James Rodrigues
169
1,658,231
AGCO EDT Electronic Diagnostic Tool Updated 1.107.21194.578 2021.4.OC1 10.2021 Diagnostic Software DVD
Size: 48.8 GB (.iso Files)
Interface Languages: English, Dutch, French, Finnish, German, Spanish, Portuguese, Danish, Russian, Polish, Italian, Turkish, Swedish Sweden, Chinese, Norwegian- Bokmal.
Database Languages: Only English
Version: Updated 1.107.21194.578 2021.4.OC1 10.2021
Type of software: AGCO EDT (Electronic Diagnostic Tool)
Year/Release Date: 10.2021
OS: Windows 7, Windows 8, Windows 8.1, Windows 10 x64 & x86 (Tested on window 7 64bit ultimate & Window 10 pro 1607 64bit)
Amount of disk: 1 DVD
Installation: Multiple PCs
Instruction: Present
Medicine: Present
Supporter: Present
Print Functions: Present
High-Speed Link Download
Electronic Diagnostic Tool (EDT) 2021 AGCO can be used by dealership technicians to interface with specific machines that have a Controller Area Network (CAN) BUS as part of the electronic system architecture. EOL (End Of Line) programming, diagnosis and documentation system for FENDT tractors. Those in-field diagnostic programs helps technician accurately diagnose and solve a technical problem quickly by getting to the root cause and giving guidance on how to best solve it.
WinEEM3 and WinEEM4 is an easy tool for the monitoring and adjustment program to SisuDiesel Electronic Control Unit (ECU). Programs can be used with EEM2, EEM3, EEM4 ECU. CAN bus used to communicate with ECU.
You can make full diagnostic, programming and troubleshoot problem of current brands:
• AGCO
• Challenger
• FENDT
• FELLA
• GLEANER
• Laverda
• Massey Ferguson
• RoGator
• SpraCoupe
• TerraGator
• Valtra
• WHITE Planters
New Update:
Release Notes - 9/3/2021 - Update 2021.4.OC1
EDT NOTES:
EDT Version: 1.107.21194.578
Vehicles Affected:
•Challenger: WR9900 Series
•Massey Ferguson: WR9900 Series
Vehicle Version:
•1.39
General:
•Added support for model year 2022 Windrowers. Added flash capability for CEA Guide specific controllers. Also included is the option for legacy machines to upgrade to new Ground Drive and Main Controller software to improve driving performance. Main controller flash can now be found under the software flash connection.
Diagnostics:
•Added CEA_Guide plug-in to assist in diagnostics
Software:
•Ground Drive (4.02.02), Main Controller (3.02.04). EXT Lite (3.96), VD04 (l.03.143). NT03 usb flash option has been added to software flash connection. Option is still present to flash legacy software however this is only available to model year 2018-2021 machines without CEA Guide. CEA Guide equipped machines only allow for added "Gen 4" software package.
Diagnostic Trouble Codes:
•Using trouble codes provided by CEA_Guide plug-in.
Plug-Ins:
•CEA_Guide plug-in was added.
Vehicles Affected:
•Fendt: IDEAL Combines
•Massey Ferguson: IDEAL Combines
Vehicle Version:
•1.35
General:
•Updated GQS software flash method
Configuration:
•ACM config: 10.4
Software:
•GQS: 1.0.5.1482
Release Notes - 9/1/2021 - Update 2021.4
EDT NOTES:
Bug Fixes:
•Fixed an issue where some signal values displayed in Diagnostics Reporting had the wrong value. Data values like 5.0 were being displayed as 50.0.
Vehicles Affected:
•Massey Ferguson: 2700e
Vehicle Version:
•2.8
Software:
•Support of the 273700-3053 (Perkins controller) spare part replacement.
Plug-Ins:
•Shibaura ver 1.12
Vehicles Affected:
•AGCO: Round Balers: 2846, 2856
•AGCO: Square Balers: 2140, 2150, 2160, 2170, 2190
•Challenger: Round Balers: RB46C, RB56C, 2946, 2956
•Challenger: Square Balers: LB23B, LB24B, LB33B, LB34B, LB34BXD, LB44B, 2240, 2250, 2260, 2270, 2270XD, 2290
•Fendt: Square Balers: 870, 990, 1270, 1290, 1290XD, 12130
•Massey Ferguson: Round Balers: 2846, 2856, 2946, 2956
•Massey Ferguson: Square Balers: 2140, 2150, 2160, 2170, 2170XD, 2190, 2240, 2250, 2260, 2270, 2270XD, 2290
Vehicle Version:
•6.16
General:
•Added support for NT03 standalone monitor. NT03 is now an option when selecting a machine's terminal.
Software:
•Added NT03 USB flash. Version 2.10.14
Vehicles Affected:
•Massey Ferguson: MF8125, MF8225, MF9130, MF9330, MF9335, MF9350Dry
•Valtra: BS2225H, BS2517H, BS3120H, BS3330H, BS3335H, BS3350H
Vehicle Version:
•2.6
General:
•SW Package update
Software:
•Sw version number updated
Vehicles Affected:
•Massey Ferguson: MF 6700S Stage 5 Series
•Massey Ferguson: MF 7700S Stage 5 Series
Vehicle Version:
•2.9
Diagnostics:
•Fixed some issues in diagnostic surfaces ?Signal inversion between X8 and X10 components on the Dyna-VT Gearbox Overview
?Connector inversion between X4 and X599 components on Dyna-VT PTO screens
Software:
•New Stage 5 engine software (49 LFTN D5)
?New 6.1.2 software release
?Improvement of cold start and cold climate calibrations
?Correction of CAN message sending Hi-idle 2160 rpm
•New Stage 5 engine software (66 LFTN D5) :
?Improvement of the diagnostic of the cross connection of exhaust gas temperature sensors
?Improvement of the diagnostic of the fault code for the boost pressure deviation
•New SRC14-34 software V6.01 for Dyna-6 models
?Fix calculation of consumption per area
?Fix wrong error code display when tractor does not have electronic hydraulic rear valves (0A.01.0E)
?Compliant with SRC14-34/32 hardware
•New SRC14-34 software V6.01 for Dyna-VT models
?Fix failure of the Hall effect sensor to get engine speed value (X25) by reading the value from engine ECU (CAN frame)
•New NT03 Embedded Software V2.10.14
?Major terminal update
•New NT03 Standalone Software V2.10.14 ?Major terminal update
Plug-Ins:
•New NT03 content ?Maintenance update (no additional features)
Vehicles Affected:
•Massey Ferguson: 2700-4700 Series
•Massey Ferguson: 6700R Series
•Massey Ferguson: Global Series 4700-5700-6700
•Valtra: A100
•Valtra: A100Hitech Series
•Valtra: A4, A4S
•Valtra: A4Hitech Series
•Valtra: AC51.5, AC52.5, AC53.5, AC54.5, AC55.5, AC56.5
Vehicle Version:
•6.6
General:
•Fix engine software for China F1004 models
Configuration:
•Handle value 40 kph for Label Code E in Dashboard for China market
•Fix reading of Auto7-ISC label code AA with software version 2.22.0
Software:
•New Engine Software for Tier4F 3 cylinder engines (33AWFC) ?Calibration of Exhaust After Treatment system to improve efficiency and catalyst performance at low load conditions
Vehicles Affected:
•Lely: Pro and Control
Vehicle Version:
•0.4
General:
•New Software
Software:
•Software Version 43 for PRO Terminals
Vehicles Affected:
•Fendt: Fendt tractor ACM support, X1000 Series
Vehicle Version:
•1.13
Software:
•Added ACM software version 4.01.36.
Plug-Ins:
•ACM -- ?Moved the file transfers to HTTP for improved speed and reliability
?Improved WiFi SSID collection method
?Fixed the replacement process from reporting a false success
?Add retries when unsuccessful in the activation process
?Improved version detection
?Added warning message if attempting to downgrade the ACM software
Vehicles Affected:
•Fendt: 8380P, 8380P AL, 8410P, 8410P AL, 9490X, 9490X AL
•Massey Ferguson: 7380, 7380 AL, 7382, 7382 AL, 9380, 9380 AL
Vehicle Version:
•2.21
General:
•New Software released: ?NT01 Version: 6822
Restored the functionality regarding the customization of a corn foldable header.
Vehicles Affected:
•Challenger: MT600E with TMC Display
•Massey Ferguson: 8700 with Datatronic 5 Series
•Massey Ferguson: MF 8700S Series
•Valtra: S4 with SmartTouch Display Series
Vehicle Version:
•5.70
Configuration:
•Update translation of SRC14 parameters for Finnish language
Software:
•New Stage 5 engine software V6.1.2 (84 LFVC D5)
?Improvement of the temperature alert diagnostic of the actuators of the Exhaust Gas Recirculation and the Wastegate
•New SRC14-34 software V6.01 for MF and Challenger models
•New NT03 Embedded Software V2.10.14 for MF models
•New NT03 Standalone Software V2.10.14 for MF models
•New SRC14-34 software V2.05 for VT models
?Major update
•New NT03 Embedded Software V2.5.3 for Valtra models
•New NT03 Standalone Software V1.5.3 for Valtra models
Plug-Ins:
•New NT03 content ?Add Feature Unlock for Auto Headland Management for Valtra
Vehicles Affected:
Vehicle Version:
•1.33
General:
•USB connection is forced to be connected for Complete Diagnostics on M/K Bus
Vehicles Affected:
•Massey Ferguson: 1700 Series
Vehicle Version:
•2.30
Diagnostic Tests:
•Add the glow plug relay diagnostic test and the DPF Regeneration indicator diagnostic tests.
Software:
Vehicles Affected:
•Fendt: Tigo Loader Wagon
Vehicle Version:
•2.6
General:
•Software Update - TIM
Software:
•1.36.1
Vehicles Affected:
•Fendt: C-Series 2015: 5275CA, 5275CPLA, 6335CA, 6335CPLA
•Fendt: L-Series 2015: 5255L, 6275L
•Laverda: M300 Series 2015: M300A, M310A
•Laverda: M400 Series 2015: M400A, M400LCA, M400LCIA, M410A, M410LCA
•Massey Ferguson: ACTIVA S Series 2015: 7345S, 7347S
•Massey Ferguson: BETA Series 2015: 7360A, 7360PLA, 7370A, 7370PLA
Vehicle Version:
•2.21
General:
•New Software released: ?NT01 Version: 6816
?NT05 Version: 6816
?NT02 Version: 6820
?EXT-LT Version 1.70
Restored correct functionality of 4WD icon appearing on NT01.
Vehicles Affected:
•Challenger: 644
•Fendt: 5220E
•Laverda: M200
•Massey Ferguson: 7244
Vehicle Version:
•4.4
General:
•New Stage V engine software for M180 combine released.
Vehicles Affected:
•Fendt: Momentum
•Massey Ferguson: Momentum
•Valtra: Momentum
Vehicle Version:
•2.7
General:
•New EXT SW to South America
•NT03 Plug-in update
Software:
•New EXT SW version 2.00.08
Plug-Ins:
•NT03 Plugin update
Vehicles Affected:
•Challenger: MT 700E, MT 800E, MT 900E
Vehicle Version:
•2.70
Software:
•Released MT 700E engine software files ?Error code SPN 520312 FMI31 disabled (Rail Pressure Control: Maximum time in limp home state is exceeded)led unnecessary error code
Plug-Ins:
•Updated ACM plugin version 5.8 to 5.22 ?Moved all CAN file transfers to HTTP for reliability
?Improved the WiFi SSID collection method
?Fixed a bug for the replacement process GUI saying success when the activation failed
?Added multiple attempts to retrieve an auth token when unsuccessful in the activation process
?Removed old ACM versions
?Added warning message to the ACM flash process if attempting to downgrade
Vehicles Affected:
•Challenger: 540C, 540E, 560C, 560E
•Massey Ferguson: 9540, 9545, 9560, 9565
Vehicle Version:
•4.50
General:
•Add EGR safety function in case of overheating
•Disabled Fault Code "SPN 520312-31 Rail Pressure Control: Max time in limp home state is exceeded", display not needed on T4F Stage4 engine
•T4F LRC Engine - Burning and Air System Calibration updated
Vehicles Affected:
•Challenger: RG900C, RG 1100C, RG 1300C, RG1300C HT
•Fendt: RG900C, RG 1100C, RG 1300C, RG1300C HT
•RoGator: RG900C, RG 1100C, RG 1300C, RG1300C HT
Vehicle Version:
•2.12
Diagnostics:
•Improved signal reporting data
Calibrations:
•Repaired the drive pump / wheel motor calibration signals in the chassis / steering connection
Configuration:
•Updated Chassis EXT configuration for 3.00.05 support
Diagnostic Tests:
•Opened safe mode boot without authorization
Software:
•Released Chassis EXT software package 3.00.05 ?Added support for SRC36-20-32 hardware
?Released bootloader BtEXTB0.22AGC for new EXT hardware support
?Implements: TeachIn Auto Turn Around
?Implements: SRC 32's Removes Flash Replaces with EEPROM, Adds Over-current Protection Rogator EXT
?Implements: TA Rear Sensor Calibration
?Implements: Updated Raven Guidance/4WS PropA Message
?Implements: Delta T
?Fixes: TeachIn System Buttons Don't work with MFA PropA interface
•Released Dashboard software package 703 ?New hardware support
•Released ACM 4.01.36 for GW03/GW04 hardware variants ?Enhancements for DoIP Flash capability with the ST122 tools
?Smart Connect API enhancements to enable Climate FieldView integration
?ACM Fuse Diagnostics Page re-design
?Updated ACM Handling of data when GPS lock is not available
?Enhancements/bugfixes to connectivity (Netherlands, Belgium, Chile)
?New vendor SDK to support new HW variant - cellular modem, cellular carrier
•Released New Leader WSM software 2.13.0.0 ?Added PropA message to support TC acre counter on NT01
•Released Raven Viper4 package 21.1.1.1 ?RELEASE NOTES ?Connect Workflow (Product Reconfiguration)
?Automatic Turn-Around with Vision steering.
?ENHANCEMENTS ?AREA REMAINING WIDGET ?Widget displays area remaining in a job based on area already applied within field boundary
?MULTI-LINE GUIDANCE ?Ability to load shapefile containing multiple guidance lines for a field.
?DEFECTS RESOLVED ?Various performance improvements to enhance stability and UI
?Fix issue with setting WIFI mode.
•Released Raven RCM package 21.1.1.1 ?Enable liquid products on spreader machine types for products 4+
?Fixed ISO GPS Speed scaling when GPS speed source is manually selected
?Added kiloseeds per pound application type
?Added spinner constant control mode for spreader spinner/fan products that will control to a target RPM with no active section width
?Added dynamic calibration scale type to air cart and generic machine types
?Increased planter blockage support with SGM from 16 to 24
?Added ISO Aux-N support to assign controllable functions to AUX-N switches (Master switch, section switches, auxiliary drivers, and quick start)
?Fixed individual section turn on/off times clearing on startup
?Increased aux driver count from 6 to 12
?Added cubic yards application type for liquid fertilizer tools
?Update blockage sensor assignment for multiproduct meter per section
?Added Romanian language support
?Fixed previous unused product showing up after update
•Improved the Raven file transfer rates
Plug-Ins:
•Updated Norac plugin version from 5.5 to 5.6 ?When Norac is not detected a validation list will be presented to pick UC5, UC7, or not installed
Vehicles Affected:
•Fendt: Rogator 300 MY19 & MY20
Vehicle Version:
•1.91.10
Software:
MY19 & MY20:
-Chassis ECU RG300M-C-01.01.00
Enhancements
•Increase wheel angle hysteresis to avoid sensor error during trail following
•Chassis ECU also compatible for 14-34/32 EXT
•Manual suspension up/down available for Isobus Joystick
•Update sprayer eeprom for manual PWM tilt valves
Fixes
•Suspension parameter fine-tuning for hilly conditions
Vehicles Affected:
•Fendt: RG344,RG355,RG366
Vehicle Version:
•1.3
Software:
•MY2021:
Enhancements
Fixes
Vehicles Affected:
•Challenger: RG300
•Fendt: RG300
Vehicle Version:
•1.13
Configuration:
•Avoid software update for 20-36/32 and 14-36/32 EXT
Vehicles Affected:
•Challenger: RG600
Vehicle Version:
•3.11
Software:
•Update C1000
Vehicles Affected:
•Challenger: RG600D Series MY16/17
•*Fendt:*RG600D series MY18
Vehicle Version:
•1.17
General:
Avoid updating 36-20-32 EXTs with current software (not compatible)
Note:
software versions of Chassis ECU, NT01,VD03, Novatel Antenna, and PVED must match, so please make sure all of these components have the up to date software installed.
Vehicles Affected:
•Fendt: Rogator 600 MY19/MY20
Vehicle Version:
•1.10
Software:
MY2020:
Engine: 6.1.1 REV.1
Chassis EXT: AGCO_RG600M-C_01.01.00
Enhancement;
•Compatibility for SRC14-34-32
Fixes;
•Fuel totals counter NT01 does not work correctly
•Fuel totals counter TC does not work correctly
Plug-Ins:
EEM4S5 version 1.8
Vehicles Affected:
•Fendt: RG645,RG655,RG665 MY2021
Vehicle Version:
•1.3
Software:
MY2021:
Chassis ECU: AGCO_RG600M-C_01.01.00
Engine: 6.1.1 REV.1
Enhancements
Fixes
•Fuel totals counter does not work (MY21)
•Trip Fuel & Def Reset message doesn't work for Stage 5 engine
Plug-Ins:
•EEM4S5 version 1.8
Note:
Software versions of Chassis ECU, NT01,VD03, Novatel Antenna, and PVED must match, so please make sure all of these components have the up to date software installed.
Vehicles Affected:
•Massey Ferguson: 5700 Dyna-4 Tractors
•Valtra: AC71.5
Vehicle Version:
•2.8
Software:
Vehicles Affected:
•Fendt: 5255 L, 5255 L PL, 6275 L, 6275 L PL, 5275 C, 5275 C SL 5275 C PL, 5275 C PLI, 6335 C, 6335 C PL, 6335 C PLI
•Laverda: M 300, M 300 LC, M310, M310 LC, M 400, M 400 LC, M 400 LCI, M410, M410 LC, M410 LCI
•Massey Ferguson: 7345 S, 7345 S PL, 7347 S, 7347 S PL, 7360, 7360PL, 7360 PLI, 7370, 7370 PL, 7370 PLI, 7360 AL 4
Vehicle Version:
•0.37
General:
•New software released: ?NT01 Version: 6816
?NT05 Version: 6816
?EXT-LT Version: 1.70
Added Authorization code pre-condition for reducing the maximum speed of Super Slope combine.
Introduced new diagnostic surface for 4WD change displacement (Super Slope only).
Vehicles Affected:
•Valtra: S3 Series
•Valtra: S4 Series
Vehicle Version:
•8.20
Software:
•New Transmission EXT SRC14 software V2.10 ?Compliant with SRC14-34/32 hardware
Vehicles Affected:
•Challenger: MT 700 Series
•Fendt: Vario MT 900 Series
•Challenger: MT 800 Series
•Fendt: Vario MT 1100 Series
Vehicle Version:
•2.8
General:
•Optimized connection script for 700/900 when no CAN is detected
Diagnostics:
•Added hydraulic valve heater signal to graphical surface diagnostics
•Disabled Hitch and/or steerable hitch surfaces when option is not present
Configuration:
•Updated the chassis EXT configuration manager for additional hardware based option support
Software:
•Released Chassis EXT software package 5.02.00 ?Added support for SRC36-20-32 hardware
?Minor HVAC bug-fixes
•Updated Fault trees and overrides for all model years
Plug-Ins:
•Updated the ACM plugin from version 5.8 to 5.22 ?Moved all CAN file transfers to HTTP for reliability
•Updated the MAN engine plugin from 2.16 to 2.18 ?Optimized parameters to match engine specification
?Added previous calibration value on LSU Adaption surface and increased number of decimal place
?Added shutdown instruction for SCR Dosing Rate Test
Vehicles Affected:
•Gleaner: S68, S78, S88
Vehicle Version:
•3.37
General:
•Disabled fault code "SPN 520312-31 Rail Pressure Control: Max time in limp home state is exceeded", displayed not needed on T4F Stage4 engine
Vehicles Affected:
•Gleaner: S96, S97, S98
Vehicle Version:
•5.61
Software:
•EXT Bootloader: 0.22
•EXT Application:21.04.003
Vehicles Affected:
•Massey Ferguson: T7
Vehicle Version:
•3.18
General:
•Added EGR safety function in case of overheating
•Disabled fault code "520312-13 Rail Pressure Control: Max time in limp home state is exceeded", display not need on T4F Stage4 engines
Vehicles Affected:
•Massey Ferguson: MF2604H, MF2605H, MF2606H, MF2607H, MF2625, MF2625, MF2630, MF2635
Vehicle Version:
•2.0
General:
•Added Models for Turkey market
Plug-Ins:
•Simpson V6.8
Vehicles Affected:
•Challenger: TG7300C, TG8300C, TG8400C, TG9300C
•TerraGator: TG7300C, TG8300C, TG8400C, TG9300C
Vehicle Version:
•1.83
Configuration:
•Updated Chassis EXT configuration for 1.01.00 support
Diagnostic Tests:
Software:
•Released Chassis EXT software package 1.01.00 ?Added support for SRC36-20-32 hardware
?Fixes: Drive Lever Acceleration Command Ignored At Times When Making Abrupt Stop
?Implements: RTX Wet Region CEAG Error 20.1.0D
?Implements: Max Fuel Tank Level
?Implements: PropA Button Messaging
?Fixes: Forward/Reverse Arrows By TerraGator Icon on NT01 Main Menu
?Fixes: fuel average not stored correctly
?Fixes: fuel rate calculation incorrect
Plug-Ins:
•Updated Norac plugin version from 5.5 to 5.6 ?When Norac is not detected a validation list will be presented to pick UC5, UC7, or not installed.
Vehicles Affected:
•Challenger: Big Square Balers: 2300 Series
•Fendt: Big Square Balers: 1290UD
•Massey Ferguson: Big Square Balers: 2300 Series
Vehicle Version:
•1.18
General:
•Added NT03 standalone support including flash support. Additional steps were added after model selection. New steps allow for the proper selection and visibility of monitors.
Software:
•Added NT03 USB flash package (2.10.14)
Vehicles Affected:
•Massey Ferguson: 3306F, 3307F, 3308F
•Massey Ferguson: MF 42XX
•Valtra: A Series
•Valtra: A63F, A73F, A83F, A93F
Vehicle Version:
•2.3
General:
•Fixed MF4400 Dashboard parameter
Software:
Vehicles Affected:
•Valtra: BH G4, BHG4 Hitech
•Massey: MF7300
Vehicle Version:
•3.2
General:
•Fixed VIN Procedure Record
•GFX750 Plugin Added
Configuration:
•Fixed to record VIN from any manufacture location
Plug-Ins:
•New Trimble GFX750 Plugin
Vehicles Affected:
•Valtra: T4-Series N4-series
Vehicle Version:
•1.66
Diagnostics:
•Tool tip names fixed and updated for all diagnostic pages
Software:
•AC26.5 (1.12.0.0) HARM 1.5.7.0 software added
•Fixes the problem with Selecto floating bug
•AC27.5 (1.12.0.0) HARM 1.5.7.0 software added
Vehicles Affected:
•Valtra: T4-series 1A7 / 1B8, N4-series 1B7 / 1C8
Vehicle Version:
•1.81
General:
•Translation terms of Feature Unlock parameters improved
Diagnostics:
•Tool tip text for Rear linkage setpoint potentiometer fixed
Software:
•AC34 (1.10.2) Transmission Controller software updated
•AC35 (1.10.2) Transmission Controller software updated
•AC36 (1.10.2) Transmission Controller software updated
•AC37 (1.10.2) Transmission Controller software updated
•NT03 Software 2.5.3 added for SmartTouch
•NT03 Software 1.5.3 added for StandAlone
Plug-Ins:
•CEA Guide v8.20, Removed the VIN from the filename of the temporary file created
•NT03 v2.10, Added new Feature Unlock parameters for Auto Headland Management, Digital front loader and Radio&Phone
Vehicles Affected:
•Challenger: 1000 Series
Vehicle Version:
•1.23
Software:
Plug-Ins:
•ACM - ?Moved the file transfers to HTTP for improved speed and reliability
Vehicles Affected:
•Challenger: MT600E Series
•Massey Ferguson: 8700 Series
Vehicle Version:
•6.8
Software:
Vehicles Affected:
•Challenger: MT400E Series
•Challenger: MT500E Series
•Iseki: i5700 Series
•Iseki: i6700 Series
•Iseki: i7700 Series
•Massey Ferguson: 5700S Series
•Massey Ferguson: 5700SL Series
•Massey Ferguson: 6700S Series
•Massey Ferguson: 7700 Made in Brazil Series
•Massey Ferguson: 7700 Series
•Massey Ferguson: 7700S Series
•Valtra: T195-250 Series
Vehicle Version:
•7.3
Configuration:
Software:
•New SRC14-34 LK software V05.00 ?Compliant with SRC14-34/32 hardware
•New NT03 Standalone Software V2.10.14 for MF models ?Major terminal update
Plug-Ins:
Release Notes - 6/2/2021 - Update 2021.3
EDT NOTES:
EDT Version: 1.101.21103.808
Bug Fixes:
•Minor updates for diagnostics.
Vehicles Affected:
•Valtra: T-Series, N-Series, A-Series
Vehicle Version:
•3.27
General:
•AC15.34, AC15.35, AC16.0 and AC19.34 removed from South America region
Diagnostics:
•4WD page for N3 / T3 Versu and Direct facelift added
•Cruise pages added for EEM3 Versu and Direct
•PTO data flow diagram page added for N2 / T2 tractors
•PTO Sigma page added for N2 / T2 tractors
Calibrations:
•Powershuttle, Powershift and Clutch Pedal names standardized on calibration page
Diagnostic Tests:
•Diagnostic help file added for Visco Fan Test
•Forced Engine Torque Curve tool set visible under diagnostic test tab
•Fault code descriptions updated
Plug-Ins:
•AG3000 v8.4, Fixed a bug with clearing the stored DTC codes
•PVED-CL v5.16, Fixed a problem with parameters write to the EEPROM
Vehicles Affected:
Vehicle Version:
•2.7
General:
•Add an improved calibration procedure for WAS Center (Steering, Middle position)
Plug-Ins:
•New CEA-Guide content ?Add VD03 V1.143 L26 version
•New ACM content ?Add Ukraine as a selectable country code in the replacement process
?Fix the read of hardware version in graphical surface for 411 devices
?Improve the detection of hardware version
?Update software V04.01.36
?Improve some graphical surfaces
Software:
•New SRC14-34 software V5.49 for Dyna-VT models ?Improve display of Memo A switch when Isobus function on lever is active in NT03 and tractor with T-Handle configuration
?Fix a bug on the steering system
?Fix delay to stop the PTO to be compliant with the regulation
?Fix the measurement of effort on rear hitch
Vehicles Affected:
•Valtra: A100
Vehicle Version:
•6.4
Software:
•New Continental software V2.09 ?Add some missing diagnostic signal for braking system
?Fix a bug of the save of counter hours
?Fix engine speed limitation during PTO clutch start phase
?Support engine curve 2 for Brazilian tractors
•New Transmission ISC software V2.21.0 ?Improve smoothness of shuttling
•New Linkage software V1.31.0 ?Remove PTO alarm in stationary mode on non MR tractors
Vehicles Affected:
Vehicle Version:
•6.4
Plug-Ins:
Vehicles Affected:
Vehicle Version:
•5.60
General:
Plug-Ins:
Software:
•New T4F engine software for models with new fuel tank (84AWF models - NA only) ?Cold start improvements
?Defrost timer improvement
•New SRC14-34 software V5.50 for MF and Challenger models ?Fix failure of the Hall effect sensor to get engine speed value (X25) by reading the value from engine ECU (CAN frame)
Vehicles Affected:
Vehicle Version:
•1.32
Software:
•GQS: 1.0.5.1266
•NT01:9.2.26
•AP Engine: 1.2.13 Rev.2 (All Regions)
•MAN Engine D3876LE125 for Western Europe, MY18, Class 9, with new temp. sensor rework
•MAN Engine D4276LE121, D4276LE122, Class 10
Vehicles Affected:
Vehicle Version:
•2.29
Software:
•Checksums for the 1700 engine flash have been corrected.
Vehicles Affected:
•Fendt: 4160V, 4180V, Rotana 130 F, Rotana 160 V, Rotana 180 V
•Lely: RP 130 F, RP 160 V, RP 180 V
•Massey Ferguson: RB 3130 F, RB 4160 V, RB 4180 V
Vehicle Version:
•1.8
Software:
•New Software 2.29.5
Vehicles Affected:
•Fendt: Rotana 130 F, Rotana 160 V
•Lely: RPC 130 F, RPC 160 V
•Massey Ferguson: RB 3130 F Protec, RB 3160 V Protec
Vehicle Version:
•1.6
Software:
•New Software 2.39.5
Vehicles Affected:
Vehicle Version:
•2.19
General:
•New software released: ?EXT-LT Version: 1.69
?NT01 Version: 6749
?NT05 Version: 6749
Vehicles Affected:
•Challenger: 644
•Fendt: 5220E
•Laverda: M200
Vehicle Version:
•4.2
General:
•M180 Stage V engine software: Version 6.1.1 Rev. 1
•5185 E Stage V engine software: Version 6.1.1 Rev. 1
•7340 Stage V engine software: Version 6.1.1 Rev. 1
Vehicles Affected:
•Fendt: RG344,RG355,RG366 MY21
Vehicle Version:
•1.2
Configuration:
•Add calibration option for upcoming plumbing change in configuration menu. Position of clean water tank sensor will be changed. (visible as pop up by software update)
Software:
MY2021:
-Sprayer ECU RG300M-M-01.01.00
Enhancements
•RGRU-1112 – Added peer control for N-sensors
•RGRU-1170 – Add section phasing buttons to separate softkey mask
Fixes
•RGRU-1146 – Fixed rate control eeprom load failure
•RGRU-1159 – Fixed autorinse does not move to the next step when there is foam in the tank
•RGRU-1183 - Fixed boom height control sensor selection listbox from appearing after VT reload
•RGRU-1052 – Fixed sections UI on main screen unclear when sections > 74
•RGRU-1204 – Fixed when pump is idle RMP is increased when switching 5 way valve
•RGRU-1117 - Boomfolding: reverted tilt speed so it matches with the progress bar again
Vehicles Affected:
•Fendt: RG645,RG655,RG665 MY21
Vehicle Version:
•1.2
Software:
MY2021:
Sprayer ECU: AGCO_RG600M-I_01.01.00
Enhancements
Fixes
Note: software versions of Chassis ECU, NT01,VD03, Novatel Antenna, and PVED must match, so please make sure all of these components have the up to date software installed.
Vehicles Affected:
•Valtra: AC71.5
Vehicle Version:
•2.7
General:
•Add Tier3 models
Software:
•New Dashboard IC1 software V1.64 for MF ?Fix the delay to stop the PTO to be compliant with the regulation
?Compatibility with Tier3 Engine without urea
Vehicles Affected:
Vehicle Version:
•0.34
General:
•New: ?EXT-LT Version: 1.69
?NT01 Version: 6749
?NT05 Version: 6749
?M410, M410 LC, M410 LCI Stage V engine software: Version 6.1.1 Rev. 1
?6335, 6335 PL, 6335 PLI Stage V engine software: Version 6.1.1 Rev. 1
?7370, 7370 PL, 7370 PLI Stage V engine software: Version 6.1.1 Rev. 1
?General diagnostic graphical surfaces updates
Vehicles Affected:
Vehicle Version:
•2.02
Software:
•Released Chassis EXT software package 5.01.02 ?Updated Transmission parameters to lower HM2 clutch speeds
Vehicles Affected:
Vehicle Version:
•5.53
Software:
•VD03:3.143
•Novatel Smart7:ES7PR0603RN0000
•Trimble AG-382:9.38.007.4
•Engine file updates for S97, S98 models.
Vehicles Affected:
Vehicle Version:
•7.3
Plug-Ins:
Software:
•New T4F engine software for 6700S tractors (49AWF models) ?Update of emission calibration to fix issue with emission fault code
?Improvement of the parameter of governor speed to fix the issue of engine speed instability
?Improvement of defrost time of the DEF
•New CCD/C1000 Software V3.4.4 ?Fix data transfer with USB stick
•New Dashboard IC1 software V5.8.7 for Dyna-4 and Dyna-6 tractors ?Possibility to assign 2 functions to H3/H4 in loader mode
?Fix the issue of the flow setting of the 3rd Live loader spool valve
?Fix issue of the front linkage which was impossible to lock
•New Dashboard IC1 software V5.3.9 for Dyna-VT tractors ?Possibility to assign 2 functions to H3/H4 in loader mode
•New SRC14-34 LK software V04.16 ?Improve guidance behaviour when speed is above 10 kph
?Fix ISOBUS issues
?Fix issue on front hitch trigger
?Add the possibility to set up to 50 cm the mounting error offset
