705,578
Hesston Mower Conditioner 1260 1265 Parts Catalog 00719059
Brand: Hesston
Type of Machine: Mower Conditioner
Model:
Hesston 1260 Mower Conditioner
Hesston 1265 Mower Conditioner
Part Number: 00719059
Number of Pages: 220 Pages
Publication Information
Drives - Main Drive (1260)
Drives - Main Drive (1265)
Drives - U-Joint Assembly (Upper-14 Foot), (700715723 U-Joint Assembly)
Drives - Sickle Drive
Drives - Swaybar
Drives - Crank
Drives - Reel Drive (Left)
Drives - Chainbox Assembly
Drives - Jackshaft Assembly (Lower)
Drives - Jackshaft Assembly (Upper)
Drives - Reel Drive (Right)
Drives - Auger Drive (Right)
Drives - Sheave Assembly
Drives - Hay Conditioner Drive (12 Foot)
Drives - U-Joint Assembly (Timing)
Drives - U-Joint Clutch Assembly, (700710451 U-Joint Clutch Assembly)
Drives - U-Joint Assembly (Lower-12 Foot), (700717387 U-Joint Assembly)
Drives - Hay Conditioner Drive (14 Foot)
Drives - U-Joint Assembly, (700715720 U-Joint Assembly)
Drives - U-Joint Assembly, (700715721 U-Joint Assembly)
Drives - U-Joint Assembly (Lower-14 Foot), (700715726 U-Joint Assembly)
Sickle - Sickle And Guard-Range Guard, (12 Foot)
Sickle - Sickle And Guard-Range Guard, (14 Foot)
Sickle - Adjustable Stub Guard (12 Foot)
(Not Used) - Flasher Lights, (S.N. 126h-00101 Thru Hk90100)-1260, (S.N. 126h-00101 Thru Hk94100)-1265
(Not Used) - Flasher Lights, (S.N. Hk90101 And Later)-1260, (S.N. Hk94101 And Later)-1265
(Not Used) - Electrical Harness Service Parts
Hay Conditioner - Hay Conditioner
Hay Conditioner - Panel-Hay Conditioner (Left)
Hay Conditioner - Panel-Hay Conditioner (Right)
Hay Conditioner - Hay Conditioner (Ticor)
Hay Conditioner - Panel-Hay Conditioner, Left, (Ticor)
Hay Conditioner - Panel-Hay Conditioner, Right, (Ticor)
Hay Conditioner - Hay Conditioner Spring
Hay Conditioner - Hay Conditioner Deflector
Reel - Reel (12 And 14 Foot)
Reel - Reel Bat And Tine Tube (12 Foot), Tine Tube Assembly A
Reel - Reel Bat And Tine Tube (12 Foot), Tine Tube Assembly B
Reel - Reel Bat And Tine Tube (14 Foot), Tine Tube Assembly A
Reel - Reel Bat And Tine Tube (14 Foot), Tine Tube Assembly B
Reel - Auger And Mounting
Reel - Auger Spiral Replacement
Frame, Wheels And Shields - Hitch And Jack
Frame, Wheels And Shields - Latch-Roading
Frame, Wheels And Shields - Flotation-Left (1260)
Frame, Wheels And Shields - Flotation-Right (1260)
Frame, Wheels And Shields - Flotation Spring Assembly (1260)
Frame, Wheels And Shields - Flotation-Left (1265)
Frame, Wheels And Shields - Flotation-Right (1265)
Frame, Wheels And Shields - Flotation Spring Assembly (1265)
Frame, Wheels And Shields - Wheel And Hub Assembly
Frame, Wheels And Shields - Dividers, Leanbar And Mounting (Left)
Frame, Wheels And Shields - Dividers, Leanbar And Mounting, (Right)
Frame, Wheels And Shields - Shields And Mounting-Left, (1260)
Frame, Wheels And Shields - Shields And Mounting-Right, (1260)
Frame, Wheels And Shields - Shields And Mounting-Left (1265)
Frame, Wheels And Shields - Shields And Mounting-Right, (1265)
Frame, Wheels And Shields - Shield Assembly (Left), (S.N. 126h-00101 Thru Hk90100)-1260, (S.N. 126h-00101 Thru Hk94100)-1265
Frame, Wheels And Shields - Shield Assembly (Right), (S.N. 126h-00101 Thru Hk90100)-1260, (S.N. 126h-00101 Thru Hk94100)-1265
Frame, Wheels And Shields - Shield Assembly (Left), (S.N. Hk90101 And Later)-1260, (S.N. Hk94101 And Later)-1265
Frame, Wheels And Shields - Shield Assembly (Right), (S.N. Hk90101 And Later)-1260, (S.N. Hk94101 And Later)-1265
Frame, Wheels And Shields - Latch Assembly
Frame, Wheels And Shields - Header Auger Pan And Stripper-Left, (12 Foot)
Frame, Wheels And Shields - Header Auger Pan And Stripper-Right, (12 Foot)
Frame, Wheels And Shields - Header Auger Pan And Stripper-Left, (14 Foot)
Frame, Wheels And Shields - Header Auger Pan And Stripper-Right, (14 Foot)
Frame, Wheels And Shields - Header Mounting
Frame, Wheels And Shields - Skid Shoe-Center And Wear Plate, (12 Foot)
Frame, Wheels And Shields - Skid Shoe-Center And Wear Plate, (14 Foot)
Frame, Wheels And Shields - Skid Shoes And Mounting, (12 Foot)
Frame, Wheels And Shields - Skid Shoes And Mounting, (14 Foot)
Frame, Wheels And Shields - Forming Shields
Hydraulics - Hydraulic Drive-Front
Hydraulics - Hydraulic Drive-Rear, (S.N. 126h-00101 Thru Hk90100)-1260, (S.N. 126h-00101 Thru Hk94100)-1265
Hydraulics - Hydraulic Drive-Rear, (S.N. Hk90101 And Later)-1260, (S.N. Hk94101 And Later)-1265
Hydraulics - Hydrostatic Pump-Pto Assembly (540 Rpm), (700700937 Hydrostatic Pump Assembly)
Hydraulics - Gearbox Step-Up Assembly (540 Rpm Pump), (700712138 Gearbox Assembly (540 Rpm))
Hydraulics - Hydrostatic Motor Assembly, (700706977 Hydrostatic Motor Assembly)
Hydraulics - Tongue Pivot-Hydraulics
Hydraulics - Hydraulic Cylinder Assembly, (700718463 Hydraulic Cylinder)
Hydraulics - Header Lift-Hydraulics (1260)
Hydraulics - Header Lift-Hydraulics (1265)
Hydraulics - Hyd. Cyl.-Lift (Master), (700712016 Hyd. Cyl.), (S.N. 126h-00101 Thru Hl90100), (S.N. 126h-00101 Thru Hl94100)
Hydraulics - Hyd. Cyl.-Lift (Slave), (700712022 Hyd. Cyl.), (S.N. 126h-00101 Thru Hl90100), (S.N. 126h-00101 Thru Hl94100)
Hydraulics - Hyd. Cylinder-Lift (Master), (700728104 Hyd. Cylinder), (S.N. Hl90101 And Later), (S.N. Hl94101 And Later)
Hydraulics - Hyd. Cylinder-Lift (Master), (700728109 Hydraulic Cylinder), (S.N. Hl90101 And Later), (S.N. Hl94101 And Later)
Decals And Kits - Decals And Location Diagram (1260)
Decals And Kits - Decals And Location Diagram (1265)
Decals And Kits - Decals And Location, (Header-Left), (S.N. 126h-00101 Thru Hk90100), (S.N. 126h-00101 Thru Hk94100)
Decals And Kits - Decals And Location, (Header-Right), (S.N. 126h-00101 Thru Hk90100), (S.N. 126h-00101 Thru Hk94100)
Decals And Kits - Decals And Location Diagram, (Header-Left), (S.N. Hk90101 And Later)-1260, (S.N. Hk94101 And Later)-1265
Decals And Kits - Decals And Location Diagram, (Header-Right), (S.N. Hk90101 And Later)-1260, (S.N. Hk94101 And Later)-1265
Decals And Kits - Knife Socket Protector Kit, (700121176 Knife Socket Protector Kit)
Decals And Kits - Crop Divider Kit, (K60918 Crop Divider Kit)
Decals And Kits - Narrow Windrow Forming Kit, (K60577 Narrow Windrow Forming Kit)
Decals And Kits - Gauge Wheel Kit (12 Foot), (K60561 Gauge Wheel Kit)
Decals And Kits - Gauge Wheel Kit (14 Foot), (K61016 Gauge Wheel Kit)
Decals And Kits - Drawbar Extension Kit, (K60978 Drawbar Extension Kit)
Decals And Kits - Pump And Step-Up Gearbox (1000 Rpm), (K60548 Pump And Step-Up Gearbox Kit)
Decals And Kits - Hydrostatic Pump-Pto Assembly (1000 Rpm), (700700711 Hydrostatic Pump Assembly)
Decals And Kits - Gearbox Step-Up Assembly (1000 Rpm Pump), (700712139 Gearbox Assembly (1000 Rpm))
Decals And Kits - Reverser Kit, (K60994 Reverser Kit)
Decals And Kits - Reverser Kit-Continued
Decals And Kits - Hydraulic Valve Assembly (Reverser), (700718243 Hydraulic Valve Assembly)
Decals And Kits - Adjustable Stub Guard Kit (12 Foot), (700120955 Stub Guard-12 Foot Kit)
Decals And Kits - Adjustable Stub Guard Kit (2 Foot), (700115807 Stub Guard-2 Foot Kit)
Recommended Dealer Stock - Recommended Dealer Stock
