New Holland Loader L213 L216 Tier 4B Service Manual 47720732
Brand: New Holland
Type of Machine: Skid Steer Loader
Model: New Holland L213, L216 Tier 4B Skid Steer Loader
Part Number: 47720732
Number of Pages: 349 Pages
Electrical Systems
Harnesses And Connectors
Technical Data
Fuse And Relay Box
General Specification Relay And Fuse Identification - Small Mechanical Machines (*)
Functional Data
Wire Harnesses
Electrical Schematic Sheet 01 Power Distribution - Mechanical Units (*)
Electrical Schematic Sheet 02 Ignition/ Charging System - Mechanical Units (*)
Electrical Schematic Sheet 03 Main Power Distribution Fuse Relay Box #1 - Mechanical Units (*)
Electrical Schematic Sheet 04 Main Power Distribution Fuse Relay Box #1 - Mechanical Units (*)
Electrical Schematic Sheet 05 Main Power Distribution Fuse Relay Box #2 - Mechanical Units (*)
Electrical Schematic Sheet 06 Main Power Distribution Fuse Relay Box #2 - Mechanical Units (*)
Electrical Schematic Sheet 07 Grounding System - Mechanical Units (*)
Electrical Schematic Sheet 08 Engine Ism Idi - Mechanical Units (*)
Electrical Schematic Sheet 09 Engine Ism Idi - Mechanical Units (*)
Electrical Schematic Sheet 10 Engine Ism Idi - Mechanical Units (*)
Electrical Schematic Sheet 11 Throttle Sensors - Mechanical Units (*)
Electrical Schematic Sheet 12 Auxiliary Hydraulic Interlock Switch- Mechanical Units (*)
Electrical Schematic Sheet 13 Bulkhead Connection - Mechanical Units (*)
Electrical Schematic Sheet 14 Bulkhead Connection - Mechanical Units (*)
Electrical Schematic Sheet 15 Left Hand Cab Console - Mechanical Units (*)
Electrical Schematic Sheet 16 Left Hand Control Handle - Mechanical Units (*)
Electrical Schematic Sheet 17 Right Hand Control Handle - Mechanical Units (*)
Electrical Schematic Sheet 18 Seat - Mechanical Units (*)
Electrical Schematic Sheet 19 Eh Aux Pwm (*)
Electrical Schematic Sheet 20 Lamps - Mechanical Units (*)
Electrical Schematic Sheet 21 Indicators - Mechanical Units (*)
Electrical Schematic Sheet 23 Boom And Road Lights - Mechanical Units (*)
Electrical Schematic Sheet 24 Wipers/ Washers - Mechanical Units (*)
Electrical Schematic Sheet 25 Instrument Cluster - Mechanical Units (*)
Electrical Schematic Sheet 26 Hvac - Mechanical Units (*)
Electrical Schematic Sheet 27 Radio - Mechanical Units (*)
Electrical Schematic Sheet 28 Multifunction Connectors - Mechanical Units (*)
Electrical Schematic Sheet 29 Telematics - Mechanical Units (*)
Electrical Schematic Sheet 30 Multifunction Jumper - Mechanical Units (*)
Electrical Schematic Sheet 31 Diagnostic Connector - Mechanical Units (*)
Electrical Schematic Sheet 01 Main Power Distribution - Eh Units (*)
Electrical Schematic Sheet 02 Accessory Power Distribution - Eh Units (*)
Electrical Schematic Sheet 03 Ignition/ Charging System - Eh Units (*)
Electrical Schematic Sheet 04 Grounding System - Eh Units (*)
Electrical Schematic Sheet 05 Engine Ism - Eh Units (*)
Electrical Schematic Sheet 06 Engine Ism - Eh Units (*)
Electrical Schematic Sheet 07 Engine Ism - Eh Units (*)
Electrical Schematic Sheet 08 Throttle Sensors - Eh Units (*)
Electrical Schematic Sheet 09 Et Pump/ Hydraulics - Eh Units (*)
Electrical Schematic Sheet 10 Hydraulic Interlocks - Eh Units (*)
Electrical Schematic Sheet 11 Loader Valve And Sensors - Eh Units (*)
Electrical Schematic Sheet 12 Bulkhead Connection - Eh Units (*)
Electrical Schematic Sheet 13 Bulkhead Connection - Eh Units (*)
Electrical Schematic Sheet 14 Bulkhead Connection - Eh Units (*)
Electrical Schematic Sheet 15 Left Hand Cab Console - Eh Units (*)
Electrical Schematic Sheet 16 Left Hand Control Handle - Eh Units (*)
Electrical Schematic Sheet 17 Right Hand Control Handle - Eh Units (*)
Electrical Schematic Sheet 18 Right Hand Control Handle - Eh Units (*)
Electrical Schematic Sheet 19 Unit Control Handle - Eh Units (*)
Electrical Schematic Sheet 20 Unit Control Module - Eh Units (*)
Electrical Schematic Sheet 21 Lamps - Eh Units (*)
Electrical Schematic Sheet 22 Indicators - Eh Units (*)
Electrical Schematic Sheet 24 Boom Road Lights - Eh Units (*)
Electrical Schematic Sheet 25 Wipers/ Washers - Eh Units (*)
Electrical Schematic Sheet 26 Instrument Cluster - Eh Units (*)
Electrical Schematic Sheet 27 Hvac - Eh Units (*)
Electrical Schematic Sheet 28 Radio - Eh Units (*)
Electrical Schematic Sheet 29 Multifunction On/ Off - Eh Units (*)
Electrical Schematic Sheet 30 Multifunction Connectors - Eh Units (*)
Electrical Schematic Sheet 31 Telematics - Eh Units (*)
Electrical Schematic Sheet 32 Multifunction Jumper - Eh Units (*)
Electrical Schematic Sheet 33 Diagnostic Connector - Eh Units (*)
Wire Connectors
Component Diagram 00 (*)
Component Diagram 01 (*)
Component Diagram 02 (*)
Component Diagram 03 (*)
Component Diagram 05 (*)
Component Diagram 07 (*)
Component Diagram 09 (*)
Component Diagram 10 (*)
Component Diagram 11 (*)
Component Diagram 12 (*)
Component Diagram 15 (*)
Component Diagram 17 (*)
Component Diagram 20 (*)
Component Diagram 23 (*)
Component Diagram 25 (*)
Component Diagram 27 (*)
Component Diagram 29 (*)
Component Diagram 30 (*)
Component Diagram 31 (*)
Component Diagram 32 (*)
Component Diagram 33 (*)
Component Diagram 36 (*)
Component Diagram 40 (*)
Component Diagram 41 (*)
Component Diagram 50 (*)
Component Diagram 52 (*)
Component Diagram 90 (*)
Component Diagram 04 (*)
Component Diagram 16 (*)
Component Diagram 43 (*)
Component Diagram 00 – Connectors B – T (*)
Component Diagram 01 – Ucm Connectors Cn1 – Cn4 (*)
Component Diagram 02 – Chassis/Cab Interface Connectors Ecc1 – Ecc7 (*)
Component Diagram 03 – Fuse Power Distribution (*)
Component Diagram 02 – Chassis/Cab Interface Connectors Cnn1 – Co2 (*)
Component Diagram 04 – Connectors C – U (*)
Fuse And Relay Box
Relay - Overview (*)
Fuse - Overview (*)
Component Localisation (*)
Service
Wire Harnesses
Repair (*)
Replace (*)
