Weidemann Wheel Loader 5080 TELE RL70T Spare Parts List 1000326089 2016 IT ES EN
Language: Italian, English, Spanish
Brand: Weidemann
Type of Machine: Wheel Loader
Type of Manual: Spare Parts List
Model: Weidemann 5080 TELE Type RL70T Wheel Loader
Version 1.0
Engine: Perkins 854E Engine
Part Number: 1000326089
Publication Date: 2016
Number of Pages: 705 Pages
Service Kit
Engine Accessories
Engine 854E
Piston
Rocker Arm
Camshaft
Injection Nozzle
Fuel Pump
Sensor
Control Unit
Ring Gear
Starter
Oil Pan
Oil Strainer
Dipstick
Ventilation
Valve Cover
Filler Neck
Pressure Valve
Filter Housing
Pulley
Thermostat Housing
Spacer For Fan
Control Housing
Adapter
Oil Pump
Turbocharger
Intake Manifold
Exhaust Manifold
Reduction
Exhaust Pipe
Soot Filter
Replacement Filter Element
Contamination Indicator
Fuel Line
Glow Plug
Lifting Eye
Engine Wiring Harness
Adapter Piece
Cooling
Coupling
Cooler Hoses
Air Cooler Hoses
Travel Drive
Variable Pump
Variable Motor
Hydraulic Tank
Return Suction Filter
Inch Device
Inch Valve
Valve Block
Valve Holder
Propeller Shaft
Drive
Axle Tube
Planetary Housing
Disc Brake
Service Brake
Gearbox Housing
Transfer Case
Differential Lock
Solenoid Valve
Mudguard
Steering
Steering Wheel
Steering Cylinder
Steering Cylinder Pin
Steering Hoses
Steering Column
Gear Pump
Pump Accessories
Hydrostatic Steering
High Pressure Filter
Priority Valve
Hydraulic Diagram
Working Hydraulics
Tipping Cylinder
Lift Cylinder
Equalizing Cylinder
Telescopic Cylinder
Solenoid Valve
Control Valve
Vibration Damper
Vibration Damping
Manifold
Pressure Relief Valve
Additional Hydraulics
Auxiliary Hydraulic Circuit
Return Line
Plug-In Coupling
Main Cable
Wiring Harness
Rear Light Wiring Harness
Oil Cooler Cable
Cabin Electrics
Joystick
Vehicle Lighting
Work Lighting
Fuse Holder
Accelerator Pedal
Sensor Kit
Additional Electrics
Socket 230v
Trailer Socket
Battery Isolator Holder
Battery Isolator Switch
Battery Cable
Valve Wiring Harness
Seat Wiring Harness
Engine Preheating
Additional Wiring Harness
Potentiometer
Bracket
Tires
Frame
Front Frame
Rear Frame
Articulation Joint
Hose Holder
Trailer Coupling
Self-Recovery Coupling
Tow Coupling
Towing Device
Auto-Hitch Coupling
Additional Weight
Fender
Cladding
Engine Hood
Hood Insulation Mat
Hinge
Hood Lock
Gas Spring
Locking Plate
Adjusting Plate
Loading System / Arm System
Telescopic Loading System
Quick-Change Plate
Telescopic Arm
Cabin
Pedal
Cabin Cladding
Crossmember
Cabin Door
Windscreen
Rear Window
Special Version
Hydraulic Tilting Cab
Cabin Mounting
Seat S722
Suspension Msg 95al-06
Seat S732-12
Air-Suspended Seat Base
Seat Cover
Sticker
Heating / Air Conditioning
Heating
Air Conditioning
Air Conditioning Condenser
Air Dryer
Air Conditioning Compressor
Evaporator
Option
License Plate Holder
Toolbox
Load Indicator Instrument
Earth Shovel
Pallet Fork
Machine Documentation
Nameplate
