Darylxd
3
22,058
AGCO EDT 2025.4.OC2 09.2025 Electronic Diagnostic Program
Download this document, you need 18750 Gallons
Size: You need to prepare 150GB free space in disk C for good installation
Interface Languages: English, Dutch, French, Finnish, German, Spanish, Portuguese, Danish, Russian, Polish, Italian, Turkish, Swedish, Chinese, Norwegian Bokmål.
Database Languages: Only English
Type of Program: AGCO EDT (Electronic Diagnostic Tool)
Type of vehicle: Agricultural
Update: 09.2025 2025.4.OC2
OS: Windows 10, Windows 11 64 & 86 bit (Tested on Windows 10 Pro 22H2 64-bit)
Send an email to get the password: "admin@autorepairmanuals.ws, Gallons@autorepairmanuals.ws"
NOTE: " DO NOT HAVE FENDIAS IN THIS AGCO EDT"
Release Notes – 9/8/2025 – Update 2025.4.OC2
EDT NOTES:
EDT Version: 1.128.25190.1121​
Vehicles Affected:
  • Massey Ferguson: 2706e, 2760e
Vehicle Version:
  • 2.9
Release Notes – 8/27/2025 – Update 2025.4
EDT NOTES:
Bug Fixes:
Enhancements:
  • Updated WinSCP to version 6.5.2
  • Minor improvements to diagnostic functionality.
Vehicles Affected:
  • Challenger: WR9900 Series
  • Massey Ferguson: WR9900 Series
Vehicle Version:
  • 1.67
Software:
  • NT03 v5.00.17
    • Fix header float conversion between imperial and metric
    • Fix USB icon stays active when USB is removed
    • Fix secondary monitor freeze in some circumstances
    • Fix primary monitor crash when shifting into rear steer
    • Fix guidance overlap not being maintained in both directions
    • Fix not applying overlap after key switch but still showing right value
Vehicles Affected:
  • Massey Ferguson: Square Balers: 2224, 2233, 2234, 2234XD, 2244
  • Fendt: Square Balers: 990, 1270, 1290, 1290XD, 12130
Vehicle Version:
  • 1.37
Diagnostics:
  • Add virtual CAN-Bus to monitor availability of ECUs while connected to ISOBUS connector.
  • Make backup of EEPROM before upgrading software
Configuration:
  • Add possibility to change electronic/mechanical knotter trip without an authorization key
Software:
  • EXT 01.14.01
    • Fix sending amount of cut bales to ACM and Infotrac at startup
    • Fix sending cutter override alarm when override is active and not only while button is pressed
    • Change delay for missing machine speed to 60 seconds to give ACM time to get started
    • Fix having active parking brake alarms after parking brake has been turned off
    • Fix displaying a double indicator when both load bullets are not sending values
    • Improve load bullet diagnostics
    • Fix having infobox items available for moisture system that was previously connected
Vehicles Affected:
  • Challenger: 660B made in Brazil, 670B made in Brazil, 680B made in Brazil
  • Massey Ferguson: 9695 made in Brazil, 9795 made in Brazil, 9895 made in Brazil
  • Valtra: BC6800, BC7800, BC8800
Vehicle Version:
  • 1.36
Configuration:
  • The “internal error” no longer occurs when opening the Combine Setup configuration page.
Vehicles Affected:
  • Challenger: 520C
  • Challenger: 540C
  • Challenger: 560C
  • Massey Ferguson: 9595S
  • Massey Ferguson: 9695S
  • Massey Ferguson: 9795S
  • Massey Ferguson: 9895S
  • Valtra: 6800
  • Valtra: 7800
Vehicle Version:
  • 1.62
General:
  • Software update for EMU and VMM, replacement of the MVEC with HCDM
  • Guidance System only AGS-2
  • Monitor only X35
Diagnostics:
  • Shaft Speeds: added block with active tailboard – spinners speed
  • Replaced all the relays of MVECs with HCDMs
Configuration:
  • Added 2 more options for discharge type: Chopper -active tailboard, straw spreader – Hyd
Software:
  • VMM ver. BB: 5.38 b63; LL: 0.66 b101
  • EMU ver. 6.6
Plug-Ins:
  • Removed AGCOCOMMAND, AG3000
Vehicles Affected:
  • Massey Ferguson: 2700-4700 Series
  • Massey Ferguson: 6700R Series
  • Massey Ferguson: Global Series 4700-5700-6700
  • Valtra: A100
  • Valtra: A100Hitech Series
  • Valtra: A4, A4S
  • Valtra: A4Hitech Series
  • Valtra: AC52.5, AC54.5, AC56.5
