Martin Welker
107
235,284
Volvo Buses B6FA Service Repair Manual
Brand: Volvo
Type of Machine: Buses
Type of Manual: Service Repair Manual
Model: Volvo B6FA Buses
Number of Pages: 811 Pages
21035-4 Engine parts, transferring
21070-1 Engine, remove
21072-1 Engine, install
21122-1 Cylinder head, remove
21124-1 Cylinder head, install
21412-2 Valves, adjust
23724-2 Delivery pipes, replace (all)
25518-2 Turbocharger, replace
26106-2 Radiator, external cleaning
26108-2 Radiator, replace
26202-2 Coolant pump, replace
26273-4 Thermostats, test
27510-3 Cable, electrical motor, replace
33104-0 Starter motor, replace
37130-2 Trailer connection, replace
41103-2Clutch plate, replace
41103-3 Clutch plate, replace
41185-2 Clutch, adjust
41283-5 Release bearing, pulling clutch replace
41314-2 Clutch cylinder, replace
43130-2 Output shaft sealing ring, replace
43130-2 Output shaft sealing ring, replace1
43137-3 Oil pressure, check
43165-5 Gearbox, disassemble and inspect
43167-5 Gearbox, assemble
43170-1 Gearbox, remove
43172-1 Gearbox, install
43173-5 Main shaft, overhaul
43175-5 Range gear, overhaul
43181-5 Intermediate shaft, overhaul
43197-5 Input shaft, overhaul
43266-2 Range cylinder, overhaul
43278-4 Control housing, overhaul
45122-2 Universal joint angles, check and calculate 1
45122-2 Universal joint angles, check and calculate2
45122-2 Universal joint angles, check and calculate3
45122-2 Universal joint angles, check and calculate4
46514-2 Pinion sealing ring, replace 2
46534-5 Shift unit, differential lock, overhaul
46570-1 Differential carrier, remove 2
46571-4 Differential carrier, overhaul 1
46571-4 Differential carrier, overhaul 2
46571-4 Differential carrier, overhaul4
46572-1 Differential carrier, install 1
46802-2 Diff lock, check and adjust disengage and engage position
46803-3 Diaphragm sleeve, adjust
48170-1 Power take-off, remove
48171-4 Power take-off, overhaul 1
48172-1 Power take-off, install
56371-4 Control lever parking brake, overhaul
56373-4 Footbrake valve, overhaul
57106-4 Trailer brake control, overhaul
57106-5 Lock free brakes
60110-2 Wheel angles, check-measure (all) FAT 5
60110-2 Wheel angles, check-measure (all) FAT 6 6.5 6.7
61103-3 Steering knuckle, overhaul (one)
87520-3 Flame indicator, replace
87521-3 Seals, heat exchanger, replace
87522-3 Seals, fan, replace
87525-3 Ignition electrodes, replace
87526-3 Glow plug strainer, replace
87527-3 Circuit board, replace
87528-3 Discharge cap, replace
87530-3 Casing cover, replace
87531-3 Overheating breaker, replace
87578-2 Carbon dioxide content, check and adjust
ABS
Actions regarding turbo failure
Adjusting diff. lock indication
Balancing the propeller shaft
Basic housing
Battery analyser 7200 user manual
Cables and connectors, fault tracing
Check of high pressure monitor
Checks before fault tracing
Clutch System bleed 1
Clutch System bleed
Control lamp, replace
D1LC
Diaphragm spring
Diff. lock
Disc
Dual draw dual return fuel system troubleshooting
Final drive rev 2
Final drive rev1
Final drives– 6x4 vehicles, adjustment
Flame indicator
Flashing code signals on controls (D1LC)
Flywheel housing run-out, check
Front wheel hub FAT 5,0
Fuel pump
Fuel tank strainer, clean and drain condensation water
Gate interlock
Gearbox general
Gearbox manual
Glow plug
Group 460 465 466 468
Group 460
Heat exchanger
Hydraulic pump, service
Hydraulic system, fault tracing
Hydraulic system, general
Hydrodynamic retarder
Installation instructions, accessories
Manual gearbox foult tracing
Manual gearbox, warranty claim handling, additional information
Modification of cable harness for new brake contacts or horn
One propeller shaft, 4x2, 6x2 vehicles
One propeller shaft, 6x4 vehicles
Other special equipment
Parking heater 1
Parking heater
Power take-off 1
Power take-off 3
Power take-off
Propeller shaft 1
Propeller shaft
Pulling clutch, single disc
R3 - Group 431 432
Ready-reference, fault codes
Rear axle design
Rear axle parts
Rear axle, general
SEATS
Single disc clutch
Spacer ring, possible combinations
Spacer sleeve
Speed sensor with O-ring
Steering knuckle, exploded view 1
Steering knuckle, exploded view 2
Straps
Symbol index
Test instrument for checking speed limiter, range inhibitor, cruise control and the tachograph's speedometer
The heater's output variations in relation to temperature
The pressure monitor's cut-off values
Three propeller shafts, 4x2, 6x2 vehicles
Three propeller shafts, 6x4 vehicles
Tightening torques rear axle
Tightening torques
Towing information
Two propeller shafts, 4x2, 6x2 vehicles
Two propeller shafts, 6x4 vehicles
Volvo service program
Washing, polishing and waxing, cab
Welding requirements
Working with chemicals
