Momed80
151
36,345
Terex Atlas Excavator TC3306LC 1804LC Workshop Manual 6128616
Brand: Atlas, Terex
Type of Machine: Excavator
Type of Manual: Workshop Manual, Electrical Diagram
Model: Atlas TC3306LC Terex 1804LC Excavator
Part Number: 6128616
Number of Pages: 394 Pages
Contents
Technical data
General information on hydraulics
1 Introduction
2 Explanation of symbols and bases of calculation
Cab Serial 935
1 General view of cab
2 Right switch panel
3 Left switch panel
4 Special equipments ¨
5 Display and controls
6 Description of the starting procedure
LSC system
1 Function of the LSC system
2 Simplified schematic
3 Functional description: control valve operation for one load
4 Functional description: control valve combined
5 Calculation of flow split-up
Hydraulics
1 Hydraulic schematic
2 Servo control unit
3 Control Block VT 7
4 Directional control valve VW 18/25
5 Directional control valve VW 18/25 for cylinder implement
6 Load Sensing Regulator with load limit control valve
7 Regulating Pump HPR 160D-01
8 Slewing motor HMF-02P
9 Variable displacement motor HMV
10 Brake valve
11 Engine Speed Control Actuator CHX01/..
12 Variable drive motor with automatic control system
13 Main rotation connection
14 Hydraulic diagram 3306 LC (1804 LC)
Adjusting Instructions
1 Bleeding air from the system
2 Engine speed, calibrating and teach-in function (TI)
3 Bleeding air from the system
4 Emergency circuit
5 Load limit control valve
6 Measuring union rail
7 LS (load sensing) controller (P1 and P2)
8 Pressure cut-off
9 Pressure cut-in stage
10 Secondary valve
11 Reverse flow restrictors
12 Supply interruption safety switch
13 Propeller shaft speed / Forwards/reverse (625 rpm)
14 Pilot pressure - travel - wheeled excavator / Checking/adjusting (25 bar)
15 Travel motor adjustment / Checking/setting
16 Moment control for orange-peel grab / Checking/adjusting
17 Secondary valve/slewing motor
18 Pressur Adjustment Table
Pilot Control Equipment
1 Dozer blade/support pads
2 Folding jib, slewing, lifting/lowering, bucket/grab
3 Function
4 Sectional view pilot control equipment
5 Diagram regulating piston
Driving Engine
1 Setting of valves
Slewing gear
1 Exploded view slewing gear - GD5/GD6
2 Bolt pre-loadings and tightening torques
3 Maintenance
Crawler gear
1 General information
2 Name plate
3 Notes
4 Installation
5 Lubrication
6 Start up
7 Maintenance
8 Disassembly
9 Reassembly
Traveling mechanism
Cylinder
Electric
1 Code letters, terminal designations
2 Symbols
3 Line number codes
4 Jump starting, starting with a flat battery
5 Identification of the „Linde electronic box“
6 Linde - Limit Power Control System 1704 - 1804
7 Explanation of the Eprom
8 Encoding Linde box CEB - 10/...
9 Sensor for watertemperature
10 Fluid sensors
11 Thermostat switch
12 Oil pressure switch
13 Pressure warning switch for power brake pressure accumulator
14 Pressure switch for emergency control
15 Pressure-operated switch
16 Circuit and location diagrams
Air condition systems
1 Safety instructions for work on AC system
2. Air Condition system 1504/1604 LC
3. Air Condition system TC2006/2306
Maintenance
1 Safety instructions for maintenance
2 Renewing hydraulic fluid filter element
3 Renewing mesh strainer fuel filter
4 Renewing fuel filter
5 Changing engine oil, renewing engine oil filter
6 Filling capacities
7 Maintenance schedule
8 Lubrication points of excavator
9 Lubricants
10 Central lubrication
Miscellaneous
1 Centaflex coupling
2 Repair Instruction for Welded Assemblies
