Darylxd
3
22,163
Nissan ROGUE X-Trail T33 2021-2024 Electrical Wiring Diagram
Brand: Nissan
Type of Machine: Automotive
Type of Manual: Electrical Wiring Diagram
Model:
2024 Nissan Datsun Truck Rogue 4WD L3-1.5L Turbo (KR15DDT)
2021-2024 nissan x-trail t-33 SNT33-001285
Electrical (OE) - Active Grille Shutter System (Cooling System) .pdf
Electrical (OE) - Automatic Air Conditioning System (Heating and Air Conditioning) .pdf
Electrical (OE) - Automatic Back Door System (Accessories and Optional Equipment) .pdf
Electrical (OE) - Automatic Drive Positioner System (Memory Positioning Systems) .pdf
Electrical (OE) - AWD System (Transfer Case) .pdf
Electrical (OE) - Back - Up Lamp - w Around View Monitor (Lighting and Horns) .pdf
Electrical (OE) - Back - up Lamp (Lighting and Horns) .pdf
Electrical (OE) - BCM (Body Control Module) (Body Control Systems) .pdf
Electrical (OE) - BCM (Body Control Module) (Powertrain Management) .pdf
Electrical (OE) - Brake Control System (Brakes and Traction Control) .pdf
Electrical (OE) - BRC Brake Control System - Automatic Emergency Braking System & Rear Automatic Braking System (Brakes and Traction Control) .pdf
Electrical (OE) - CAN Gateway System (Information Bus) .pdf
Electrical (OE) - CAN System ( w o Secured Gateway) (Information Bus) .pdf
Electrical (OE) - CAN System (w Secured Gateway) (Information Bus) .pdf
Electrical (OE) - Charging System - w Idle Stop Start System (Charging System) .pdf
Electrical (OE) - Charging System - w o Idle Stop Start System (Charging System) .pdf
Electrical (OE) - Chassis Control System (Collision Avoidance and Parking Assist Systems) .pdf
Electrical (OE) - Consult Checking System (Powertrain Management) .pdf
Electrical (OE) - CVT Control System - w KR15DDT (Continuously Variable Transmission Transaxle) .pdf
Electrical (OE) - Daytime Running Light System (Lighting and Horns) .pdf
Electrical (OE) - Door Mirror (Mirrors) .pdf
Electrical (OE) - Driver Assistance System (Collision Avoidance and Parking Assist Systems) .pdf
Electrical (OE) - Electric Parking Brake System (Parking Brake System) .pdf
Electrical (OE) - Electronically Controlled Power Steering System (Power Steering) .pdf
Electrical (OE) - Engine Control System - w KR15DDT (w Idle Stop Start System) (Powertrain Management) .pdf
Electrical (OE) - Front Wiper & Washer System (Wiper and Washer Systems) .pdf
Electrical (OE) - Head Up Display (Instrument Panel, Gauges and Warning Indicators) .pdf
Electrical (OE) - Headlamp - w Around View Monitor (Lighting and Horns) .pdf
Electrical (OE) - Headlamp (Lighting and Horns) .pdf
Electrical (OE) - Heated Seat System (Seats) .pdf
Electrical (OE) - Heated Steering Wheel (Steering Wheel) .pdf
Electrical (OE) - Horn (Lighting and Horns) .pdf
Electrical (OE) - Illumination (Lighting and Horns) .pdf
Electrical (OE) - Inside Mirror (Mirrors) .pdf
Electrical (OE) - Intelligent Around View Monitor System (Collision Avoidance and Parking Assist Systems) .pdf
Electrical (OE) - Intelligent Auto Light System - w Around View Monitor (Lighting and Horns) .pdf
Electrical (OE) - Intelligent Auto Light System (Lighting and Horns) .pdf
Electrical (OE) - Intelligent Key System (Keyless Entry) .pdf
Electrical (OE) - Intelligent Key System (Starting System) .pdf
Electrical (OE) - Intelligent Key System Engine Start Function (Starting System) .pdf
Electrical (OE) - Interior Room Lamp Control System (Lighting and Horns) .pdf
Electrical (OE) - Lumbar Support System (Seats) .pdf
Electrical (OE) - Manual Air Conditioning System (Heating and Air Conditioning) .pdf
Electrical (OE) - Meter (7 Inch Information Display Meter) (Instrument Panel, Gauges and Warning Indicators) .pdf
Electrical (OE) - Meter (Full TFT Meter) (Instrument Panel, Gauges and Warning Indicators) .pdf
Electrical (OE) - Moonroof System (Sunroof Moonroof) .pdf
Electrical (OE) - NissanConnect (w Bose) (Entertainment Systems) .pdf
Electrical (OE) - NissanConnect (w Bose) (Radio, Stereo, and Compact Disc) .pdf
Electrical (OE) - NissanConnect (w o Bose) (Entertainment Systems) .pdf
Electrical (OE) - NissanConnect (w o Bose) (Radio, Stereo, and Compact Disc) .pdf
Electrical (OE) - NVIS (Antitheft and Alarm Systems) .pdf
Electrical (OE) - Overall Circuit Diagram .pdf
Electrical (OE) - Overall Circuit Diagram image .pdf
Electrical (OE) - Parking, License Plate, Side Marker and Tail Lamp - w Around View Monitor (Lighting and Horns) .pdf
Electrical (OE) - Parking, License Plate, Side Marker and Tail Lamp (Lighting and Horns) .pdf
Electrical (OE) - Power Door Lock System (Keyless Entry) .pdf
Electrical (OE) - Power Door Lock System (Locks) .pdf
Electrical (OE) - Power Seat System for Driver Side - w o Automatic Drive Positioner (Seats) .pdf
Electrical (OE) - Power Seat System for Passenger Side (Seats) .pdf
Electrical (OE) - Power Window System (Windows) .pdf
Electrical (OE) - ProPILOT Assist (Cruise Control) .pdf
Electrical (OE) - Rear View Monitor System (Collision Avoidance and Parking Assist Systems) .pdf
Electrical (OE) - Rear Window Defogger (Heated Glass Element) .pdf
Electrical (OE) - Rear Wiper & Washer System (Wiper and Washer Systems) .pdf
Electrical (OE) - Seat Belt Warning System (Seat Belt Systems) .pdf
Electrical (OE) - Sonar System (Collision Avoidance and Parking Assist Systems) .pdf
Electrical (OE) - SRS Air Bag Control System (Air Bag Systems) .pdf
Electrical (OE) - Starting System (Starting System) .pdf
Electrical (OE) - Stop Lamp (Lighting and Horns) .pdf
Electrical (OE) - Telematics System (Accessories and Optional Equipment) .pdf
Electrical (OE) - Telematics System (Emergency Contact Module) .pdf
Electrical (OE) - Tire Pressure Monitoring System (Tire Monitoring System) .pdf
Electrical (OE) - TM Transaxle & Transmission - Electric Shift Control System (Continuously Variable Transmission Transaxle) .pdf
Electrical (OE) - Turn Signal and Hazard Warning Lamp (Lighting and Horns) .pdf
Electrical (OE) - Turn Signal and Hazard Warning Lamp w Around View Monitor (Lighting and Horns) .pdf
Electrical (OE) - Vehicle Security System (Antitheft and Alarm Systems) .pdf
Electrical (OE) - Warning Chime System (Instrument Panel, Gauges and Warning Indicators) .pdf
Electrical (OE) - Power and Ground Distribution - Accessory Power Supply - Accessory Power Supply Fuse NO. 40 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Accessory Power Supply - Accessory Power Supply Fuse NO. 44 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Accessory Power Supply (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Accessory Pre-Wire (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Battery Power Supply - Battery Power Supply - w KR15DDT (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Battery Power Supply - Battery Power Supply - w PR25DD (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Battery Power Supply - Battery Power Supply Fuse NO. 26 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Battery Power Supply - Battery Power Supply Fuse NO. 54 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ground - Battery Cable (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ground - Body Harness (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ground - Engine Control Harness w KR15DDT (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ground - Engine Control Harness w PR25DD (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ground - Engine Room Harness (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ground - Main Harness (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ignition Power Supply - Ignition Power Supply Fuse NO. 2 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ignition Power Supply - Ignition Power Supply Fuse NO. 24 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ignition Power Supply - Ignition Power Supply Fuse NO. 67 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ignition Power Supply - Ignition Power Supply Fuse NO. 73 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ignition Power Supply - Ignition Power Supply Fuse NO. 76 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ignition Power Supply - Ignition Power Supply Fuse NO. 79 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ignition Power Supply - Ignition Power Supply Fuse NO. 82 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ignition Power Supply - Ignition Power Supply Fuse NO. 9 (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Ignition Power Supply (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - IPDM E R (Intelligent Power Distribution Module Engine Room) (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Power Distribution System (Power and Ground Distribution) .pdf
Electrical (OE) - Power and Ground Distribution - Power Socket (Power and Ground Distribution) .pdf
Electrical - Interactive Color (Non OE) - Active Body Work (Body and Frame) .pdf
Electrical - Interactive Color (Non OE) - Air Conditioning - Automatic A C Circuit (Heating and Air Conditioning) .pdf
Electrical - Interactive Color (Non OE) - Air Conditioning - Manual A C Circuit (Heating and Air Conditioning) .pdf
Electrical - Interactive Color (Non OE) - Anti-Lock Brakes (Antilock Brakes Traction Control Systems) .pdf
Electrical - Interactive Color (Non OE) - Anti-Theft - Forced Entry Circuit (Antitheft and Alarm Systems) .pdf
Electrical - Interactive Color (Non OE) - Anti-Theft - Immobilizer Circuit (Antitheft and Alarm Systems) .pdf
Electrical - Interactive Color (Non OE) - Around Vision Camera Circuit (Collision Avoidance and Parking Assist Systems) .pdf
Electrical - Interactive Color (Non OE) - Body Computer (Body Control Module) .pdf
Electrical - Interactive Color (Non OE) - Computer Data Lines - W Secured Gateway (Information Bus) .pdf
Electrical - Interactive Color (Non OE) - Computer Data Lines - W O Secured Gateway (Information Bus) .pdf
Electrical - Interactive Color (Non OE) - Cooling Fans (Radiator Cooling Fan) .pdf
Electrical - Interactive Color (Non OE) - Cruise Control (Cruise Control) .pdf
Electrical - Interactive Color (Non OE) - Defogger (Rear Defogger) .pdf
Electrical - Interactive Color (Non OE) - Door Locks (Power Locks) .pdf
Electrical - Interactive Color (Non OE) - Driver Assistance System Circuit (Collision Avoidance and Parking Assist Systems) .pdf
Electrical - Interactive Color (Non OE) - Electronic Power Steering (Power Steering) .pdf
Electrical - Interactive Color (Non OE) - Electronic Suspension (Suspension Control ( Automatic - Electronic )) .pdf
Electrical - Interactive Color (Non OE) - Engine Controls (Powertrain Management) .pdf
Electrical - Interactive Color (Non OE) - Exterior Lights - Backup Lamps Circuit (Lighting and Horns) .pdf
Electrical - Interactive Color (Non OE) - Exterior Lights - Exterior Lamps Circuit (Lighting and Horns) .pdf
Electrical - Interactive Color (Non OE) - Ground Distribution (Power and Ground Distribution) .pdf
Electrical - Interactive Color (Non OE) - Headlights (Headlamp) .pdf
Electrical - Interactive Color (Non OE) - Heated Steering Wheel Circuit (Steering Wheel) .pdf
Electrical - Interactive Color (Non OE) - Horns (Horn) .pdf
Electrical - Interactive Color (Non OE) - Instrument Cluster - Head-Up Display Circuit (Instrument Panel, Gauges and Warning Indicators) .pdf
Electrical - Interactive Color (Non OE) - Instrument Cluster - Instrument Cluster Circuit (Instrument Panel, Gauges and Warning Indicators) .pdf
Electrical - Interactive Color (Non OE) - Interior Lights - Courtesy Lamps Circuit (Lighting and Horns) .pdf
Electrical - Interactive Color (Non OE) - Interior Lights - Instrument Illumination Circuit (Lighting and Horns) .pdf
Electrical - Interactive Color (Non OE) - Memory Systems - Memory Mirrors Circuit (Memory Positioning Systems) .pdf
Electrical - Interactive Color (Non OE) - Memory Systems - Memory Seat Circuit (Memory Positioning Systems) .pdf
Electrical - Interactive Color (Non OE) - Mirrors - Auto Anti-dazzling Inside Mirror Circuit (Mirrors) .pdf
Electrical - Interactive Color (Non OE) - Mirrors - Power Mirrors Circuit (Mirrors) .pdf
Electrical - Interactive Color (Non OE) - Navigation - Navigation Circuit (W Bose) (Navigation System) .pdf
Electrical - Interactive Color (Non OE) - Navigation - Navigation Circuit (W O Bose) (Navigation System) .pdf
Electrical - Interactive Color (Non OE) - Navigation - Telematics Circuit (Navigation System) .pdf
Electrical - Interactive Color (Non OE) - Park Brake Release Circuit (Parking Brake System) .pdf
Electrical - Interactive Color (Non OE) - Power Distribution (Power and Ground Distribution) .pdf
Electrical - Interactive Color (Non OE) - Power Tops (Sunroof Moonroof) .pdf
Electrical - Interactive Color (Non OE) - Power Windows (Windows) .pdf
Electrical - Interactive Color (Non OE) - Seats - Heated Seats Circuit (Seats) .pdf
Electrical - Interactive Color (Non OE) - Seats - Lumbar Circuit (Seats) .pdf
Electrical - Interactive Color (Non OE) - Seats - Power Seat Circuit (Seats) .pdf
Electrical - Interactive Color (Non OE) - Shift Interlock - Shift Interlock Circuit (Transmission and Drivetrain) .pdf
Electrical - Interactive Color (Non OE) - Sonar Circuit (Collision Avoidance and Parking Assist Systems) .pdf
Electrical - Interactive Color (Non OE) - Sound Systems - W Bose (Radio, Stereo, and Compact Disc) .pdf
Electrical - Interactive Color (Non OE) - Sound Systems - W O Bose (Radio, Stereo, and Compact Disc) .pdf
Electrical - Interactive Color (Non OE) - Starting Charging - Charging Circuit (Starting and Charging) .pdf
Electrical - Interactive Color (Non OE) - Starting Charging - Starting Circuit (Starting and Charging) .pdf
Electrical - Interactive Color (Non OE) - Supplemental Restraints (Restraints and Safety Systems) .pdf
Electrical - Interactive Color (Non OE) - Tire Pressure Monitoring Circuit (Tire Monitoring System) .pdf
Electrical - Interactive Color (Non OE) - Transmissions - 4WD Circuit (Transmission and Drivetrain) .pdf
Electrical - Interactive Color (Non OE) - Transmissions - A T Circuit (Transmission and Drivetrain) .pdf
Electrical - Interactive Color (Non OE) - Trunk, Tailgate, Fuel Doors - Back Door Opener Circuit (W Automatic Back Door System) (Doors, Hood and Trunk) .pdf
Electrical - Interactive Color (Non OE) - Trunk, Tailgate, Fuel Doors - Back Door Opener Circuit (W O Automatic Back Door System) (Doors, Hood and Trunk) .pdf
Electrical - Interactive Color (Non OE) - Warning Systems - Chime Circuit (Instrument Panel, Gauges and Warning Indicators) .pdf
Electrical - Interactive Color (Non OE) - Wiper Washer - Front Wiper Washer Circuit (Wiper and Washer Systems) .pdf
Electrical - Interactive Color (Non OE) - Wiper Washer - Rear Wiper Washer Circuit (Wiper and Washer Systems) .pdf
Fuse - Fuse and Fusible Link Box 1 - Fuse, Fusible Link, Relay Box and Terminal Arrangement .pdf
Fuse - Fuse and Fusible Link Box 2 - Fuse, Fusible Link, Relay Box and Terminal Arrangement .pdf
Fuse - Fuse and Fusible Link Box 4 - Fuse, Fusible Link, Relay Box and Terminal Arrangement .pdf
Fuse - Fuse and Fusible Link Box 5 - Fuse, Fusible Link, Relay Box and Terminal Arrangement .pdf
Fuse - Fuse and Fusible Link Box 6 - Fuse, Fusible Link, Relay Box and Terminal Arrangement .pdf
Fuse - Fuse, Connector and Terminal Arrangement (Intelligent Power Distribution Module Engine Room) .pdf
Fuse - Fuse, Fusible Link, Relay Box and Terminal Arrangement (Battery) .pdf
Fuse - Fuse, Fusible Link, Relay Box and Terminal Arrangement .pdf
Fuse - Fuse, Relay, Connector and Terminal Arrangement (Fuse Block (J B)) .pdf
