Momed80
151
36,345
Zoomlion Scissor Lifts ZS0508C ZS0610C ZS1216C Service And Maintenance Manual 2023 EN
Brand: Zoomlion
Type of Machine: Scissor Lifts
Model: Zoomlion ZS0508C ZS0610C ZS1216C Scissor Lifts
Publication Date: 2023
Number of Pages: 97 Pages
SECTION 1 MAINTENANCE SAFETY INSTRUCTION
1.1 Maintenance Cycle Instruction
1.2 User Responsibility
1.3 Service Center Obligation
1.4 Disclaimer
SECTION 2 MAINTENANCE REQUIREMENTS
2.1 General
2.1.1 Maintenance purpose
2.2 Precautions
2.2.1 General precautions
2.2.2 Safety precautions
2.3 Pre-delivery Inspection
2.4 Maintenance Intervals Instrustion
2.5 Maintenance Schedule
2.6 Maintenance Inspection
2.6.1 Daily inspection
2.6.1.1 Check manual and decals
2.6.1.2 Pre-start inspection
2.6.1.3 Battery inspection
2.6.1.4 Check hydraulic oil level
2.6.1.5 Functional test
2.6.1.6 Check the tension of crawler and drive chain
2.6.2 Maintenenca every month
2.6.2.1 Maintenance after 30 days
2.6.2.2 Lubricate steering knuckles
2.6.3 Maintenance every 3 months
2.6.3.1 Battery maintenance
2.6.3.2 Inspect electrical wiring
2.6.3.3 Inspect walking device bolt torque
2.6.3.4 Inspect emergency stop function
2.6.3.5 Test key switch
2.6.3.6 Test the horn
2.6.3.7 Test the drive brakes
2.6.3.8 Test the top drive speed-stowed position
2.6.3.9 Test slow drive speed-stowed position
2.6.3.10 Hydraulic oil analysis
2.6.3.11 Inspect hydraulic oil tank cap venting system
2.6.3.12 Inspect tray latch components
2.6.3.13 Inspect down limit switch and angle sensor
2.6.3.14 Inspect up limit switch
2.6.4 Maintenance every 6 months
2.6.4.1 Inspect platform overload system
2.6.4.2 Replace the hydraulic tank venting cap
2.6.4.3 Replace hydraulic filters
2.6.4.4 Lubricate drive device chain
2.6.5 Maintenance every year
2.6.6 Maintenance every 24 months
SECTION 3 TRICAL SYSTEM MAINTENANCE
3.1 Electrical System Troubles shooting
3.1.1 Fault code
3.1.2 Troubles shooting method
3.1.3 ECU pin definition
3.1.4 Electrical schematic
SECTION 4 HYDRAULIC SYSTEM MAINTENANCE
4.1 Inspection and Maintenance of Hydraulic System
4.1.1 Routine inspection of hydraulic system
4.1.2 Hydraulic oil tank
4.1.2.1 Inspection of hydraulic oil tank
4.1.2.2 Replace exhaust cap of hydraulic tank
4.1.2.3 Replace hydraulic oil
4.1.3 Hydraulic system air exhaust
4.1.4 Check hydraulic system line breakage
4.1.5 Hydraulic cylinder inspection
4.1.6 Hydraulic hose inspection
4.1.7 Hydraulic valves
4.1.8 Hydraulic system pressure adjusting
4.1.8. 1 Lifting pressure adjusting
4.1.9 Hydraulic schematics
SECTION 5 COMMON FAULTS ANALYSIS
5.1 Hydraulic System Fault
5.2 Electrical System Fault
