Liebherr Mobile Crane LTM 1250-1-01 Z70507 Spare Parts Catalog
Brand: Liebherr
Type of Machine: Mobile Crane
Model: Liebherr LTM 1250-1-01 - Z70507 Mobile Crane
Date: 2002
Serial: 070 507
Number of Pages: 3906 Pages
Manual Preview & Document Quality:
Brand: Liebherr
Date: 2002
Serial: 070 507
DIESEL ENGINE W.RADIATOR (1/3)
DIESEL ENGINE W.RADIATOR (2/3)
DIESEL ENGINE W.RADIATOR (3/3)
STEERING HYDRAULICS (2/3)
STEERING HYDRAULICS (3/3)
ADDITIONAL HEATING
EXHAUST TAIL PIPE
EXHAUST SYSTEM
AIR FILTER UNIT
TIRE COVER PANELLING (2/2)
UNDERCARRIAGE ELEC. SYSTEM
COMPRESSED AIR PLANT (2/8)
COMPRESSED AIR PLANT (3/8)
COMPRESSED AIR PLANT (4/8)
COMPRESSED AIR PLANT (5/8)
COMPRESSED AIR PLANT (6/8)
COMPRESSED AIR PLANT (7/8)
COMPRESSED AIR PLANT (8/8)
HYDRAULIC SUPPORT (2/4)
HYDRAULIC SUPPORT (3/4)
HYDRAULIC SUPPORT (4/4)
HYDRAULIC AXLE SUSPENSION (2/3)
HYDRAULIC AXLE SUSPENSION (3/3)
PIPELINES UNDERCARRIAGE
ASSEMBLY PARTS F.SLEWING PLTF. (1/2)
ASSEMBLY PARTS F.SLEWING PLTF. (2/2)
DRIVE ASSEMBLY CPL. (2/2)
CRANE DRIVER'S CABIN CPL. (2/2)
POUCH SOCKET [SPF]
CONTROL STAND
ADDITIONAL BALLAST
BALLASTING
HYDRAULICS (2/5)
HYDRAULICS (3/5)
HYDRAULICS (4/5)
HYDRAULICS (5/5)
PIPELINES SUPERSTRUCTURE
2nd NECK PULLEY INSTALLATION
ADDITIONAL HEATING (2/2)
PUMP HOISTING GEAR 2
EL.2 HOISTING LIMIT SWITCH
EMERGENCY OPERATION CRANE HYDR (1/3)
EMERGENCY OPERATION CRANE HYDR (2/3)
EMERGENCY OPERATION CRANE HYDR (3/3)
ASSEMBLY UNIT (2/2)
N HEAD SECTION (2/2)
NI REDUCING SECTION
LUFFING PULLEY BLOCK (1/2)
LUFFING PULLEY BLOCK (2/2)
DIESEL ENGINE, PRE-ASSEMBLED (1/2)
DIESEL ENGINE, PRE-ASSEMBLED (2/2)
RADIATOR, PRE-ASSEMBLED (1/2)
RADIATOR, PRE-ASSEMBLED (2/2)
HEAT EXCHANGER, PRE-ASSEMBLED
MULTI-FLOW PUMP PRE-ASS.
HYDR. COOLER DRIVE
TRANSMISSION INSTALLATIONTRANSFER CASE, PRE-ASSEMBLED
AXLE 1+2 WITH SUSPENSIONAXLE 1, PRE-ASSEMBLED
AXLE 2, PRE-ASSEMBLED
SUSPENSION CYLINDER [SPF]
AXLES 3+4 WITH SUSPENSIONAXLE 3, PRE-ASSEMBLED
AXLE 4, PRE-ASSEMBLED
AXLES 5+6 WITH SUSPENSIONAXLE 5, PRE-ASSEMBLED
AXLE 6, PRE-ASSEMBLED
TYRES 16.00 R25TIRE CPL.16.00 R25
TIRE CPL.16.00 R25TYRE
DISC WHEEL [SPF]
METAL VALVE
STEERING MECHANISMSTEERING LEVER, PRE-ASSEMBLED
STEERING ROD
STEERING WHEEL LOCK [SPF]
STEERING HYDRAULICS (1/3)STEERING HYDRAULICS (2/3)
VALVE PLATE, PRE-ASSEMBLED
FLOW CONTROL VALVE
STEERING BLOCK
DIRECTIONAL CONTROL VALVE
DRIVE SHAFT FITTINGADDITIONAL HEATING
ADDNL.HEATING, PRE-ASSEMBLED
DOSING PUMP
FIXING PARTS SLEWING RINGSPECIAL GREASE
SLIDING BEAM WITH BEARINGSLIDING BEAM FRONT,PRE-ASSEMB (1/2)
SLIDING BEAM FRONT,PRE-ASSEMB (2/2)
SLIDING BEAM REAR, PRE-ASSEMBL (1/2)
SLIDING BEAM REAR, PRE-ASSEMBL (2/2)
CABLE TENSIONER CPL.
WHEEL CHOCKS WITH HOLDERMOUNTING PARTS
SUPPORT PLATES W.FAST.ADD-ONBRACE PLATE
BOOM JIB SUPPORT CPL.BOOM JIB SUPPORT BLOCK PRE-ASS
TOOL BOX ADD-ONTOOL BOX, PRE-ASSEMBLED
STORAGE BOXSTORAGE BOX
FUEL TANK ADD-ON UNITFUEL TANK, PRE-ASSEMBLED
MOTOR PUMP PRE-ASS.
OIL TANK ASSEMBLAGEOIL TANK PRE-ASS.
AIR VESSEL MOUNTINGEXHAUST TAIL PIPE
EXHAUST SYSTEM
AIR FILTER UNIT
AIR FILTER
SENSOR COMPL.
MANEUVERING COUPLING IN FRONTMANEUVERING COUPLING
TOOLS AND ACCESSORIESMAIN TOOLS
ACCESSORIES
DISPATCH ASSY.MECH.PARTSHOSE GUIDE PRE-ASS.
DRIVER'S CABIN CPLDRIVER'S CABIN PRE-ASS.
BUMPER CPL.
TACHOGRAPHTACHOGRAPH
DRIVER'S CABIN CONTROLSINSTRUMENT WIRING
DASHBOARD CENTER CONSOLE PRE-A
CENTRE BRACKET PRE-ASS.
BATTERY BOX, PRE-ASSEMBLED
KEYBOARD UNIT [SPF]
ACCELERATOR PEDAL SENSOR [SPF]
CHARGERPOWER SUPPLY
CHARGER [SPF]
TIRE COVER PANELLING (1/2)TIRE COVER PANELLING (2/2)
FOLDING LADDER [SPF]
ENGINE COWLING CPL.COVERING PANEL
COVER PLATE LEFT PRE-ASS.
COVER/LID/CAP, PRE-ASSEMBLED
COVER PRE-ASSEMBLED REAR
ENGINE COVERING
PLATING GERMANUNDERCARRIAGE ELEC. SYSTEM
CABLE LIST ELECTRICAL SYSTEM
ELECTRIC INCLINATION
DOUBLE HORN
BATTERY MAIN SWITCH
COLLECTING RINGSLIP RING CONNECTOR PRE-ASSEM.
LIGHTING GERMANWIRING LIST FOR LIGHTING
LAMP CLAMP CPL.REAR LEFT
LAMP CLAMP CPL.REAR RIGHT
BUMPER COMPLETE
SIDE MARKING LAMP
EL.COMP. DISPATCH ASSEMBLYROTATING BEACON
COMPRESSED AIR PLANT (1/8)COMPRESSED AIR PLANT (2/8)
AIR DRYER
RELAY VALVE
LINE FILTER
PRESSURE LIMITING VALVE
SOLENOID VALVE
SOLENOID VALVE [SPF]
FITTING
HYDRAULIC SUPPORT (1/4)HYDRAULIC SUPPORT (2/4)
SLIDE VALVE BLOCK
HYDRAULIC AXLE SUSPENSION (1/3)HYDRAULIC AXLE SUSPENSION (2/3)
CONTROL BLOCK
AXLE LOCKING VALVE
BLADDER ACCUMULATOR
DIAPHRAGM ACCUMULATOR
PRESSURE GAUGE CONNECTION
EL.OPERATION OF HYDR. VALVESSWITCH BOX CPL.
HOSE LINES UNDERCARRIAGEPIPELINES UNDERCARRIAGE
BEAM
DRIVE ASSEMBLY CPL. (1/2)DRIVE ASSEMBLY CPL. (2/2)
DRIVE ASSEMBLY, PRE-ASSEMBLED (1/3)
DRIVE ASSEMBLY, PRE-ASSEMBLED (2/3)
DRIVE ASSEMBLY, PRE-ASSEMBLED (3/3)
EXPANSION TANK PRE-ASS.
BATTERY STORAGEELECTRIC FOR BATTERY BOX
OIL RESERVOIR, COMPLETEPILLOW BLOCK PRE-ASS.
LUFFING RAM W. PIVOTLUFFING CYLINDER [SPF]
ROLLER SLEWING RINGROLLER SLEWING RING
SLEWING GEARSLEWING GEAR DRIVE [SPF]
HYDRO MOTOR [SPF]
ANGLE THREADED BULKHEADHYDRO CYLINDER [SPF]
POINTER COMPL.
MAIN HOIST GEARCOMPACT ROPE WINCH [SPF]
VARIABLE DISPLACEMENT MOTOR [SPF]
ELECTRIC FOR WINCH 1
CRANE DRIVER'S CABIN CPL. (1/2)CRANE DRIVER'S CABIN CPL. (2/2)
CRANE DRIVER'S CABIN,PRE-ASSY. (1/2)
CRANE DRIVER'S CABIN,PRE-ASSY. (2/2)
HYDRO CYLINDER
ROPE WITH ACCESSORIES 1POUCH SOCKET [SPF]
REPAIR KIT
ERECTING WINCHAUXILIARY WINCH [SPF]
CONSOLE PRE-ASS.
ADDNL. HYDR. F. ERECTING WINCH
ROPE WITH ACCESSORIESCONTROL STAND
OPERATOR SEAT
TURNTABLE PANELLINGSLEWING PLATFORM PANELLING RIG (1/2)
SLEWING PLATFORM PANELLING RIG (2/2)
SLEWING PLATFORM PANELLING LEF (1/2)
SLEWING PLATFORM PANELLING LEF (2/2)
CRANE OPERATOR CAB INSTRUMENTSDASHBOARD FRONT, PRE-ASSEMBLED
LICCON CONSOLE LCD1
EL.INSTRUMENTS F.CRANE DRIV.CADASHBOARD ROOF, PRE-ASSEMBLED
CABLE LIST DRIVER'S CABIN
ELECTRIC ADD-ON PARTS CABIN
ELECTR. FOR CONTROL STANDELECTRIC FOR ARMREST LEFT
ELECTRIC FOR ARMREST RIGHT
COUNTERWEIGHT WITH CLAMPADDITIONAL BALLAST
BALLASTING
BALLAST EXTENSION RAM [SPF]
CENTRAL LUBRICATING SYSTEMELECTRIC PUMP
DISTRIBUTION BLOCK
PASSAGE NIPPLE BLOCK
ELECTR. SYSTEM F.SLEWING PLATFEL.ADD-ON SET-LIMIT SWITCHES +
AUXILIA.SONIC ALARM DEVICE SLI
ELECTR.FOR SLEWING GEAR
ELECTR. FOR WORK AREA LIGHT
FOOT SWITCH CPL.
COMPLEMENT ELECTR., CAB
SWITCHBOX MOUNTING PARTSBASIC WIRING 2 (1/2)
BASIC WIRING 2 (2/2)
SWING FRAME RELAY CONTROL SYST
COMPRESSED-AIR SYST.SUPERSTR.MECHANICAL AUXILIARIES
HYDRAULICS (1/5)HYDRAULICS (2/5)
HYDRAULICS (3/5)
HYDRAULICS (4/5)
HYDRAULICS (5/5)
DIRECTIONAL SEAT VALVE
CONTROL BLOCK [SPF]
LOWERING BRAKE VALVE [SPF]
FILTER
PRESSURE FILTER
PRESSURE LIMITING VALVE [SPF]
DIAPHRAGM ACCUMULATOR [SPF]
PRESSURE CONTROL VALVE
BALL VALVE COMBINATION
BALL VALVE
COUPLING SLEEVE
SAE FLANGE CONNECTION
PRESSURE TRANSDUCER LUFFING CY
PRESSURE TRANSMITTER ASSEMBLY
OIL COOLER CPL.OIL COOLER, PRE-ASSEMBLED
HOSE LINES SUPERSTRUCTUREPIPELINES SUPERSTRUCTURE
ROPE CLAMP
TELESCOPIC BOOM CPL.PIVOT SECTION, PRE-ASSEMBLED (1/2)
PIVOT SECTION, PRE-ASSEMBLED (2/2)
TELESCOPIC SECTION 1 PRE-ASSEM (1/2)
TELESCOPIC SECTION 1 PRE-ASSEM (2/2)
TELESCOPIC SECT.2 PRE-ASSEMBL (1/2)
TELESCOPIC SECT.2 PRE-ASSEMBL (2/2)
TELESCOPIC SECT.3 PRE-ASSEMB (1/2)
TELESCOPIC SECT.3 PRE-ASSEMB (2/2)
TELESCOPIC SECT.IV PRE-ASSEMBL (1/2)
TELESCOPIC SECT.IV PRE-ASSEMBL (2/2)
TELESCOPIC SECT.5 PRE-ASSEMBLE (1/2)
TELESCOPIC SECT.5 PRE-ASSEMBLE (2/2)
MECHANICAL EXTENSION SYSTEM
SENSOR ASSEMBLY BASIC BOOM
SENSOR ASSEMBLY HEAD PIECE
ELECTR. SYSTEM F. BOOMELECTRIC F.BASE SECTION
ELECTR. FOR HEAD SECTION
ELECTR. F.EXTENDING MECHANISM
ELECTRIC WIND WARNING TELE
CLAMP WIND WARNING UNIT
HYDR.F.TELESCOPIC BOOM2nd NECK PULLEY INSTALLATION
ROPE PULLEY CPL.
ADDITIONAL HEATING (1/2)ADDITIONAL HEATING (2/2)
HEATER UNIT [SPF]
CABLE HARNESS
REBUILDING SET MAGNET VALVE
A-HEADL.SEARCHLIGHT PIVOT SEC.TERMINAL BOX
MECH.AUXILIARIES FOR LIGHTING
LEAD
EL. FLASHING LIGHT TELEELECTRIC AIRCRAFT PROTECTION
AIR COND. UNIT SUPERSTRUCTURECONSTR.KIT COMPR.AIR CONDIT.
AIR COND. EVAPORATOR RFK
ELECTR. FOR AIR-CONDITIONING
FILLER NECK CONNECTION
HOOK BLOCK [SPF]ROPE PULLEY CPL. [SPF]
ROPE GUARD CPL
AUXILIARY HOIST.ROPE W.ACCESSOPUMP HOISTING GEAR 2
VARIABLE PUMP [SPF]
AUXILIARY HOISTING GEAR 2WINCH 2 PRE-ASS.
HYDR.AUXILIARY HOISTINGEXPANSION TANK CPL.
COUPLING PLUG
PRESS.TRANS. AUX. HOIST GEAR
PROX. SWITCH COMPL. WINCH 2
HOSE LINES HOISTING GEAR
PIPELINES HOISTING GEAR 2
EQUIPMENT BOX COMPL.EL.2 HOISTING LIMIT SWITCH
LIMIT SWITCH HOISTING ABOVE
FIXING DEVICE 2.LIFT TOP
ADD-ON PARTS
EMERGENCY OPERATION CRANE HYDRHOSE LINES EMERGENCY CONTROL
QUTSIDE POWER SUPP.EQUIPT.EMERGENCY OPERATION CRANE HYDR (1/3)
BALL VALVE STRIP
BRAKE VALVE
PRESSURE RELIEF VALVE [SPF]
PIPELINES EMERGENCY CONTROL
ADD-ON UNIT TELMAEDDY CURRENT BRAKE
ELECTRIC F. EDDY-CURRENT BRAKEWIRING LIST EDDY CURRENT BRAKE
CONTROL GEAR [SPF]
ASSEMBLY UNIT (1/2)ASSEMBLY UNIT (2/2)
N PIVOT SECTION (1/2)
N PIVOT SECTION (2/2)
TN ADAPTER
NA FRAME 1
NA FRAME 2 (1/2)
NA FRAME 2 (2/2)
N OVERRUN PROTECTION
ELECTRICS TENSION DYNAMOMETER
ROD
ROD CPL.
TF ADAPTER CPL.TF ADAPTER PRE-ASS.
TF BASE SECTION PRE-ASS.
TENSION PLATE PRE-ASS.
N HEAD SECTION (1/2)N HEAD SECTION (2/2)
ELECTR. FOR N-HEAD SECTION
NA INTERMEDIATE SECTIONPIN COMPL.
NI INTERMEDIATE SECTIONNI REDUCING SECTION
LOWER BLOCK PRE-ASS. (1/2)
LOWER BLOCK PRE-ASS. (2/2)
UPPER PULLEY BLOCK CPL.
CROSS SHACKLE CPL.
BASKET CPL.
ADD. HYDRAULICS TN BLOCK
RODS FOR LATTICE JIBROD [SPF]
TENSIONING ROPE
MIRROR ATTACHM.AT SLEW.PLATFORWIDE ANGLE MIRROR
SERVICEFILTER PACKAGE
SERVICE PACKAGE
- Liebherr Mobile Crane LTM 1080-1 Liccon Error Code
- Liebherr LTM-1090-4.1 Liccon Error Code
- Liebherr Mobile Crane LTM1090-2 Hydraulic Schematic
- Liebherr Mobile Crane LTM 1050-1 Service Manual
- Liebherr Mobile Crane LTM1200-5.1 Wiring Diagram
- Liebherr Mobile Crane LTM 1090-4.1,1100-4.1,1080-2 Wiring Diagram
- Liebherr LTM 1040-2.1 Service Manual
- Liebherr cranes service manuals
- Liebherr Data Bus and Liccon Computer System Technical Training
- Liebherr Crane LTM 1030-2 Service Manual Hydraulic
- Liebherr Mobile Crane LTM 1050 Diagrams Electrical
- Liebherr Mobile Crane LTM 1090-4.1 Hydraulic Schematic
- Liebherr LTM 1030-2 Service Manual Pneumatic
- Liebherr Mobile Crane LTM 1070-4.1 Spare Parts Catalogue
- Liebherr Mobile Crane LTM 1030-2.1 Wiring Diagram
