Hyundai
86
176,834
AGCO Power Engine AP75 Workshop Service Manual V837092292
Brand: AGCO Power
Type of Manual: Workshop Service Manual, Electric Diagrams
Model: AGCO Power AP75 Engine
Part Number: V837092292
Publication Date: 2022
Number of Pages: 378 Pages
1. General
1.1 Engine type designations​
1.2 Location of the engine serial number​
1.3 Contents of the engine identification plate​
1.4 Engine serial number​
1.5 Additional information label​
1.6 Type plate of the electronic control unit​
1.7 Safety instructions​
1.8 How to use this manual​
1.9 To the user​
1.10 Lift the engine​
1.11 Technical data​
1.12 Engine construction​
2. Specifications
2.1 Cylinder block​
2.2 Cylinder head​
2.3 Valves and rocker arm​
2.4 Camshaft​
2.5 Crankshaft​
2.6 Flywheel​
2.7 Timing gears​
2.8 Connecting rod​
2.9 Piston, piston rings and piston pin​
2.10 Lubrication system​
2.11 Oil pump​
2.12 Thermostat​
2.13 Lubricating oil quality requirements​
2.14 Coolant quality requirements​
2.15 Fuel quality requirements​
2.16 Terminal diagram​
3. Maintenance
3.1 Major maintenance and engine replacement​
3.2 Cylinder block​
3.3 Flywheel housing​
3.4 Front cover​
3.5 Cylinder head​
3.6 Valve mechanism​
3.7 Crankshaft​
3.8 Connecting rods and pistons​
3.9 Flywheel​
3.10 Timing gear assembly​
3.11 Lubrication system​
3.12 Cooling system​
3.13 Belt drive​
3.14 Air control system maintenance​
3.15 Fuel system​
3.16 SCR system​
3.17 DPF maintenance​
3.18 Engine control system​
3.19 Air compressor​
Index
