System (Rear)​
(Seats) - Memory Seat System (Base)​
(Seats) - Memory Seat System (Premium)​
Spoilers, Flaps, and Air Dams​
(Spoilers, Flaps, and Air Dams) - Active Aero Front Splitter​
Starting System​
(Starting System) - Starting_Charging System (2.0L)​
(Starting System) - Starting_Charging System (2.9L)​
Steering Wheel​
(Steering Wheel) - Heated Steering Wheel System​
Steering​
(Steering) - Electric Power Steering (EPS) System​
Suspension Control ( Automatic - Electronic )​
(Suspension Control ( Automatic - Electronic )) - Active Damping System​
Tire Monitoring System​
(Tire Monitoring System) - Tire Pressure Monitoring (TPM) System​
Trailer Connector​
(Trailer Connector) - Trailer Tow System​
Voice Activation Module​
(Voice Activation Module) - Hands Free System​
Voice Activation System​
(Voice Activation System) - Hands Free System​
Windows​
(Windows) - Windows​
Wiper and Washer Systems​
(Wiper and Washer Systems) - Wiper_Washer Systems​
Electrical - Interactive Color (Non OE)
(Antilock Brakes _ Traction Control Systems) - Anti-Lock Brakes​
(Antitheft and Alarm Systems) - Anti-Theft - Forced Entry Circuit​
(Antitheft and Alarm Systems) - Anti-Theft - Passive Entry Circuit​
Body Control Module​
(Body Control Module) - Body Computer​
(Collision Avoidance and Parking Assist Systems) - Blind Spot Monitoring Circuit​
(Collision Avoidance and Parking Assist Systems) - Parking Assistant Circuit​
(Collision Avoidance and Parking Assist Systems) - Rear View Camera Circuit​
Cruise Control​
(Cruise Control) - Cruise Control​
Doors, Hood and Trunk​
(Doors, Hood and Trunk) - Trunk, Tailgate, Fuel Doors - Deck Lid Release Circuit​
Headlamp​
(Headlamp) - Headlights - Headlamps Circuit (Base)​
(Headlamp) - Headlights - Headlamps Circuit (Premium)​
(Headlamp) - Headlights - Headlamps Leveling Circuit​
(Heating and Air Conditioning) - Air Conditioning - Automatic A_C Circuit​
Horn​
(Horn) - Horns​
Information Bus​
(Information Bus) - Computer Data Lines​
(Instrument Panel, Gauges and Warning Indicators) - Instrument Cluster - Instrument Cluster Circuit​
(Instrument Panel, Gauges and Warning Indicators) - Instrument Cluster - Overhead Console Circuit​
(Instrument Panel, Gauges and Warning Indicators) - Warning Systems​
Lighting and Horns​
(Lighting and Horns) - Exterior Lights - Backup Lamps Circuit​
(Lighting and Horns) - Exterior Lights - Exterior Lamps Circuit​
(Lighting and Horns) - Exterior Lights - Trailer Tow Circuit​
(Lighting and Horns) - Interior Lights - Courtesy Lamps Circuit​
(Lighting and Horns) - Interior Lights - Instrument Illumination Circuit​
Memory Positioning Systems​
(Memory Positioning Systems) - Memory Systems - Memory Mirrors Circuit​
(Memory Positioning Systems) - Memory Systems - Memory Seat Circuit (Base)​
(Memory Positioning Systems) - Memory Systems - Memory Seat Circuit (Premium)​
Mirrors​
(Mirrors) - Mirrors​
Navigation System​
(Navigation System) - Navigation - Navigation Circuit (Base)​
(Navigation System) - Navigation - Navigation Circuit (Premium 1)​
(Navigation System) - Navigation - Navigation Circuit (Premium 2)​
(Parking Brake System) - Electric Parking Brake Circuit​
(Power and Ground Distribution) - Ground Distribution​
(Power and Ground Distribution) - Power Distribution​
Power Locks​
(Power Locks) - Door Locks​
Power Steering​
(Power Steering) - Electronic Power Steering​
(Powertrain Management) - Engine Controls​
Radiator Cooling Fan​
(Radiator Cooling Fan) - Cooling Fans​
(Radio, Stereo, and Compact Disc) - Sound Systems - Base​
(Radio, Stereo, and Compact Disc) - Sound Systems - Premium 1​
(Radio, Stereo, and Compact Disc) - Sound Systems - Premium 2​
Rear Defogger​
(Rear Defogger) - Defogger​
(Restraints and Safety Systems) - Supplemental Restraints​
Seats​
(Seats) - Seats - Front Heated Seats Circuit​
(Seats) - Seats - Rear Heated Seats Circuit​
Starting and Charging​
(Starting and Charging) - Starting_Charging - Charging Circuit​
(Starting and Charging) - Starting_Charging - Starting Circuit​
Steering Wheel​
(Steering Wheel) - Heated Steering Wheel Circuit​
Sunroof _ Moonroof​
(Sunroof _ Moonroof) - Power Tops​
(Suspension Control ( Automatic - Electronic )) - Electronic Suspension - Active Aero Front Splitter Circuit​
(Suspension Control ( Automatic - Electronic )) - Electronic Suspension - Active Damping Circuit​
Transmission and Drivetrain​
(Transmission and Drivetrain) - Shift Interlock - Shift Interlock Circuit​
(Transmission and Drivetrain) - Transmissions - A_T Circuit​
(Transmission and Drivetrain) - Transmissions - AWD Circuit​
(Transmission and Drivetrain) - Transmissions - Differential Lock Circuit​
Windows​
(Windows) - Power Windows​
(Wiper and Washer Systems) - Wiper_Washer​
