Jacobsen Mower Fairway 250 305 405 Parts Manual 25034G-A 2020
Brand: Jacobsen
Type of Machine: Ride On Reel Mower
Model: Jacobsen Ride On Reel Mower
Fairway 250
Series: JZ
Product code: JGZZ250
Fairway 305
Series: JN
Product code: JGPP305
Series: KD
Product code: JGPP305P
Series: JT
Product code: JGPP305C
Fairway 405
Series: JP
Product code: JHAA405
Series: KE
Product code: JHAA405P
Series: JU
Product code: JHAA405C
Part Number: 25034G-A
Publication Date: 2020
Number of Pages: 184 Pages
FRAME AND REAR AXLE
FRAME AND REAR AXLE
HYDRAULIC TRACTION MOTOR REAR
ENGINE MOUNTING SERIES JZ, KD, KE
ENGINE MOUNTING SERIES JZ, JN, JP
ENGINE EXHAUST AND MOUNTING - SERIES KD, JT, KE, JU
ENGINE / HYDRAULIC TRANSMISSION DRIVE
SERVO PUMP & THROTTLE CONTROLS
AIR FILTER MOUNTING AND BULKHEAD series JZ, JN, JP
RADIATOR & OIL COOLER MOUNTING SERIES JZ, JN, JP
RADIATOR, OIL COOLER AND AIR FILTER MOUNTING SERIES JT, KD, JU, KE
STEERING WHEEL AND PEDAL MOUNTING
FRONT LIFT ARMS
FRONT LIFT ARMS
REAR LIFT ARMS
REAR LIFT ARMS
WING LIFT ARMS - FAIRWAY 405
ROPS
FRONT AXLE MOTOR and WHEEL - SERIES JT, KD, JU, KE
HYDRAULIC RESERVOIR - FUEL TANK and BATTERY
BONNET AND REAR BUMPER
SEAT MOUNTING
GRAMMER MSG 85 SUSPENSION
GRAMMER MSG 85 SEAT
SEAT BREAKDOWN GRAMMER (S 85 / 90R)
SEAT SUSPENSION BREAKDOWN GRAMMER DS85H
JOYSTICK ASSEMBLY FAIRWAY 305 AND 405
ELECTRICS-INSTRUMENT PANEL SERIES JZ, JN, JP
ELECTRICS-INSTRUMENT PANEL SERIES KD, JT, KE, JU
ELECTRICS - VARIOUS COMPONENTS
ELECTRICAL SYSTEM 305 - SERIES JT, KD
ELECTRICAL SYSTEM 405 - SERIES KE, JU
HYDRAULIC VALVE MOUNTING - SERIES JZ, JN, JP
HYDRAULIC VALVE MOUNTING - SERIES KD, JT, KE, JU
SERVO TRANSMISSION PUMP - SAUER SUNDSTRAND
TANDEM PUMP
HYDRAULIC STEER GEAR
LIFT CONTROL VALVE FAIRWAY 250 AND 305
SOLENOID LIFT CONTROL VALVE FAIRWAY 305 / 405
SOLENOID VALVE
REEL DRIVE VALVE
VALVE, WEIGHT TRANSFER
GROUP BRAKE VALVE SERIES JT, KD, JU, KE
BRAKE VALVE (4201021)
VALVE 4 WHEEL DRIVE SERIES JZ, JN, JP
4WD TRANSMISSION VALVE SERIES JT, KD, JU, KE
HYDRAULIC DIAGRAM TRACTION SERIES JZ, JN, JP
HYDRAULIC DIAGRAM TRACTION SERIES JT, KD, JU, KE
HYDRAULIC DIAGRAM - 250 305 CUTTING, STEERING & LIFT
HYDRAULIC DIAGRAM - 405 CUTTING, STEERING & LIFT
DECALS
DECALS
MAIN FRAME & MOUNTING
COMMON PARTS - CONCAVE
COMMON PARTS - BOTTOM BLOCK & CONCAVE
COMMON PARTS - CYLINDER BEARING HOUSINGS
COMMON PARTS - REAR ROLL SMOOTH
CUTTING CYLINDER & FRONT PLAIN ROLL (FLOATING HEAD)
CUTTING CYLINDER & FRONT GROOVED ROLL 22in and 26in
REAR ROLL BRUSH KIT FOR 22" & 26" LH DRIVE UNIT
REAR ROLL BRUSH KIT FOR 22" & 26" RH DRIVE UNIT
CUTTING UNIT DRIVE MOTORS
GRASSBOX AND FITTINGSGRASSBOX AND FIXINGS
CABIN REAR WINDOW AND INFILL FAIRWAY 305, 405
CABIN FAIRWAY 305, 405
CABIN (009093660) FAIRWAY 305, 405
CABIN DOORS FAIRWAY 305, 405
CAB NOISE REDUCTION (009094990) FAIRWAY 305, 405
CAB WEIGHTS
CAB DECALS
CAB WIRING
