Ag-Chem Applicators Air Max Precision and Air Max Precision 2 Parts Catalog 539950D1
Brand: Ag-Chem
Type of Machine: Applicators
Model:
Ag-Chem Air Max Precision Applicators
Ag-Chem Air Max Precision 2 Applicators
Serial Number: WXX1001-WXX1001
Part Number: 539950D1
Number of Pages: 1704 Pages
Product Containment
Air Max Precision
Installation Arrangement, Air Max Precision 1
V-Hood Installation, Air Max 1000
Conveyor Cover
Amp1
Gearbox, Worm, 5 1, 1.44 Bore
Airmax Precision
Hydraulic Motor, 9.9 Cid
Bypass Valve
Air Max 1000
Hydraulic Component Installation, Amp, Common, 2013
Bulkhead Assembly, Conv, Air Max Precision
Hydraulic Filter Assembly, High Pressure, 4000 Psi, Amp
Hydraulic Valve Assembly, Fan
Fan
Low Pressure Hydraulic Filter Assembly
Reservoir Assembly, 2013
Sequence Valve Assembly, Air Max
Hydraulic Boom Sequence Valve
Valve Assembly, Fan, Anti-Cavitation, Air Max
Sensor Installation, Bin Full Empty
Sensor Installation, Rate, Air Max 1
Decal Installation, Air Max Precision
Installation Arrangement, Air Max Precision 2
Amp2
Air Max 2000
Hydraulic Hose Installation, Air Max Precision, Air Max 2000
Sensor Installation, Rate, Air Max 2
Decal Installation, Air Max Precision 2
Bracket Installation, Gauge
Bulkhead Cover Installation, Front
Bumper Installation, Rear
Catch Pan Installation, Air Max 1000 2000
Dual Bin Divider Installation
Riser
No Granular Bin
Retainer Cap Reload, 0.62
Fender Installation, Air Max
2016-2018
Conveyor Flap Kit
Flip Panel Installation
Holddown Assembly, Main, 3 Wheel
Holddown Assembly, Air Max 2000, 8104
Airmax 1000 2000
Ladder Installation, Rear
Granular Metering Housing Installation
Assembly
Motor, Electrical, Twin Output
Lift Eye Installtion, Airmax Precision
Lift Eye Decal Installation , Airmax Precision
Mud Flap Installation, Air Max
Screen Installation
Screen Installation, Front, Without Tank
Screen Installation, Air Max 1000
Sight Gauge Installation, Spraymax
Sleeper Installation
Air Max
Auxiliary
Unloading Chute Installation
Window Installation, Hopper
V-Hood Installation, Dual Bin
V-Hood Installation, Air Max 2000
081_Primary Product Distribution
Blower Installation
Blower Assembly
Hydraulic Motor Assembly, Fan
Hydraulic Motor, 1.83 Cir
Oil Cooler Assembly, Left Hand
Oil Cooler Assembly, Right Hand
Fan Guard Installation
Pre Cleaner Installation
Fan Assembly, 1.83 Cir
Fan, 16 Inch, Dual Nylon Fins
Hydraulic Motor Assembly, Fan, 1.83 Cir
Conveyor Belt Installation, Upper
Conveyor Belt Installation, Lower
Conveyor Belt Assembly, 15.75, Lower
Conveyor Drive Sprocket Installation, Front
Manifold Assembly
Manifold And Funnel Installation
Housing Installation-Metering, Granular
Spacer Installation, 2.25 Wheel
Metering Wheel Installation, Standard
Metering Wheel Installation, Low Rate
Metering Wheel Installation, Maxirate High
Outlet Deflector Installation
Outlet Deflector Installation, Air Max 1000 2000
Plate Installation, Product Deflector
146_Secondary Product Distribution
3 Way Valve, 0.75, Sideload
3 Way Valve, 1.50, Bottom Load
3 Way Valve, 2.00, Bottom Load
Ball Valve, 0.75 Npt, Union, Poly
Ball Valve, 0.75 Poly, Full Flow
Ball Valve, 1.50 Inch Poly, Full Flow
Ball Valve, 2.00 Inch, Poly
Ball Valve, 2.00 Npt, Union, Poly
Boom Tee Assembly
Boom Valve Assembly, Left Hand
Electrical Valve, 2, Way, 1.00, With Connector
Pressure Transducer, 0-100 Psi
Boom Valve Assembly, Right Hand
Boom Valve Installation, Boom Sections
Centrifugal Pump, 2.00 X 1.5, 142, Hydraulic Motor
Hydraulic Motor, Hm3 With Bypass
Chemical Eductor Assembly
Chemical Eductor Kit
Chemical Eductor Assembly, Frame And Band
Chemical Eductor Kit, With Lance And Plunger
Chemical Eductor, Clean Load Ii, Poly
Clean Load Lid Kit, 12 Inch
Chemical Eductor Installation, Spraymax
Electrical Group, Autoboom, Air Max 1000 2000
End Row Nozzle Installation, Air Max 1000 2000
Valve, 144a
Flowmeter, 2.00 Inch, 140 Pulse Per Gallon, 12 Volt
Flowmeter Plumbing Assembly
Hose Installation, Product, No Injection
Hose Installation, Pump Station
Plug Installation, Plumbing, Without Eductor
Product Pump Assembly, Fitting, Hydraulic
Pump And Reload Station Assembly
Reload Pump And Valve Installation
Valve Assembly, Fill And Spray
Sensor Installation, Autoboom
Ultrasonic Sensor, Digital, Left Hand
Ultrasonic Sensor, Digital, Right Hand
Single Nozzle Holder, .75 Pipe
Triple Nozzle Holder .75 Pipe
Spraybar And Plumbing Installation, Triple
Spraybar Assembly, A Section, Left Hand, Triple
Spraybar Assembly, A Section, Right Hand, Triple
Spraybar Assembly, B Section, Left Hand, Triple
Spraybar Assembly, B Section, Right Hand, Triple
Spraybar Assembly, C Section, Triple
Spraybar Assembly, Center, Left Hand, Triple
Spraybar Assembly, Center, Right Hand, Triple
Spraybar And Plumbing Installation, 70 Foot
Spraybar Assembly, A Section, Left Hand, 70 Foot
Spraybar Assembly, A Section, Right Hand, 70 Foot
Spraybar Assembly, B Section, 70 Foot, Left Hand
Spraybar Assembly, B Section, 70 Foot, Right Hand
Spraybar Assembly, C Section, 70 Foot
Spraybar Assembly, Center, Left Hand, 70 Foot
Spraybar Assembly, Center, Right Hand, 70 Foot
Spraymax Option, Air Max 1000 2000
Tank Installation, Spraymax
Tank Assembly, Spraymax
Hydraulic Installation, Spraymax
Hydraulic Valve Assembly, Spraymax
Hydraulic Valve, Shutoff
Decal Installation, Spraymax, English
Spraymax Option, Air Max 1000 2000, Triple
389_Booms
2012
Boom Assembly, 70 Foot, Air Max 1000 2000, Left Hand
Hydraulic Cylinder Assembly, Boom Tip Fold
Boom Assembly, 70 Foot, Air Max 1000 2000, Right Hand
Left Hand
Tip Fold Cylinder Assembly
Right Hand
Boom Pivot Installation
Hydraulic Cylinder Assembly, Boom Fold
Boom Fold Cylinder Assembly
Boom Rack Assembly
Boom Rack Installation
Boom Suspension Installation
Hydraulic Cylinder Assembly, Suspension, Boom
Boom Suspension Cylinder Assembly
Boom Tip Weldment, Left Hand, 70 Foot
Boom Tip Weldment, Right Hand, 70 Foot
Boom Weldment, Inner, Left Hand, 70 Foot
Boom Weldment, Inner, Right Hand, 70 Foot
Outlet Tube Installation, Boom Center
Tube Installation, Product, Center, 70 Foot
446_Foam Marker
Foam Marker Tank Installation, Air Max 1000 2000
Foam Marker Tank Assembly, 60 Gallon, Ss
Solenoid Valve Rework
Solenoid Valve
Valve, Stainless Steel, 0.75
60 Gallon
Foam Marker Regulator Assembly
Solenoid Valve, 25npt, 12 Volt
Foam Marker Tank Installation, 36 Gallon
Foam Marker Tank Assembly, 36 Gallon
36 Gallon
Foam Marker Hose Installation
486_Hydraulic System
Field Installation, Boom Holddown
Field Kit, High Pressure Filter
Gear Pump Assembly, Air Max, 82xx
Hydraulic Pump Gear, 1.16 Cir Displacement, B, Splined
Non Cvt
Hydraulic Reservoir Assembly, Air Max Precision
Hydraulic Component Installation, Pwm Valve Amp 1
Hydraulic Valve Assembly, Conveyor, Amp 1
Hydraulic Valve, Pwm 15gpm, Air Max Precision 1
Hydraulic Component Installation, Pwm Valve Amp 2
Hydraulic Valve Assembly, Conveyor, Amp 2
Hydraulic Valve, Pwm 15gpm, Air Max Precision 2
Hydraulic Cylinder Assembly, Left Hand
Hydraulic Cylinder Assembly, Right Hand
Hydraulic Cylinder Assembly, Boom Rack
Hydraulic Group, Pump Installation, Amp 6 8xxx
Hydraulic Pump Assembly, Air Max Precision, 8xxx
Piston Pump, 5.19 Cid, Right Hand
2010
Hydraulic Hose Installation, 82xx
Hydraulic Hose Installation, 83xx
Hydraulic Hose Installation, 9300, Rexroth
Hose Installation
Hydraulic Hose Installation, Air Max Precision, Common
Hydraulic Hose Kit, Common
Hydraulic Hose Installation, Air Max Precision 2
Hydraulic Hose Installation, Common
Hydraulic Hose Kit, Air Max Precision, Common
Hydraulic Hose Installation, Airmax Precision
Hydraulic Hose Installation, Air Max Precision, 9203
9300
Hydraulic Hose Installation, Eaton
Tg7300c Tg8300c Tg8400c
Hydraulic Pump Installation, Amp, Bosch
Hydraulic Pump Assembly, Air Max Precision, Bosch
Piston Pump, 90cc, Right Hand
Hydraulic Valve
Tg9300c
Hydraulic Pump Installation, Air Max Precision, 9300
Hydraulic Piston Pump, 98cc, Eaton
Hydraulic Pump Installation, Eaton
Hydraulic Pump Assembly, Air Max Precision, Eaton
Hydraulic Pump Installation, 84xx
Hydraulic Pump Assembly, Air Max Precision, 84xx
Hydraulic Pump Installation, Amp, 82xx
Pump Assembly, Variable Displacement, 82xx
Variable Displacement Pump 4.33 Spl, R P
Hydraulic Pump Installation, Amp, 9203
Hydraulic Pump Assembly, Air Max Precision, 9203
Variable Displacement Pump, 4.33, Thru Drive, Ccw
Hydraulic Tank Heater Installation, 120 Volt
Hydraulic Cap And Plug Installation
Plug Assembly, -8 Orfs
Loose Combo Option, Air Max Precision, 82xx
Plug Assembly, -6 Orfs
Pump Replacement Kit
Valve Installation
Valve Assembly
735_Electrical System
Kit, Repair
Electric Box Assembly, Enclosure
Granular
2014
Module Assembly, Input Output, Can
2015
Electric Group Roll Tarp, 9203
Electric Group, Spraymax, Falcon Vt
Electric Group, Falcon Vt, Granular, 9203
Electrical Group, Falcon Vt, Granular, Airmax
Electrical Group, Falcon Vt, Air Max 2000
Electric Group, Raven 5000, Viper
Electrical Group, Raven, Air Max, 2000
Electrical Group, Raven, Granular, Air Max, 9203
Electrical Group, Spraymax, Raven
Electrical Group, Vt, Granular, 8400, 2012
Electrical Group, Raven, Granular, Air Max, 8400, 2012
Electrical Group, Raven, Granular, Airmax
Harness Installation, Extension, End Row, Co Application
Lamp Cluster, Rear, Right Hand
Lamp Cluster, Rear, Left Hand
Switch Installation, End Row, Liquid
Taillight Installation
Electrical Group, Falcon Vt, Air Max 1000
819_Pressure Washer And Rinse System
Pressure Washer Tank Installation
3 Wheel
4 Wheel
Tg7300b Tg8300b
Tg9300b
Rinse Tank Installation, Co Application
Tank Installation, Pressure Washer Co Application Rinse
832_Decals
839_Attachments
Cab Kit, 98 Air Max, New Cab
Tarp Installation, Air Max
Ratchet Assembly, 1.00 Inch, Ss
Roll Tarp Installation
Seal Group
Hardware Group, No Tarp
852_Accessories
Grease Bank
Relay
Brand: Ag-Chem
Model:
Product Containment
Air Max Precision
Conveyor Cover
Amp1
Airmax Precision
Bypass Valve
Air Max 1000
Fan
Amp2
Air Max 2000
Riser
No Granular Bin
2016-2018
Conveyor Flap Kit
Airmax 1000 2000
Assembly
Screen Installation
Air Max
Auxiliary
Blower Installation
Blower Assembly
Manifold Assembly
Boom Tee Assembly
Valve, 144a
389_Booms
2012
Left Hand
Right Hand
Boom Rack Assembly
446_Foam Marker
Solenoid Valve
60 Gallon
36 Gallon
Non Cvt
2010
Hose Installation
9300
Hydraulic Valve
Tg9300c
Valve Installation
Valve Assembly
Kit, Repair
Granular
2014
2015
3 Wheel
4 Wheel
Tg7300b Tg8300b
Tg9300b
832_Decals
839_Attachments
Seal Group
852_Accessories
Grease Bank
Relay
- Ag Chem EU Applicator Twin Bin Four Bin Terragator Operator Manual
- Ag Chem EU Applicator TG8400 Terragator Chassis Service Manual_79034095
- Ag Chem EU Applicator TG8400 Terragator Chassis Operator Manual
- Ag Chem EU Applicator TG8400B Terragator Chassic Repair Time Schedule_568642D1D
- Ag Chem EU Applicator TG9300 Terragator Chassis Operator Manual
- Ag Chem EU Applicator TG8400B Chassis Operator Manual_568099D1C
- Ag Chem EU Applicator TG7300 TG8300 Chassis Operator Manual
- Ag Chem EU Applicator TG9300B Chassis Workshop Service Manual_79035609C
- Ag Chem EU Applicator TG9300B Chassis Operator Manual_568102D1B
- Ag Chem EU Applicator TG7300 TG8300 Terragator Chassis Service Manual
- Ag Chem EU Applicator TG7300B TG8300B Chassis Operators Manual_568093D1B
- Ag Chem EU Applicator TG9300B Taragator Chassis Repair Time Schedule_568643D1G
- Ag Chem EU Applicator TG7300B TG8300B Workshop Service Manual_79035602B
- Ag Chem EU Applicator Terragator Liquid System Repair Time Schedule_AG331650A
- Ag Chem EU Applicator TG7300B TG8300B Chassis Repair Time Schedule_568640D1G
