Hyundai
86
178,785
Toyota Yaris & Yaris HV 2020-2021 Service and Repair Manual
Format: HTML
Brand: Toyota
Type of Machine: Automotive
Type of Manual: Service and Repair Manual, Wiring Diagram
Model: Toyota Yaris, Yaris HV
Engine: 1KR-FE, M15A-FKS, M15A-FXE, G16E-GTS
Model Code:
KSP211
MXPA1#(MXPA10,MXPA11)
MXPH1#(MXPH10,MXPH11)
GXPA16
Region: Europe, Australia
Date:
2021.11
2021.08
2021.04
2021.01
2020.09
2020.07
2020.03
Repair Manual
General
INTRODUCTION
SETUP
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
M15A-FKS (ENGINE CONTROL)
M15A-FXE (ENGINE CONTROL)
G16E-GTS (ENGINE CONTROL)
1KR-FE (ENGINE CONTROL)
HYBRID / BATTERY CONTROL
M15A-FKS (ENGINE MECHANICAL)
M15A-FXE (ENGINE MECHANICAL)
G16E-GTS (ENGINE MECHANICAL)
1KR-FE (ENGINE MECHANICAL)
M15A-FKS (FUEL)
M15A-FXE (FUEL)
G16E-GTS (FUEL)
1KR-FE (FUEL)
M15A-FKS (EMISSION CONTROL)
M15A-FXE (EMISSION CONTROL)
G16E-GTS (EMISSION CONTROL)
1KR-FE (EMISSION CONTROL)
M15A-FKS (INTAKE / EXHAUST)
M15A-FXE (INTAKE / EXHAUST)
G16E-GTS (INTAKE / EXHAUST)
1KR-FE (INTAKE / EXHAUST)
M15A-FKS (COOLING)
M15A-FXE (COOLING)
G16E-GTS (COOLING)
1KR-FE (COOLING)
M15A-FKS (LUBRICATION)
M15A-FXE (LUBRICATION)
G16E-GTS (LUBRICATION)
1KR-FE (LUBRICATION)
M15A-FKS (STARTING)
M15A-FXE (STARTING)
G16E-GTS (STARTING)
1KR-FE (STARTING)
CRUISE CONTROL
STOP AND START
Drivetrain
P910 (HYBRID TRANSMISSION / TRANSAXLE)
CLUTCH
C551 (MANUAL TRANSMISSION / TRANSAXLE)
EC6E (MANUAL TRANSMISSION / TRANSAXLE)
EA67F (MANUAL TRANSMISSION / TRANSAXLE)
K320 (MULTIDRIVE / CVT)
GF1A (TRANSFER / 4WD / AWD)
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
Suspension
ALIGNMENT / HANDLING DIAGNOSIS
FRONT SUSPENSION
REAR SUSPENSION
TIRE PRESSURE MONITORING
TIRE / WHEEL
Brake
BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
Steering
POWER ASSIST SYSTEMS
STEERING COLUMN
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
NAVIGATION / MULTI INFO DISPLAY
TELEMATICS
PARK ASSIST / MONITORING
Power Source / Network
M15A-FKS (BATTERY / CHARGING)
M15A-FXE (BATTERY / CHARGING)
G16E-GTS (BATTERY / CHARGING)
1KR-FE (BATTERY / CHARGING)
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
THEFT DETERRENT / KEYLESS ENTRY
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
SUPPLEMENTAL RESTRAINT SYSTEMS
PRE-COLLISION
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
ACOUSTIC VEHICLE ALERTING SYSTEM
EXTERIOR PANELS / TRIM
New Car Features
General
INTRODUCTION
SPECIFICATIONS
M15A-FKS (FUEL)
M15A-FXE (FUEL)
G16E-GTS (FUEL)
1KR-FE (FUEL)
M15A-FKS (COOLING)
M15A-FXE (COOLING)
G16E-GTS (COOLING)
1KR-FE (COOLING)
M15A-FKS (STARTING)
G16E-GTS (STARTING)
1KR-FE (STARTING)
CRUISE CONTROL
STOP AND START
Drivetrain
CLUTCH
Suspension
FRONT SUSPENSION
REAR SUSPENSION
TIRE / WHEEL
Brake
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
Steering
STEERING COLUMN
AUDIO / VIDEO
TELEMATICS
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
PRE-COLLISION
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Introduction
INTRODUCTION
ABBREVIATIONS
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS INTRODUCTION
WIRE HARNESS REPAIR GUIDELINES
TERMINAL AND CONNECTOR REPAIR PROCEDURES
System Circuit
Drivetrain
Suspension
Brake
Steering
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
ADAS / AD
Location & Routing
Engine Compartment
Instrument Panel
Body
Antenna
Fuse List
Engine Compartment
Instrument Panel
Body
Connector List
Engine Compartment
Instrument Panel
Body
Overall EWD
Drivetrain
Suspension
Brake
Steering
Vehicle Interior
Vehicle Exterior
ADAS / AD
Body Repair Manual
General
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
