Jacobsen Rotary Mower HR800 Safety Operation Maintenance Manual 4372606-D-GB
Brand: Jacobsen
Type of Machine: Rotary Mower
Type of Manual: Safety Manual, Operation Manual, Maintenance Manual
Model: Jacobsen HR800 Rotary Mower
Engine: Kubota V3307-CR-E5B, With Reversing Fan, 4WD with ROPS And Cab
Series from: AAD000344. AAE000347, AAF000301, AAG000314
Product code: 070543-4613110, 4624110, 4613210, 4623210
Part Number: 4372606-D-GB
Number of Pages: 124 Pages
Safety, Operation & Maintenance Manual
2.1 Important
WARNING
2.2 PRODUCT IDENTIFICATION
2.3 GUIDELINES FOR THE DISPOSAL OF SCRAP PRODUCTS
2.4 parts manual
2.5 KEY NUMBERS
2.6 SERVICE SUPPORT MATERIAL
NOTES
3.1 How to Operate Safely
4.1 SAFETY DECALS
4.2 Instruction DECALS
5.3 VISUAL DISPLAY
5.4 FAULT LOG
5.5 SETTINGS
5.6 WARNING SCREENS
5.7 lift/lower switch’s
5.8 Indicator lamps
5.9 WEIGHT TRANSFER BUTTON
5.10 TRACTION PEDAL
DRIVING
MOWING
5.11 STEERING TILT CONTROL
5.12 HORN
5.13 POWER OUTLET
5.14 PARK BRAKE RELEASE VALVE
5.15 FREE WHEEL
THE FREE WHEEL FACILITY IS FOR RECOVERY PURPOSES ONLY.
5.16 lighting KIT (Optional)
5.17 seat right hand arm rest & pod
5.18 CABIN CONTROLS
5.1 OPERATOR WORKSTATION
5.2 CONTROL PANEL
6.1 DAILY INSPECTION
6.2 OPERATOR PRESENCE AND SAFETY INTERLOCK SYSTEM
6.3 PROCEDURE for operation
6.4 TO FIT THE Cutter Decks TO THE MACHINE
6.5 OPERATION OF THE MACHINE
6.6 How to start THE ENGINE
6.7 How to drive
6.8 How to mow
6.9 TO STOP THE ENGINE
6.10 To remove A blockage from cutting units
6.11 Transporting on a trailer
6.12 SLINGING and jacking THE MACHINE
6.13 MOWING ON SLOPES
How to calculate a slope
Slope calculation chart
7.1 General Precautions
WARNING
7.2 ENGINE FAN BELT
7.3 weight TRANSFER ADJUSTMENT
7.4 STEERING SHAFT Adjustment
7.5 axle stop Adjustment
7.6 HEIGHT OF CUT ADJUSTMENT
7.7 GENERAL INSTRUCTIONS FOR GRAMMER SEATS
7.8 AIR SUSPENSION SEAT (GRAMMER MSG95 -721)
8.25 Lubrication of cutting unit
NOTES
8.1 maintenance and lubrication charts
8.2 General Precautions
8.3 Engine
8.4 ENGINE LUBRICATION
8.5 ENGINE COOLANT
8.6 HYDRAULIC SYSTEM
8.7 Hydraulic Filter
8.8 HYDRAULIC TEST PORTS
8.9 Fuel
8.10 FUEL SYSTEM
8.11 AIR CLEANER
8.12 BATTERY
8.13 Charge the battery
8.14 Engine Exhaust
8.15 Diesel Particulate Filter
8.16 Hydraulic Hoses
8.17 WHEEL ALIGNMENT PROCEDURE
8.18 STEERING ROD AND STEERING LINK CHECK
8.19 Tyres
8.20 Wheel Mounting Procedure
8.21 BLADE CHANGE
8.22 Inspecting Blades
8.23 Sharpening Blades
8.24 Folding ROPS
8.25 Care and Cleaning
8.26 Mower Storage
9.1 ENGINE problem DIAGNOSTICS
10.1 Quality of Cut PROBLEM SOLVING
10.2 THE Step Cut
10.3 Scalping
10.4 Stragglers
10.5 Streaks
10.6 Windrowing
10.7 Mismatched Cutter DECKS
11.1 fuse and relay/Component identification
12.1 Engine Specification
12.2 Dimensions & Weights
12.3 Machine Specification
12.4 Vibration
12.5 Noise
12.6 Slopes
12.7 Cutting Performance
12.8 Cutter Deck Specification
12.9 Recommended Lubricants
12.10 Accessories
12.11 Third Party Accessories
13.1 Guarantee
