Sumitomo Excavator SH330-3B Spare Parts Catalog
Brand: Sumitomo
Type of Machine: Excavator
Model: Sumitomo SH330-3B Excavator
List of Files:
SH330-3B inner.pdf (Pages: 341)
SH330-3B main.pdf (Pages:
Detail Content:
SH330-3B inner.pdf
CYL; ARM
CYL; BOOM
CYL; BUCKET
MOTOR
MOTOR; TRACTION
PUMP; HYD
RADIATOR
VALVE; CONTROL(100)
VALVE; CONTROL(103)
VALVE; CONTROL(13)
VALVE; CONTROL(0)
VALVE; CONTROL(3)
VALVE; CONTROL(203)
VALVE; CONTROL(23)
VALVE; CUSHION
VALVE; HOLDING
VALVE; REMOTE CONT
VALVE; SOLENOID
VALVE; SPL
SH330-3B main.pdf
2-PUMP FLOW CIRCUIT
AIR CLEANER(W ELEMENT)
AIR CLEANER(W ELEMENT)PCLEANER
AIR CONDITIONER
AIR CONDITIONER(CAB)
AM/FM RADIO HIGH BAND
ARM CYLINDER LINE
ARM(SHORT)
ARM(STANDARD)
ARM(SUPER SHORT)
BATTERY
BOLT
BOOM CYLINDER LINE
BOOM LINE
BOOM(BACK-HOE)
BUCKET & ARM LINE
BUCKET CYLINDER LINE
BUCKET LINKAGE(BUILD-UP)
BUCKET LINKAGE(STANDARD)
BUCKET LINKAGE
BUCKET
BYPASS FILTER
CAB SIDE STEP
CENTER JOINT
CONSOLE BOX(100)
CONSOLE BOX(10)
CONSOLE BOX(0)
CONSOLE BOX
CONSOLE BOX(200)
CONTROL VALVE
CONTROLLER
COUNTER WEIGHT
DC-DC CONVERTER (12V10A)
DOG CHAIN
DOUBLE ACTING CIRCUIT
DRAIN LINE
ELEC.PARTS & WIRE HARNESS(105)
ELEC.PARTS & WIRE HARNESS(15)
ELEC.PARTS & WIRE HARNESS(5)
ENGINE(ISUZU)
FLOOR MAT
FUEL FEED PUMP
FUEL LINE
FUEL TANK
GREASE LINE
GROUSER SHOE 600 SEAL
GROUSER SHOE 800 SEAL
HEATER
HORN(ELECTRIC)
HOUSE(104)
HOUSE(14)
HOUSE(4)
HOUSE
HYDRAULIC PUMP
JOYSTICK CONTROL
LOWER FRAME
LOWER ROLLER
LOWER UNDER COVER
LUBRICATION PUMP
MUFFLER(STANDARD)
MULTI-PURPOSE+3WAY VALVE(105)
MULTI-PURPOSE+3WAY VALVE(15)
MULTI-PURPOSE+3WAY VALVE(5)
NAME PLATE(ENGLISH)
NAME PLATE
OPE NAME PLATE
OPERATOR'S CAB
OPTION LINE(BAR BASE)
PAINTING(YELLOW)
PILOT CONTROL LINE
PILOT PRESS.& RETURN LINE
PLUG
PRESSURE LINE
RADIATOR(STANDARD)
REAR STAND
REAR VIEW MIRROR(R&L) EXPORT
REAR VIEW MIRROR
RECOIL SPRING
REPAIR PARTS KIT
RETURN & OIL COOLER LINE
REVOLVING EQUIPMENT
REVOLVING FRAME
SEAT BELT
SERVICE VALVE CONTROL
SERVICE VALVE
SINGLE ACTING CIRCUIT
SPARE PARTS KIT
SUCTION LINE
SUMP TANK
SUNVISOR
SWING LINE
SYSTEM MONITOR
TAKE-UP ROLLER
TOOLS
TRACK GUARD(DOUBLE)
TRACTION EQUIPMENT
TRACTION LINE
TRACTION MOTOR LINE
TURN TABLE BEARING
UPPER ROLLER
UPPER UNDER COVER
WINDOW WASHER
WORKING LIGHT
Brand: Sumitomo
List of Files:
Detail Content:
SH330-3B inner.pdf
CYL; ARM
CYL; BOOM
CYL; BUCKET
MOTOR
MOTOR; TRACTION
PUMP; HYD
RADIATOR
VALVE; CONTROL(100)
VALVE; CONTROL(103)
VALVE; CONTROL(13)
VALVE; CONTROL(0)
VALVE; CONTROL(3)
VALVE; CONTROL(203)
VALVE; CONTROL(23)
VALVE; CUSHION
VALVE; HOLDING
VALVE; REMOTE CONT
VALVE; SOLENOID
VALVE; SPL
SH330-3B main.pdf
2-PUMP FLOW CIRCUIT
AIR CONDITIONER
ARM CYLINDER LINE
ARM(SHORT)
ARM(STANDARD)
ARM(SUPER SHORT)
BATTERY
BOLT
BOOM CYLINDER LINE
BOOM LINE
BOOM(BACK-HOE)
BUCKET & ARM LINE
BUCKET LINKAGE
BUCKET
BYPASS FILTER
CAB SIDE STEP
CENTER JOINT
CONSOLE BOX(100)
CONSOLE BOX(10)
CONSOLE BOX(0)
CONSOLE BOX
CONSOLE BOX(200)
CONTROL VALVE
CONTROLLER
COUNTER WEIGHT
DOG CHAIN
DRAIN LINE
ENGINE(ISUZU)
FLOOR MAT
FUEL FEED PUMP
FUEL LINE
FUEL TANK
GREASE LINE
HEATER
HORN(ELECTRIC)
HOUSE(104)
HOUSE(14)
HOUSE(4)
HOUSE
HYDRAULIC PUMP
JOYSTICK CONTROL
LOWER FRAME
LOWER ROLLER
LOWER UNDER COVER
LUBRICATION PUMP
MUFFLER(STANDARD)
NAME PLATE(ENGLISH)
NAME PLATE
OPE NAME PLATE
OPERATOR'S CAB
PAINTING(YELLOW)
PILOT CONTROL LINE
PLUG
PRESSURE LINE
RADIATOR(STANDARD)
REAR STAND
REAR VIEW MIRROR
RECOIL SPRING
REPAIR PARTS KIT
REVOLVING EQUIPMENT
REVOLVING FRAME
SEAT BELT
SERVICE VALVE
SPARE PARTS KIT
SUCTION LINE
SUMP TANK
SUNVISOR
SWING LINE
SYSTEM MONITOR
TAKE-UP ROLLER
TOOLS
TRACK GUARD(DOUBLE)
TRACTION EQUIPMENT
TRACTION LINE
TRACTION MOTOR LINE
TURN TABLE BEARING
UPPER ROLLER
UPPER UNDER COVER
WINDOW WASHER
WORKING LIGHT
- Sumitomo SH240-5 error code 7003 and 0335
- Need Part Book Sumitomo SH210-5
- Sumitomo SH125-3 SH135X-3 Service Manual
- Service manual for Sumitomo Sh700 excavator
- I need Sumitomo SH200 A-1 Service Manual
- Sumitomo SH 330- 350-5 Service Manual
- Sumitomo SH200-3G Shop Manual
- Sumitomo SH290 Shop Manual
- Sumıtomu SH200,220 -3 Shop Manual Diagram
- Sumitomo SH330-5,SH330LC-5,SH350HD-5,SH350LHD-5 Parts Manual
- Sumitomo Hydraulic Excavator SH210-5 Series Parts Manual _EN
- Sumitomo Hydraulic Excavator SH330-SH350HDLC-5 Shop Manual _EN
- Sumitomo SH290 Service Manual
- Sumitomo R450LC-7 Shop Manual
- Service text Sumitomo SH330/350-3B
