Jacobsen Mower Greens King IV Technical Repair Manual 4247530 2011
Brand: Jacobsen
Type of Machine: Riding Greens Mower
Type of Manual: Technical Manual, Repair Manual, Wiring Diagram, Hydraulic Diagram
Model: Jacobsen Greens King IV Riding Greens Mower
Product Number: 62287, 62288, 62289, 62302, 62303, 62304, 62305, 62306
Engine:
62304 - Kubota D722-E3B
62305 - Briggs And Stratton Vanguard V-Twin OHV
62306 - Briggs And Stratton Vanguard V-Twin OHV
Publication Date: 2011
List of Files:
Jacobsen Mower Greens King IV Technical Repair Manual 4247530p1-A 2011.pdf (60 Pages)
Jacobsen Mower Greens King IV Technical Repair Manual 4247530p2-A.pdf (58 Pages)
Jacobsen Mower Greens King IV Technical Repair Manual 4247530p3-A.pdf (112 Pages)
Jacobsen Mower Greens King IV Technical Repair Manual 4247530p4-A.pdf (108 Pages)
Steering
Specifications
Component Location
Checks and Adjustments
Steering Cable Adjustment
Repair
Steering Wheel (Manual Steering)
Steering Wheel (Power Steering)
Steering Unit (PN 4196484)
Steering Unit (PN 4136214)
Steering Tower Cover
Steering Cylinder
Steering Fork (Manual Steering)
Steering Fork (Power Steering)
Cutting Units
Specifications
Component Location
Troubleshooting
Quality-of-Cut Troubleshooting
Grass Graining
Mechanical Troubleshooting
Center Lift Arm Anti-Sway Spring Adjustment
Reel Control Adjustment
Reel Leveling Adjustment
Front Lift Cylinder Adjustment
Rear Lift Cylinder Adjustment
Bedknife-to-Reel Clearance Adjustment
Height-of-Cut (HOC) Adjustment
Grass Shield Adjustment
Reel Bearing Pre-Load Adjustment
Repair
Front Cutting Units
Center Cutting Unit
Front Lift Arms
Center Lift Arm
Reel Motor
Grass Shield
Bedknife Backing Assembly
Bedknife
Reel Bearing Housing Assembly
Reel Assembly
Front Roller
Rear Roller
Roller Bearings
Accessories and Miscellaneous Repair
Specifications
Component Location
Park Brake Adjustment
Traction Lever Adjustment
Traction Pedal Adjustment
Brake Pedal Adjustment
Repair
OPS
Fuel Tank (Diesel)
Fuel Tank (Gasoline)
Fuel Tank Support Pan
Upper Control Linkage
Lower Control Linkage
Pedal Linkage
Seat Assembly
Seat Switch
Top Seat Skirt
Front Seat Skirt
Fenders
Front Cowling
Floorboard
Front Wheel
Brake and Front Wheel Hub
Rear Wheel and Steering Axle
Steering Axle
Index
