Hatz Engine E71 E75 E79 E780 HE780 E785 E786 Repair Manual
Brand: Hatz
Type of Manual: Repair Manual
Model: Hatz E71 E75 E79 E780 HE780 E785 E786 Engine
Number of Pages: 127 Pages
Index
1. Oil bath air filter and exhaust silencer
2. Fuel tank and fuel filter
3. Injector
4. Cylinder head
5. Cylinder
6. Piston
7. Connecting rod
8. Injection pump
9. Timing cover
9a. Timing cover for engines with counterbalance E 780 U - HE 780 UE 785 UE 786 U
10. Camshaft and gearwheel on crankshaft
10a. Counterbalance E 780 UHE 780 UE 785 U-E 786 U
11. Governor
12. Flywheel
13. Bearing flange
14. Crankshaft
15. Bleeding
15a. Automatic bleeding device of injection pump
15b. Checking of automatic bleeding device
15c. Subsequent mounting of automatic bleeding device
16. Adjusting of injection pump and rpm. "not denoised" engines
16a. Adjusting of injection pump, denoised version
17. Checking of injection pump and injector
18. Electrically operated fuel pressure bypass valve
19. Alternator 10 A "Ducati"
for engine HE 780 (U) (watercooled)
20. Piston and cylinder; disassembly and assembly
21. Cylinder head; disassembly and assembly
22. Water pump; disassembly, repair, assembly
23. Thermostat; disassembly, operational testing, assembly
Pictures - special tools
Technical data
Fuel and lub.-oil
Repair data
Injection equipment governor components
Torque wrench settings
Modifications
Brand: Hatz
Index
3. Injector
4. Cylinder head
5. Cylinder
6. Piston
7. Connecting rod
8. Injection pump
9. Timing cover
11. Governor
12. Flywheel
13. Bearing flange
14. Crankshaft
15. Bleeding
Technical data
Fuel and lub.-oil
Repair data
Modifications
- Hatz Diesel Engine 1D81S-325 Parts list 805-10001
- Hatz Engine 1D Series Workshop Manual 43820201
- Hatz Engine 2M41 3M41 4M41 Spare Parts Catalog 000043460012
- Hatz Engine 2W35 3W35 3W35T 4W35 4W35T Workshop Manual 95203901.9984
- Hatz Engine E71 E75 E79 E780 E786 Parts Catalog
- Hatz Engine 3H50T 3H50TI 3H50TIC 3H50TICD Spare Parts Catalog 000043700402
- Hatz Engine 1B20 1B20R 1B27 1B30 Spare Parts Catalog 2014
- Hatz Engine 1B20 1B20R 1B27 1B30 Spare Parts Catalog 2019
- Hatz Engine 1B20 1B27 1B30 1B40 1B50 Instruction Book DE
- Hatz Engine 1B20 1B27 1B30 1B40 1B50 Instruction Book EN
- Hatz Engine 1B20 1B27 1B30 1B40 1B50 Instruction Book FR
- Hatz Engine 1B20 1B27 1B30 1B40 1B50 Operation and Maintenance Manual EN
- Hatz Engine 1B20 1B30 1B40 1B50 Operation and Maintenance Manual DE
- Hatz Engine 1B20 1B30 1B40 1B50 Operation and Maintenance Manual EN
- Hatz Engine 1B20 1B30 1B40 1B50 Operation and Maintenance Manual ES
