Aichi Aerial Work Platform SK200 Service Manual SME-318A
Brand: Aichi
Type of Manual: Service Manual, Electrical Diagrams
Model: Aichi SK200 Aerial Work Platform
Part Number: SME-318A
Publication Date:
Number of Pages: 102 Pages
1. General information
Brand: Aichi
Publication Date:
Overall dimensions
Specifications
Work range chart
2. Electric sectionMain power box (329-02785C)
Main power box (329-03498F)
Main power box (329-03499F)
Engine control board (325-02843)
Engine control board (329-03500)
Surge killer board (321-03346)
Main control box
Valve control board
Relay board
Voice alarm board
Lower control box (for Standard machines)
Lower control box (for the machines with optional Auto, rotation stop switch)
Upper control box (for Standard machines)
Upper control box (for the machines with optional Auto, rotation stop switch)
Joystick controller
Rear control panel
Work range control system
Work range control unit
Outrigger control box
Boom angle sensor
Boom length sensor (K21-W2001)
Boom length sensor (K21-W2003C)
Rotation sensor
Outrigger sensor
Interlock system
Accelerator motor
Engine stop motor
Automatic rotation stop system (Option)
3. Electric circuit for Individual systemEngine start and stop system (Main power box 329-02758C + Isuzu NPR chassis)
Engine start and stop system (Main power box 329-02785C + Mitsubishi FE, FK & Toyota BU chassis)
Engine start and stop system (Main power box: 329-3498F + Mitsubishi FE & Toyota BU chassis)
Engine start and stop system (Main power box 329-03499F + Isuzu NPR chassis)
Boom rotation system
Boom rotation system (with optional Automatic rotation stop system)
Boom telescoping system
Boom elevation system
Platform rotation system
Emergency stop system
Accelerator system
Interlock system
Emergency pump & Work light system
Voice alarm system
Winch system (Option)
4. Inspection and AdjustmentInspection procedures of Work range control system
Work range control system inspection sheet
Adjustment of Work range control unit
Inspection and Adjustment of Actuating speed
Adjustment data sheet
5. AppendixHydraulic circuit diagram
Electrical circuit diagram (602-05234)
Electrical circuit diagram (602-06401B)
6. Inspection manualProcedures of Daily inspection
Daily inspection check sheet
Procedures of Periodical inspection
Withstand voltage tests
Function tests
Periodical inspection check sheet
Withstand voltage test check sheet
Function tests check sheet
Major alteration and repair
- AICHI Boom Lift SR123-SR182-SR210-RZ150 Operation Manual
- Aichi RV 060/IRV 200-55 Parts Manual
- Aichi SP18A SP18AJ SP21A SP21AJ SP25B Parts Manual
- Aichi RZ090 Parts Manual
- Aichi SP12C,SP14C Parts Manual
- Aichi SR12B/ISR40B SR12BJ/ISR40BJ Parts Manual
- Aichi RV RV123/IRV403-90 Parts Manual
- AICHI SR12B(J) Boom Lift Crawler Operation Manual
- Aichi SP-18A/ISP60 SP-18AJ/ISP60J SP-21A/ISP70 SP-21AJ/ISP70J Parts Manual
- AICHI Crawler Boom Lift SR12C, SR14CJ Operation Manual
- Aichi Scissors-Type Aerial Platform RV060,IRV200-55 Operation Manual
- Aichi RV-093,RV-123 Operation Manual
- Aichi SV06,08CNL Operation Manual
- Aichi RZ150 01 Parts Manual
- Manual Aichi Boom Lift SP12C & SP14CJ Operation Manual
