705,578
Mahindra Tractor 3600 Series HST Cabin 3640P 3650P mCRD Operator Manual
Brand: Mahindra
Model:
Mahindra 3600 Series HST Cabin 3640P mCRD Tractor TIER-4 FINAL
Mahindra 3600 Series HST Cabin 3650P mCRD Tractor TIER-4 FINAL
Number Of Pages: 126 Pages
Emission Control Warranty for California
Emission Control Warranty for Federal
About this manual
Introduction
General Description
Owner Assistance
Owner’s Personal Data
Safety Instructions
Safety Signs
Universal Symbols
LH & RH View of Engine
Lamps
Controls, Instruments & Operations
Instrument Cluster
Self Test Function of Instrument Cluster
Forward/Reverse & PTO Neutral Indicator
Engine RPM Meter
LCD of Instrument Cluster
Hour Counter
Trip Hour Meter
Next Service / Service Reminder Indicator
Clock
Fuel Gauge
Coolant Temperature Gauge
High Temperature Warning Indicator
Turn Indicators
High Beam Indicator
Heater Indicator
Parking Brake Indicator
4WD Indicator
Battery Charging Indicator
Low Oil Pressure Indicator
Water in Fuel Indicator
Air Filter Clog Indicator
CHK ENG (Check Engine) Indicator
MIL (Malfunction) Indicator
Switches
Hazard Switch
Combination Switch
Horn
Light Switch
Turn Signal Switch
Starter Key Switch
Key Pad Switch
PTO Operation Switches
PTO ON/OFF Switch
PTO Auto / Manual / Off Switch
Power Take Off
Controls
Operator Seat
Adjusting Seat Position
Height & Weight Adjustment
Using Seat belt
Release Seat belt
Slow Fast Valve Control Knob
Hand Throttle Operation
Increasing Engine Speed
Engine Tachometer Speed
Decreasing Engine Speed
Constant Speed Setting
Forward-Reverse Operation
Tilt Steering
Tilt Adjustment
4WD Engagement Lever
Brake
Differential Lock Pedal
Range Shift Lever
Cruise Control Lever
Hydraulic Remote (Auxiliary Valve) Operation
Loader
Opening the Hood
Closing the Hood
Removing the Side Panels
Assembling the Side Panels
Air Cleaner Clog Indicator
Keys
Opening Doors from Outside
Opening Doors from Inside
Rear View Mirrors
Rear Window
Windshield Wiper/Washer System Controls
Adding Suitable Anti-freeze Solution to
Water in Reservoir
Heater and Air Conditioning Controls
Blower Speed Control Regulator
Heater Regulator
Cooling Regulator
AC ON/OFF Switch
Fresh/Recirculation Air Selector Switch
Cab Worklight Switches
Cabin Lamp / Dome Lamp
Power Socket Unit
Cigarette Lighter
3 - Terminal Power Socket
Optional Power Socket
Ashtray
Can Holder cum Glove Box
Coat Hook
Sun-visor
Audio System
Hydraulic System & Operation
Position Control-Operation
Quadrant Assembly
Position Control
Setting of Position Control
Draft Control - Operation
Draft Control
Setting the Draft Control
Three Point Linkage
Top Link
Draft Sensing Bracket
Telescopic Lower Links
Adjustable Lift Rod RH
Lateral Stabilizers
Fixed Lift Rod LH
Drawbar
Attaching PTO Driven Implement
Drawbar
Seven-Terminal Trailer Socket
Wheel Tread Adjustment
Pneumatic Tires
Adding Liquid Weight
Inflation
Care of Tires
Shipping Tractors Equipped with Pneumatic Tires
Tire Protection during Storage
Mounting Tires on the Rim
Operating Instructions
Before Starting The Tractor
Starting the Tractor
Stopping the Engine
Cold Starting Aid
Driving the Tractor
Tractor Storage
Using The Tractor After Storage
Precautions
Operating the Tractor
The Tractor
Driving the Tractor
Servicing the Tractor
Operating the PTO (Power Take Off)
Transporting Tractor on a Trailer
Towing
Diesel Fuel
Do’s & Dont’s
Maintenance
Radiator Cap
Surge Tank
Thermostat
Hose Connections
Fan & Fan Belts
Draining the System
Cleaning out Dirt and Sludge
Adding Coolant to the System
Cooling System Protection
Trashguard
Adjusting The Valve Clearance
Air Intake System
Air Cleaner
Body Air-Cleaner
Cyclopack or built-in Pre-Cleaner
Paper Element Filter
Safety Cartridge
Dust Collector Bowl
Hose and Clamps
Emission Control System
Positive Crankcase Ventilation (PCV) System
Exhaust Gas Recirculation (EGR) System
Diesel Oxidation Catalyst (DOC)
Under-Hood Muffler (UHM)
Fuel System
Clean Diesel Fuel
Bleeding the Fuel Filter
Bleeding the Fuel Injection Pump
Fuel Tank and Fuel Pipes
Servicing the Fuel Filter
Lubrication System
Oil Level Check
Oil Change
Engine Oil Filter
Changing Spin On Filter
Battery Maintenance Cleaning
Servicing
Effect of Low Temperatures
Charging Circuit
Starter Motor Removal
Air Conditioning System (Cabin)
Cab Air Conditioning System Safety
Switching ON the Air Conditioning
Adjustment
Switching OFF the Air Conditioning System
Tips on using Air Conditioning
Maintaining the Air Conditioning System
Heating Mode
Cleaning of Condenser & Wiremesh
Clean the Cab Air Filters (Cabin)
Hydraulics & Transmission
Adding Hydraulic & Transmission Oil
Front Axle
Hydraulic & Transmission Suction Oil Filter
Hydraulic & Transmission Strainer
Transmission Oil Drain
Hydrostatic Transmission (HST) Oil Filter
Transmission Oil Cooler
Toe-in Setting
Front Axle - Front Wheel “Toe-in” Check
Brake Pedal Free Play
Head Lamp Adjustment
Lubricants
General
Lubricant Storage
Alternate and Synthetic Lubricants
Diesel Engine Lubricating Oil
Mixing of lubricants
Engine Oil
Transmission, Hydraulics &
Oil Immersed Brakes
Chassis Lubricant (CL)
Front Axle
Oil Specifications Chart
Special Bolt Torques
Specifications - 3640P HST
Specifications - 3650P HST
Trouble Shooting
Hydraulics
Brakes
Electricals
Power Steering
Tractor History Card
Service Record
Part Replacement Record
Daily Operating Log
Tractor Storage Precautions
Lubrication & Greasing Chart
Routine Service Schedule
Electrical Circuit Layout
