CHEVROLET FAULT CODES
Diagnostic trouble codes (1.4 L / 1.6 L DOHC)
DTC APPOINTMENT
NO2S P0030 (Sensor 1) Heater Circuit Not Available
NO2S P0036 (Sensor 2) Heater Circuit Not Available
P0107 Sensor Manifold Absolute Pressure, Low Voltage
P0108 Sensor Manifold Absolute Pressure, High Voltage
P0112 Intake Air Temperature Sensor Low Voltage
P0113 Intake Air Temperature Sensor High Voltage
P0117 Engine Coolant Temperature Sensor Low Voltage
P0118 Engine Coolant Temperature Sensor High Voltage
P0122 Throttle Position Sensor Low Voltage
P0123 Throttle Position Sensor High Voltage
P0131 HO2S (Sensor 1) low level signal
P0132 HO2S (Sensor 1) High level signal
P0133 HO2S (Sensor 1) Slow performance
P0137 HO2S (Sensor 2) Low signal
P0138 HO2S (Sensor 2) High level signal
P0140 HO2S (Sensor 2) Failure of the circuit or signal
P0171 Fuel Trim System Too Lean
P0172 Fuel Trim System Too Rich
P0222 Drive controller idle throttle, low voltage circuit
P0223 Actuator idle speed regulator Throttle High Voltage
P0261 Injector cylinder 1, a low level signal of the control circuit
P0262 Injector cylinder 1, a high signal level control circuit
P0264 injector 2-cylinder, low level signal the control circuit
P0265 injector 2nd cylinder, a high level signal of the control circuit
P0267 Injector, cylinder 3, a low level signal of the control circuit
P0268 injector cylinder 3, a high level signal of the control circuit
P0270 Injector 4 cylinder, low signal level control circuit
P0271 injector cylinder 4, a high level signal of the control circuit
P0300 showed multiple misfires
P0327 Knock Sensor, Circuit Malfunction
P0335 Crankshaft Position Sensor, Circuit Malfunction
P0336 Error pulse crankshaft position sensor
P0337 Crankshaft position sensor, no signal
P0341 Camshaft position sensor, the output signal of the acceptable range
P0342 Camshaft position sensor, no signal
P0351 Circuit Malfunction 1 and 4, the ignition control
P0352 Circuit Malfunction 2 and 3, the ignition control
P0400 Exhaust Gas Recirculation Out of Limit
P0401 Exhaust Gas Recirculation EGR valve is blocked
P0403 Circuit Malfunction EGR valve
P0404 Exhaust Gas Recirculation EGR valve is faulty
P0405 Low signal or an open in the feedback loop recycling system
exhaust gas
P0406 High signal or wire fault in the feedback system
EGR
P0420 Low efficiency of the converter
P0444 Circuit EVAP purge valve, there is no signal
P0445 Circuit Malfunction canister purge valve
P0462 Fuel Level Sensor Low Voltage
P0463 Fuel Level Sensor High Voltage
P0480 Relay Circuit Fault Low Speed Cooling Fan
P0481 High Voltage relay high speed cooling fan
P0501 Vehicle Speed No Signal (only with manual transmission)
P0510 Circuit Malfunction Throttle Position Switch
P0562 Low Voltage Systems
P0563 High Voltage Systems
P0601 ECM, checksum error
P0604 RAM error ECM
P0605 Error writing controller engine control
P0628 fuel pump relay, low voltage circuit
P0629 fuel pump relay, High Voltage
P0646 C compressor relay, low voltage circuit
P0647 C compressor relay, High Voltage
P0650 Malfunction Indicator Lamp Low Voltage
P0656 Circuit Malfunction Fuel Level Output
P0661 Solenoid actuator intake manifold, variable-length low voltage
chain
P0662 solenoid actuator intake manifold of variable length, higher
voltage circuit
P0700 General fault TCM, disrupt transmission (only
automatic)
P1390 Sensor Circuit Malfunction Rough Road (only 0.8S)
P1396 Rough Road Sensor ABS incorrect data
P1504 Vehicle Speed No Signal (only with automatic transmission)
P1610 Main Relay Circuit High Voltage
P1611 Main Relay Circuit Low Voltage
P1628 does not communicate with the immobilizer
P1629 Incorrect calculation of immobilizer
P1650 MIL, High Voltage
P2101 Circuit Fault Drive Idle Charge
P2118 Actuator Mechanical Error Idle Charge
P2119 Functional Error Idle Air Control
U0101 Missing Message TCM (automatic only)
DTCs (1.8D-FAM I)
DTC Description
P0016 The relationship between the crankshaft position (CKP) and position
camshaft position (CMP)
P0106 Sensor Performance Manifold Absolute Pressure (MAP)
P0107 Sensor Circuit Manifold Absolute Pressure (MAP), a low level signal
P0108 Sensor Circuit Manifold Absolute Pressure (MAP), a high level signal
P0112 Sensor Circuit Intake Air Temperature Low Voltage
P0113 Sensor Circuit Intake Air Temperature High Voltage
P0117 Sensor Circuit Engine Coolant Temperature, Low Voltage
P0118 Sensor Circuit Engine Coolant Temperature High Voltage
P0122 Circuit Throttle Position Sensor Low Voltage
P0123 Circuit Throttle Position Sensor High Voltage
P0131 Sensor Circuit HO2S, low signal, the sensor 1
P0132 Sensor Circuit HO2S, High Voltage Sensor 1
P0133 Sensor 1 delayed response of the HO2S
P0134 Sensor 1 attenuation circuit of the HO2S activity
P0135 Sensor 1 HO2S heater efficiency
P0137 Sensor Circuit HO2S, a low level signal, sensor 2
P0138 Sensor Circuit HO2S, High Voltage Sensor 2
P0140 Sensor 2 attenuation circuit of the HO2S activity
P0141 Sensor 2 HO2S heater efficiency
P0171 lean fuel trim system
P0172 rich mixture in the fuel trim
P0201 injector control circuit 1
P0202 injector control circuit 2
P0203 injector control circuit 3
P0204 injector control circuit 4
P0300 Misfire Detected
P0315 not detect changes in the system changes the angle of rotation of the crankshaft
P0317 No input signal from the rough road detection system
P0324 Efficiency knock sensor module
P0325 Knock Sensor Circuit
P0335 Circuit Crankshaft Position Sensor (CKP)
P0336 Sensor Performance crankshaft position (CKP)
P0340 Circuit Camshaft Position Sensor (CMP)
P0351 Control Circuit Ignition Coil 1 and 4
P0352 Control Circuit Ignition Coil 2 and 3
P0401 Exhaust Gas Recirculation insufficient flow
P0402 Exhaust Gas Recirculation, excess consumption
P0404 Exhaust gas recirculation, efficiency in the open position
P0405 position sensor circuit in the EGR system, the low level
signal
P0406 position sensor circuit in the EGR system, a high level
signal
P0420 Poor performance of the catalytic converter
P042E Exhaust gas recirculation, efficiency in the closed position
The control circuit P0443 EVAP canister purge valve
P0461 Fuel Level Sensor Performance
P0462 Circuit Low Voltage fuel level sensor
P0463 Circuit High Voltage fuel level sensor
P0502 Circuit Vehicle Speed Sensor (VSS), a low level signal
P0506 Low speed at idle
P0507 High-speed idle
P0532 pressure sensor circuit coolant in air conditioning system, a low level
signal
P0533 pressure sensor circuit coolant in air conditioning system, high
signal
P0601 Only Memory (ROM) of the controller
P0602 controller is programmed
P0606 Speed Controller
P0660 control circuit solenoid valve in the intake manifold assembly adjustment
Enable P0700 MIL requested by the controller
PPC
P1133 Sensor 1 inefficiency switching the HO2S
P1134 HO2S, sensor 1 ratio of transition time
P1166 lean at full load
P1391 Rough Road Sensor Performance
P1392 Rough Road Sensor Circuit Low Voltage
P1393 Rough Road Sensor Circuit High Voltage
P1396 deviation signal from the wheel speed sensor ABS
P1397 No signal from the wheel speed sensor ABS
P1631 unbelievers signal of the supply of fuel to protect against theft
P2297 HO2S, sensor 1 performance when fuel shut-off mode
engine braking
P2610 Efficiency ignition off timer in the controller
U0101 Lost Communication with TCM
U0167 Missing message identifier of the immobilizer
DTC APPOINTMENT
exhaust gas
EGR
P0604 RAM error ECM
chain
voltage circuit
automatic)
DTCs (1.8D-FAM I)
DTC Description
signal
signal
signal
signal
PPC
engine braking
- Chevrolet Captiva 2008-2010 Service Repair Manual
- Chevrolet Europe TIS 02.2011 Full Link data
- Chevrolet Cruze 2010 Europe Service Manual
- Chevrolet Europe TIS 2006 - 2009
- Chevrolet Captiva Sport 2008-2010 Owners & Service Manual
- CHEVROLET CAPTIVA C100 Maintenance and Repair Manual
- Chevrolet Tahoe 2016 Wiring Diagrams
- Chevrolet Corvette C5 5.7L 1997-2002 Parts Manual
- GM Service Manual v09 Manuals ESI
- Chevrolet Cruze L4-1.4L 2017 Electrical Wiring Diagram
- Chevrolet Volt, Opel Ampera 2012 Service Manual
- Manual de taller del motor 4JA1 4JH1-TC
- Chevrolet Euro Service Manual 2009-2011
- Chevrolet Colorado Engine 2.8 Wiring Diagram Manual 2016
- Chevrolet Sonic 2012 Body Repair Manual
