Jacobsen Gasoline Greens Mower G-Plex II 898865 Parts Maintenance Manual 4115645 2001
Brand: Jacobsen
Type of Machine: Gasoline Greens Mower
Type of Manual: Parts List, Maintenance Manual, Hydraulic Diagram, Wiring Diagram
Model: Jacobsen Greensplex II 898865 Gasoline Greens Mower
Part Number: 4115645
Publication Date: 2001
Number of Pages: 118 Pages
1 Identification
1.1 Model Number & Serial Number
1.2 Engine Identification Number
1.3 Cutting Head Serial Numbers
2 Service Parts And Support Material
3 Specifications
4 Controls
4.1 Hand Controls
4.2 Control Pedals
5 Adjustments
5.1 Rear Swing Out Arm
5.2 Bedknife Adjustment
5.3 Height of Cut
5.4 Leveling Linkage for the Front Cutting Heads
5.5 Mow/Transport Speed Control
5.6 Adjusting Mow Speed
5.7 Setting Bellcrank Stop Screw
5.8 Head Lift & Lower Timing
6 Maintenance
6.1 Hydraulic Pump Bypass Valve
6.2 Free Wheeling or Towing Unit
6.3 Engine Break–in
6.4 Maintenance Guide
6.5 Lube Chart
6.6 Fuel Recommendations
6.7 Engine Access
6.8 Air Cleaner
6.9 Engine Oil Level
6.10 Engine Oil Filter
6.11 Hydraulic System
6.12 Hydraulic Hoses and Lines
6.13 Hydraulic Oil
6.14 Removal and Installation of the Rear Fork and Tire
6.15 Cutting Head Maintenance
6.16 Backlapping
6.17 Tires
6.18 Fuses
6.19 Battery
6.20 Jump Starting
7 Accessories
7.1 Backlap Valve
7.2 Grass Catcher
7.3 3–wheel Drive
7.4 Dual Headlight
7.5 Tool Box
8 Storage
8.1 Daily Storage
8.2 Extended Storage
9 Troubleshooting
10 Hydraulic Diagram
11 Torque Chart
PARTS SECTION CONTENTS
12.1 Decal Locations
12.2 Decals
12.3 Chassis, Covers, and Rear Fork
12.4 Power Assembly
12.5 Hydraulic Reservoir & Fuel System
12.6 Oil Cooler Mounting
12.7 Head Lift and Pump Control Linkage
12.8 Hydraulic Gear Pump and Reel Control Valve
12.9 Hydraulic Lift Circuit
12.10 Hydraulic Reel Circuit
12.11 Reel Case Drain Circuit
12.12 Service “O”rings Available
12.13 Hydraulic Wheel Drive Circuit
12.14 Hydraulic Power Steering Circuit
12.15 Control Arm
12.16 Lift Assembly – Front Cutting Heads
12.17 Lift Assembly – Rear Cutting Head
12.18 Mow/Raise & Speed Control Pedals
12.19 Mow Speed Control
12.20 Brake Pedal
12.21 Seat
12.22 Control Panel
12.23 Electrical Components
12.24 Tires and Rear Hub
12.
12.26 Cutting Heads
12.27 Rear Rollers
12.28 Vertical Mower
12.29 Rollers and Scrapers for Vertical Mower
12.30 Rotary Rear Brush
12.31 Rollers, Grooved
12.32 Front Roller, Smooth
12.33 Turf Groomer
12.34 Dual Headlight Accessory
12.35 Grass Catcher Accessory
12.36 Tool Box Accessory
12.37 Backlapp Valve Accessory
12.38 Roller Spiker Adapter
12.38 Reel Motor Mounting
12.39 Wire Schematic
12.40 Wire Diagram
Maintenance Section Index
Part Section Index
Part Number Index 1
