ACE Backhoe Loader AX-124(4WD) Parts Catalog
Brand: ACE
Model: ACE AX-124(4WD) Backhoe Loader
Number of Pages: 256 Pages
01.01 Chassis Assembly
01.02 Stabilizer Assembly
01.03 Bonnet Assy
01.04 Cabin Assembly
01.05 Cabin Sub Assembly
01.06 Loader Linkage Assembly
01.07 Boom Assembly
01.08 Dipper Assembly
01.09 King Post Carriage Assembly
01.10 Slew Assembly
01.11 Engine And Transmission Assembly
01.12 Air Intake Assembly
01.13 Exhaust Assembly
01.14 Fuel Tank Assembly
01.15 Propeller Shaft Assembly
01.16 Front Axle Assy
01.17 Rear Axle Assembly
01.18 Tyre Assy Bkt-14x25
01.19 Tyre Assy Std 16.9x28
01.20 Tyre Assy Bkt 9x16
01.21 Brake Linkage Assy
01.22 Parking Brake Assembly
01.23 Gear Shifting Assembly
01.24 Loader Control Valve Assembly
01.25 Loader Control Valve Assembly 6in1
01.26 Loader Hydraulics Assembly
01.27 Loader Hydraulics Assembly 6in1
01.28 Excavator Control Valve Assembly
01.29 Excavator Hydraulics Assembly
01.30 Acc Linkage Assembly
01.31 Engine Stop Cable
01.32 Hydraulics Steering Assembly
01.33 Hydraulic Tank Assembly
01.34 Cooling System Assembly
01.35 Light Installation Assembly
01.36 Battery Installation
01.37 Dashboard Assembly
01.37 Side Dashboard Assembly
01.38 Loader Bucket Assembly (1.2 Cum)
01.39 Loader Bucket Assembly 6in 1.1 (Cum )
01.40 Excavator Bucket Assy (0.30 Cum)
01.41 Excavator Bucket Assy (0.24 Cum)
01.42 Excavator Bucket Assembly (0.18 Cum)
01.43 Excavator Bucket Assembly (0.12 Cum)
01.44 Pump Assembly
01.45 Decal Assembly
01.46 Wiring Harness
01.47 Stickers Assy
02 Carraro Transmission Component’s
02.01 Oil Pump 103 -104
02.02 Oil Filter
02.03 Transmission Housing
02.04 Input Abd Pto Transmission Shaft (Axe A)
02.05 Reverse Shaft (Axe D) And Primary Shaft (Axe B)
02.06 Secondary Shaft (Axe C)
02.07 Gear Control
02.08 Transmission Control Valve
02.09 Torque Converter
03 Kirloskar Engine Component’s
03.01 Adaptor For Inelt Manifold 121
03.02 Alternator 12v-65a Mico 122
03.03 Bosch Rotary Fip For 4r1040ta2 Engine 123
03.04 Bracket For Mounting Accelerator & Stop Cable 124
03.05 Breather Pipe (Turbo Engine) 125
03.06 Cover Plate For Oil Filling On Gear Casing 126
03.07 Crank Shaft Pulley With Poly V Groove (P6pk200) 127
03.08 Crankcase (Turbocharged Engine)
03.09 Crankshaft 134
03.10 Cylinder Head Assembly
03.11 Cylinder Liner.(105 Dia) 142
03.12 Delivery Body. 143
03.13 Dipstick S-F Fabricated Modified Oil Sump 144
03.14 Exhaust Diffuser For K24 Tc (Cmvr)
03.15 Exhaust Manifold Fwe Top Open For K24 Tc (Cmvr) 147
03.16 Fan Mounting 148
03.17 Fip Gear Cover And Feed Pump Assembly
03.18 Fip Gear With Facial Cam 151
03.19 Flywheel End Foot(Packing) 152
03.20 Flywheel For Carraro Transmision 153
03.21 Flywheel Housing Sae 3 144.5 Mm , Two Starter Bore
03.22 Fuel Pipe Filter To Fip Bs Iii 156
03.23 Gear Casing (New Design Combined With Front Cover) With
Timing Pointer
03.24 Gear End Foot 161
03.25 High Pressure Pipe Assembly
03.26 Hose For Air Cleaner 164
03.27 Hose T-Bolt Clamp (Dia. ) 165
03.28 Iegr Camshaft & Gear Assembly For Ta Engine 166
03.29 Injector Assembly 167
03.30 Inlet Manifold (Fwe Top Open) 168
03.31 Intermediate Gear &Support For Combined Gear Casing 169
03.32 L.O.Pump Intermediate Gear An Support 170
03.33 Leak Off Pipe Assly 171
03.34 Lifting Hook (S-F 440 Crs Water Pump) 172
03.35 Lub Oil Cooler & Spin-On Filter)
03.36 Lub Oil Pump (S-F Without Intermediate Gear)
03.37 Lube Oil Pr Sendor (Two Terminal With Body Ground 181
03.38 Lube Oil Sump Fabricated (35 Deg, 265 Ht) 182
03.39 Mico Starter 12vdc 2.7kw Suitable For - 20 Deg. C 183
03.40 Mounting For Alternator Amps With 79.1 Pcd 6pk Poly
V Pulley
03.41 Mud Collector Bsiii 186
03.42 Name Plate 187
03.43 Oil Seal Housing (Flywheel End) 188
03.44 Piston & Con Rod(Turbocharged Engine)
03.45 Plastic Cap For Inlet Adaptor 193
03.46 Plug For Inlet Manifold 194
03.47 Poly V Belt (Sect 6pk - 1270) Fenner 195
03.48 Pre Cleaner Bs- Iii 196
03.49 Pushrod & Tappets 197
03.50 Radial Seal Air Cleaner 8 Cu. M Per Min 198
03.51 Rocker Cover 4r1040t G.E. Top Lub Oil Filling 199
03.52 Rocker Support Assly (Low Freq. Tappet Adj
03.53 Spin On Fuel Filter(With Hand Primer) Suitable For Rotary
Pump 204
03.54 Stop Lever Arrangement For Bs Iii Engines 205
03.55 Suction Tube (4r1040t Fabricated Sump 35 Deg Incl) 206
03.56 T Bolt Clamp Klipco Tb108 - Jupitor (108 To 116 Dia 207
03.57 Thermostat And Mounting (71 Mm Cover)
03.58 Thermostat Plug 210
03.59 Tr59_6.1 Hsg Turbocharger
03.60 Water Pump282.5 Crs Without Pulley 214
03.61 Water Pump Pulley Withpoly V Groove (P6pk120 215
04 Carraro Rear Axle Components
04.01 Axle Housing
04.02 Bevel Gear Set
04.03 Differential
04.04 Brakes
04.05 Brakes Control
04.06 Wheel Hub
04.07 Final Reduction
04.08 Rear Axle Over Hauling Kit
05 Tandem Pump 232
06 Standard Tool Kit Components
07 Propeller Shaft
08 Hoses Kit
09 Hydraulic Cylinders
Brand: ACE
01.03 Bonnet Assy
01.07 Boom Assembly
01.10 Slew Assembly
01.44 Pump Assembly
01.47 Stickers Assy
02.02 Oil Filter
02.07 Gear Control
Timing Pointer
V Pulley
Pump 204
04.01 Axle Housing
04.03 Differential
04.04 Brakes
04.06 Wheel Hub
05 Tandem Pump 232
07 Propeller Shaft
08 Hoses Kit
- Ingersoll Rand SD-100 Schematic, Repair & Troubleshooting Manual 2022
- Kalmar Reach Stackers 40-45T DRF 400-450 Maintenance Manual
- Parts catalog Isuzu 3LA1, 3LB1, 3LD1
- Hamm 3516, 3518 ,3520 ,3516 P, 3518 P ,3520 P Spare parts List
- HATZ Diesel 2W35,3W35,3W35T,4W35,4W35T Workshop Manual
- Schwing Service Training - Training Manual
- HBM Motor Grader NOBAS BG160T-4
- Yuchai Diesel Engine YC4D Parts Catalog
- ZF – ERGOPOWER TRANSMISSION 4 WG-190/210 Service
- PALFINGER PK4501 PK5001 Hydraulic Crane Spare Parts List
- Tamrock Ranger 700-2 Operator and Maintenance Manual
- XGMA XG 955II Wheel Loader Parts Catalog
- MF 50H, MF 50HX, MF 60HX Turbo Operator Manual
- VOITH Retarder 115 Actors After Sales Service Manual
- O&K RH23.5 Crawler Excavator Hydraulics Schematics and Spare Parts Catalogue
