Momed80
151
36,345
Zoomlion Articulating Boom Lifts ZA14JE-Li Service And Maintenance Manual 2021 EN
Brand: Zoomlion
Model: Zoomlion ZA14JE-Li Articulating Boom Lifts
Publication Date: 2021
Number of Pages: 101 Pages
Section 1 Maintenance Safety Instruction
1.1 Maintenance Personnel Duties, Requirements And Safety Equipment
1.1.1 Duties
1.1.2 Basic Requirements
1.1.3 Personnel Safety Equipment
1.2 Maintenance Precautions
1.2.1 Precautions
1.2.2 Precautions In Maintenance
Section 2 Technical Parameters
2.1 Performance
2.2 Specification And Performance
2.3 Capacity
2.4 Battery
2.5 Tire
2.6 Functional Speed
2.6.1 Operating Procedure When Testing Speed
2.6.2 Test Cautions
2.7 Torque Requirements
2.8 Lubrication
2.8.1 Hydraulic Oil
2.9 Pressure Setting
Section 3 General Introduction
3.1 Machine Preparation, Inspection And Maintenance
3.1.1 General Introduction
3.1.2 Preparation, Inspection And Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery And Daily Inspections
3.1.5 Machine Annual Inspection
3.1.6 Preventive Maintenance
3.2 Maintenance And Instruction
3.2.1 General Description
3.2.2 Safety And Operating Standards
3.2.3 Cleaning
3.2.4 Component Disassembly And Installation
3.2.5 Component Disassembly And Reinstallation
3.2.6 Pressure-Fit Parts
3.2.7 Bearing
3.2.8 Washer
3.2.9 Bolt And Torque Applications
3.2.10 Hydraulic Line And Electric Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Lubrication And Maintenance
3.3 Lubrication And Information
3.3.1 Hydraulic System
3.3.2 Hydraulic Oil
3.3.3 Hydraulic Oil Replacement
3.3.4 Lubrication Specification
3.4 Cylinder Drift Test
3.4.1 Platform Drift
3.4.2 Cylinder Drift
3.5 Pin And Bearing Inspection Instructions
3.5.1 Fiber Bearing
3.6 Welding On The Device
3.6.1 Please Perform The Following Operations When Welding On The Device
3.6.2 Do Not Perform The Following Operations When Welding On The Device
Section 4 Chassis And Turntable
4.1 Tire And Wheel
4.1.1 Tire Inflation
4.1.2 Tire Damage
4.1.3 Tire Replacement
4.1.4 Wheel Replacement
4.1.5 Wheel Installation
4.2 Chassis Angle Sensor System
4.3 Manual Lowering System
4.4 Traveling Drive System
4.5 Travel Reducer
4.5.1 Disassembly
4.5.2 Installation
Section 5 Boom And Platform
5.1 Platform And Jib
5.1.1 Load Cell
5.1.2 Rotary Actuator
5.1.3 Jib Lifting Cylinder
5.2 Boom Assembly
5.2.1 Cable
5.2.2 Leveling Cylinder
5.2.3 Lower Leveling Cylinder And Lifting Cylinder
5.2.4 Upper Boom
5.2.5 Telescopic Cylinder
5.2.6 Tower Boom And Its Cylinder
Section 6 Electrical System Maintenance
6.1 Fault Code
6.2 Common Faults And Solutions
Section 7 Electrical Information And Schematic
7.1 General Introduction
7.2 Multimeter Basic Operation
7.2.1 Grounding
7.2.2 Backside Detection
7.2.3 Minimum Value/Maximum Value
7.2.4 Polarity
7.2.5 Range
7.2.6 Voltage Measurement
7.2.7 Resistance Measurement
7.2.8 Conduction Test
7.2.9 Current Measurement
7.3 Deutsch Connector
7.3.1 Dt/Dtp Series Connector Assembly
7.3.2 Dt/Dtp Series Connector Disassembly
7.3.3 Hd30/Hdp20 Series Connector Assembly
7.3.4 Hd30/Hdp20 Series Connector Removal
7.4 Electrical Schematics
7.5 Hydraulic Schematics
