ATSG Automatic Transmission 4L40-E 5L40-E Service Manual
Brand: ATSG
Type of Machine: Automatic Transmission
Model: ATSG 4L40-E 5L40-E Automatic Transmission
Publication Date:
Number of Pages: 128 Pages
5L40-E IDENTIFICATION TAG INFORMATION
CUT-AWAY VIEW AND COOLER LINE IDENTIFICATION
COMPONENT APPLICATION CHART
SOLENOID APPLICATION AND RESISTANCE CHARTS
INTERNAL WIRE SCHEMATIC
TCM LOCATION, CONNECTOR ID AND UNDERHOOD FUSE BLOCK ID
ELECTRONIC COMPONENT LOCATER
INTERNAL MODE SWITCH DESCRIPTION
DIAGNOSTIC TROUBLE CODES AND DESCRIPTION
GENERAL OPERATION AND DESCRIPTION
FLUID LEVEL CHECKING PROCEDURE
LINE PRESSURE TESTS
OIL PRESSURE PASSAGE IDENTIFICATIONS
CHECK BALL DESCRIPTIONS
TRANSMISSION DISASSEMBLY
TRANSMISSION EXPLODED VIEW
COMPONENT REBUILD SECTION
CASE ASSEMBLY
OIL PUMP ASSEMBLY
DIRECT AND REVERSE CLUTCH HOUSING
FORWARD AND COAST CLUTCH HOUSING
FORWARD SPRAG ASSEMBLY
INTERMEDIATE SPRAG ASSEMBLY
INTERMEDIATE AND OVERDRIVE CLUTCH HOUSING
LOW SPRAG ASSEMBLY
CENTER SUPPORT ASSEMBLY
5L40-E PLANETARY CARRIER ASSEMBLY
4L40-E PLANETARY CARRIER ASSEMBLY
VALVE BODY ASSEMBLY
CHECKBALL LOCATIONS
FINAL TRANSMISSION ASSEMBLY
BOLT IDENTIFICATION CHART
TORQUE SPECIFICATIONS
Brand: ATSG
Publication Date:
LINE PRESSURE TESTS
CASE ASSEMBLY
OIL PUMP ASSEMBLY
LOW SPRAG ASSEMBLY
VALVE BODY ASSEMBLY
CHECKBALL LOCATIONS
- Delphi Common Rail Pump
- Delphi Workshop Manual Injector 2008
- Geely Gearbox S160 - 1.5 Manual Parts
- Chery QQ3 Service Manual 372 and 472 Engine.
- ZF 5HP18 Automatic Transmission Repair Manual
- GM 4L30E Transmisson Repair Manual
- ZF 4HP20 Automatic Transmission Repair Manual
- Harley Davidson 2014 Wiring Diagram
- Greatwall 491QE Engine Spare Parts Catalogue
- Chery QQ6 - SQR473F Engine-Mechanical Service Manual
- Citroen C5 Haynes Workshop Manual
- Geely CK 2008 Catalogue Parts
- RAVE CD - a collection of original technical documentation from the MG & Rover
- Hummer H2 2005 Repair Manual
- Zexel COVEC-F Service Manual Adjusment & Inspection
