ACE Pick-Carry Crane FX210 Parts Catalog 2017
Brand: ACE
Type of Machine: Pick-Carry Crane
Type of Manual: Parts Catalog, Pneumatic Circuit
Model: ACE FX210 Pick-Carry Crane
Document Number: 102092420500-B
Publication Date: 2017
Number of Pages: 281 Pages
S No. Description
01 Body And Frame Work
01.01 Front Body Sub Assy (Inner Outrigger)
01.02 Front Body Sub Assy. (With Outside Outrigger)
01.03 Front Body Sub Assy. (With Outside Outrigger -Dw)
01.04 Outrigger Hyd. Assembly
01.05 Rear Frame Sub Assembly
01.06 Center Pivot Assembly
01.07 Counter Weight Assembly -Installation
01.08 Front Bonnet -Cover Assembly
01.09 Rear Bonnet -Cover Assembly
01.10 Cabin Assembly
01.11 Cabin Sub Assembly
01.12 Tyre Guard Assembly
02 Boom And Extension Assembly
02.01 Boom Complete Assembly - 58‘
02.02 Main Boom Assembly
02.03 1st Extension Assembly
02.04 2nd Extension Assembly
02.05 Manual Extension Assembly
02.06 Boom Complete Assembly - 36‘
02.07 Main Boom Assembly
02.08 1st Extension Assembly
02.09 2nd Extension Assembly
02.10 Santch Block Assembly-6f
03 Engine -Transmission Assembly
03.01 Engine Installation
03.02 Air Intake Assembly
03.03 Exhaust System
03.04 Fuel Tank Installation
03.05 Cooling System
04 Front -Rear Axle
04.01 Front Axle -Brake Assembly
04.02 Front Wheel Assembly
04.03 Rear Wheel Assembly
04.04 Rear Axle Assembly (Eicher)
04.05 Single Suspension Assy)
04.06 Drive Line Assembly
S No. Description Page No
05 Control -Linkages
05.01 Engine Control Assembly
05.02 Gear Shifting Assembly
05.03 Pneumatic Circuit
05.04 Clutch Assembly
05.05 Foot Accelerator Assembly
06 Hydraulics
06.01 Control Valve Circuit
06.02 Steering Circuit
06.03 Luff Circuit
06.04 Hydraulic Tank Instalation
06.05 Steering Unit
06.06 Priority Valve
06.07 Hydraulic Cylinders
07 Electrical System
07.01 Wiring Harness
07.02 Light Assembly
07.03 Battery Installation
07.04 Dashboard -Instruments
08 Decals
08.01 Daecals-36‘
08.02 Daecals-58‘
09 Optional Items
09.01 S.L.I. (Safe Load Indication System)
09.02 Proximity Sensor Assembly
09.03 Rear View Camera Installation
09.04 Revolving Light -Fire Extinguisher Assembly
09.05 Hose Kit
10 Engine Components
10.01 Enigne Block
10.02 Cylinder Head
10.03 Main Bearing
10.04 Piston -Rings
10.05 Connecting Rod
10.06 Crank Shaft
10.07 Camshaft
10.08 Flywheel
10.09 Flywheel Housing
10.10 Timing Gears
10.11 Timing Gears Case
10.12 Oil Sump
10.13 Oil Suction Strainer
10.14 Oil Pump
10.15 Engine Valves
10.16 Oil Dipstick
10.17 Intake Manifold
10.18 Exhaust Manifold
10.19 Oil Cooler And Filter
10.20 Oil Cooler -Filter –Internal Components
10.21 Thermostat
10.22 Breather Hose
10.23 Fuel Injection Pump And Pipes
10.24 Nozzle Holder
10.25 Water Pump
10.26 Assy Of Air Compressor
10.27 Assy Of Air Compressor Intrnal Components
10.28 Alternator
10.29 Alternator – Internal Components
10.30 Turbo Charger
10.31 Starter Motor
10.32 Sundries And Finish
10.33 Loose Items
11 Clucth
12 Auxilliary Gear Box
13 Air Inflation Kit
14 Filter Assembly
15 Winch
16 Control Valve
17 Brake Valve
18 Unloader Valve
19 Quick Release Valve
20 Graduated Hand Control Valve
21 Rear Axle 440 Dh (Eicher)
22 Winch Installation
23 Fly Jib Asembly
24 Man Basket Assembly
Brand: ACE
S No. Description
04 Front -Rear Axle
06 Hydraulics
06.03 Luff Circuit
06.05 Steering Unit
08 Decals
08.01 Daecals-36‘
08.02 Daecals-58‘
09 Optional Items
09.05 Hose Kit
10.01 Enigne Block
10.02 Cylinder Head
10.03 Main Bearing
10.04 Piston -Rings
10.06 Crank Shaft
10.07 Camshaft
10.08 Flywheel
10.10 Timing Gears
10.12 Oil Sump
10.14 Oil Pump
10.15 Engine Valves
10.16 Oil Dipstick
10.21 Thermostat
10.22 Breather Hose
10.24 Nozzle Holder
10.25 Water Pump
10.28 Alternator
10.30 Turbo Charger
10.31 Starter Motor
10.33 Loose Items
11 Clucth
14 Filter Assembly
15 Winch
16 Control Valve
17 Brake Valve
18 Unloader Valve
23 Fly Jib Asembly
- PALFINGER Crane Spare Parts List
- Palfinger PK 23500 Loader Crane Spare Parts Catalog
- Cifa Magnum MK 28.4Z - 115 RH Parts Catalog 293437
- Locatell Crane Workshop Manual
- Tiger Crane 1061 Operation and Maintenance Manual
- VF VENIERI 9290431E 2008 Spare Parts Catalogue
- Crane PCM 120 AS Electrical Schematic
- Century Tacom MR-30 Owner's Parts Manual
- Potain GTMR 331C Cranes Service Manual
- Altec Crane AC 26-28-30S Maintenance Manual
- Böcker AHK 27/1200, AHK 30/1400 Operating Instructions
- Altec Crane AC 26-28-30s Maintenance Manual
- Comacchio MC600 Drilling Rig Maintenance Manual SN0930
- Bell B50D Dump Truck Shop Manual
- Broderson IC-80-1D Yardrunner Owners Manual
