AGCO EDT 11.2025 Diagnostic Program
- Download this document, you need 18750 Gallons
AGCO EDT v1.128.25258.1057 11.2025 Diagnostic Program
Size: 45.34GB (Winrar Files)
Interface Languages: English, Dutch, French, Finnish, German, Spanish, Portuguese, Danish, Russian, Polish, Italian, Turkish, Swedish, Chinese, Norwegian Bokmål.
Database Languages: Only English
Type of Program: AGCO EDT (Electronic Diagnostic Tool)
Type of vehicle: Agricultural
Update: v1.128.25258.1057 11.2025
OS: Windows 10, Windows 11 64 & 86 bit (Tested on Windows 10 Pro 22H2 64-bit)
Send an email to get the password: "admin@autorepairmanuals.ws, Gallons@autorepairmanuals.ws"
NOTE: " DO NOT HAVE FENDIAS IN THIS AGCO EDT"
Release Notes – 11/5/2025 – Update 2025.5
EDT NOTES:
EDT Version: 1.128.25258.1057
Enhancements:
Enhancements:
- Add double-click action for EDT selections
- Minor improvements to diagnostic functionality.
Vehicles Affected:
- Challenger: WR9900 Series
- Massey Ferguson: WR9900 Series
- 1.68
- This update requires that the guidance receiver is updated to the latest software version.
- Specifically for units with Trimble receivers, if after the software updates the system is not recognized on the monitor or the only correction source available is Autonomous, then technicians will need to clear the BB Ram to allow the receiver to do a full reboot. To do this the technicians will need to download the Trimble Toolbox+ app onto their mobile device. From there use the following steps to navigate to the appropriate location within the app:
- Turn on the receiver.
- Connect the Trimble Toolbox+ app with the receiver.
- Run the AgRemote utility.
- Navigate to the Clear BB RAM screen.
- Press double window icon until “Yes” appears.
- Press enter.
- NT03 v5.00.18
- Fix third screen black bug
- Fix incorrect convergence value when in imperial units
- Fix latest worked area not saving on ignition off
- Fix overlap in correction screen when using Trimble with no modem
- Last selected field/wayline restores on ignition off/on
- VD0x VD0X.GLB001.I.03.198.
- Improved pivot recording algorithm
Vehicles Affected:
Release Notes – 9/8/2025 – Update 2025.4.OC2- Challenger: 520C
- Challenger: 540C
- Challenger: 560C
- Massey Ferguson: 9595S
- Massey Ferguson: 9695S
- Massey Ferguson: 9795S
- Massey Ferguson: 9895S
- Valtra: 6800
- Valtra: 7800
- 1.66
- fixed VMM version as “BB: 5.38 b63; LL: 0,66 b101”
- EMU update ver. AX_S3_P2_ISO_EMU_v6.06_b167
- engine update variant 84674 to sw: 837085987_5
- engine update variant 84679 to sw: 837093577_1
- engine update variant 98622 to sw: 837093579_1
- engine update variant 98621 to sw: 837093578_1
- engine plug-in update to ver. 6.16
EDT NOTES:
EDT Version: 1.128.25190.1121
Vehicles Affected:
Release Notes – 8/27/2025 – Update 2025.4- Massey Ferguson: 2706e, 2760e
- 2.9
EDT NOTES:
Bug Fixes:
Enhancements:
Bug Fixes:
Enhancements:
- Updated WinSCP to version 6.5.2
Vehicles Affected:
- 1.67
- NT03 v5.00.17
- Fix header float conversion between imperial and metric
- Fix USB icon stays active when USB is removed
- Fix secondary monitor freeze in some circumstances
- Fix primary monitor crash when shifting into rear steer
- Fix guidance overlap not being maintained in both directions
- Fix not applying overlap after key switch but still showing right value
Vehicles Affected:
- Massey Ferguson: Square Balers: 2224, 2233, 2234, 2234XD, 2244
- Fendt: Square Balers: 990, 1270, 1290, 1290XD, 12130
- 1.37
- Add virtual CAN-Bus to monitor availability of ECUs while connected to ISOBUS connector.
- Make backup of EEPROM before upgrading software
- Add possibility to change electronic/mechanical knotter trip without an authorization key
- EXT 01.14.01
- Fix sending amount of cut bales to ACM and Infotrac at startup
- Fix sending cutter override alarm when override is active and not only while button is pressed
- Change delay for missing machine speed to 60 seconds to give ACM time to get started
- Fix having active parking brake alarms after parking brake has been turned off
- Fix displaying a double indicator when both load bullets are not sending values
- Improve load bullet diagnostics
- Fix having infobox items available for moisture system that was previously connected
Vehicles Affected:
- Challenger: 660B made in Brazil, 670B made in Brazil, 680B made in Brazil
- Massey Ferguson: 9695 made in Brazil, 9795 made in Brazil, 9895 made in Brazil
- Valtra: BC6800, BC7800, BC8800
- 1.36
- The “internal error” no longer occurs when opening the Combine Setup configuration page.
Vehicles Affected:
- Challenger: 520C
- Challenger: 540C
- Challenger: 560C
- Valtra: 6800
- Valtra: 7800
- 1.62
- Software update for EMU and VMM, replacement of the MVEC with HCDM
- Guidance System only AGS-2
- Monitor only X35
- Shaft Speeds: added block with active tailboard – spinners speed
- Replaced all the relays of MVECs with HCDMs
- Added 2 more options for discharge type: Chopper -active tailboard, straw spreader – Hyd
- VMM ver. BB: 5.38 b63; LL: 0.66 b101
- EMU ver. 6.6
- Removed AGCOCOMMAND, AG3000
Vehicles Affected:
- Massey Ferguson: 2700-4700 Series
- Massey Ferguson: 6700R Series
- Massey Ferguson: Global Series 4700-5700-6700
- Valtra: A100
- Valtra: A100Hitech Series
- Valtra: A4, A4S
- Valtra: A4Hitech Series
- Valtra: AC52.5, AC54.5, AC56.5
- AGCO EDT (Electronic Diagnostic Tool) v1.75 [03.2016] Full + Instruction
- AGCO Full Database NA + UK + AU + SA Parts & Workshop Service Manual 2021
- AGCO EDT (Electronic Diagnostic Tool) v1.77 [02.2017] Full + Instruction
- AGCO Epsilon 2.1.80 03.2018
- AGCO Epsilon 2.1.80 05.2019 Full
- AGCO EPSILON KG for all 24 Brands
- AGCO Epsilon Security Key [31.10.2017]
- AGCO AG Agricultural ALL Database EU Updated [11.2020]
- AGCO AG Agricultural EU Updated 03.2021 ALL Database Part and Workshop Repair Manual
- AGCO EDT Electronic Diagnostic Tool v.1.92.20028.884 [04.2020] Update Files
- AGCO AG Agricultural ALL Database NA + UK + AU Updated [06.2019]
- AGCO Epsilon Security Key [30.04.2017]
- AGCO AG Agricultural ALL Database NA Updated [03.2020]
- AGCO EDT Electronic Diagnostic Tool Updated 1.107.21194.578 2021.4.OC1 10.2021 Diagnostic Software DVD
- AGCO EDT Electronic Diagnostic Tool Updated 05.2022 Diagnostic Solution
