Newest Software Full Updated 06.2017 - Challenger - Fendt - Massey Ferguson [06.2017] - Jaguar EPC + VIN [06.2017] - TOYOTA & LEXUS EPC [04.2017] - Microcat KIA [04.2017]- Nissan & Infiniti Fast EPC [06.2017]- Mazda EPC II [01.2017]- Volvo Penta EPC [06.2017] - SM EPC Hyundai and KIA v3.0 [06.2017] - Scania Multi [03.2017] - JCB ServiceMaster 4 v1.59.3 [06.2017] - HINO DX2 [2017] - Perkins SPI2 2016A [01.2016] - Honda HDS [06.2017] - Forklift ProSecCo KG 2016 v2 - GROVE Crane Full Set Manual DVD - ISUZU IDSS II + Updates [02.2017] - Kobelco Crane Full Set Manual - VOLVO PROSIS Offline Part & Repair [09.2016] - Valtra Epsilon Service [05.2017]- VALTRA Epsilon EU Part [05.2017] - FENDT EU Service [05.2017] - FENDT EU Parts Catalog [05.2017] - Challenger Epsilon Service [05.2017] - Challenger Epsilon Parts Europe [05.2017] - Mitchell Estimating (UltraMate) v.7.1.220 [05.2017] - Meritor WABCO TOOLBOX 12.4 English [05.2017] - Man Mantis v557 EPC [02.2017] - Microcat Ford Europe [01.2017] Full - Doosan Infracore GPES 2017 - Kobelco 2015 Electronic Spare Parts Full - Microcat KIA [02.2017] Full - BMW KSD2 [03.2017]-
Service Reset Advice
Discussion in 'Cars Troubleshooting' started by Root, Jan 7, 2013.
  1. Root
    Root Donator Staff Member
    Aug 31, 2012
    244
    12
    18
    If you download this document, you will be lost 0 Gallons
    CLICK HERE DOWNLOAD
    Email Support : autorepairmanuals.ws@gmail.com
    IMPORTANT: All of the below procedures are to be undertaken at your own risk. While they do work the vast majority of the time and are the methods used by professionals, there is always an element of risk. Please do not follow any of these procedures unless you understand this.
    This list will continue to be updated from time to time. It is NOT in alphabetical order and is not supported by us in any way. We do sell suitable tools that cover some vehciles which are fully supported, but the information here is not supported in any way and is for your information only.
    Audi A3
    Display reads, "Service!" when you first start the car.
    1. With the ignition key in the off position, push and hold the right button under the speedometer. This is the button you use to reset the trip odometer also.
    2. Turn the ignition key to the on position, but don't start the engine. Keep holding down the right button while you turn the key.
    3. Push the left button under the tachometer. Your service light should reset to say something like "Service in 7000 miles."
    Also try this switch ignition on (do not start) pull and hold right button (display show how many km over before oil service) let go pull again and hold after a few seconds it will clear ------- and then show 15 000 km to next service and 365 days left.
    Audi A4 & A6 - 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006
    Turn off the ignition
Press and hold the button on the left side of the display while turning the ignition on - Service OIL will be displayed
    Pull out the button on the right side of the display until the service prompt is cleared
    The display should now read ----
    If the above procedure does not work, below is an alternative procedure:
    With the ignition off, push the right button
    Turn the ignition on and then pull the left button
    Turn off ignition
    Audi All Road - 2000, 2001, 2002, 2003, 2004
    With ignition off, press and hold the button on the right hand side of the instrument panel. Turn ignition on and release the button. ‘Service’ or ‘Service In xxx Mi’ will appear in the display. Press the button on the left hand side of the instrument panel to the left until the display clears. Turn ignition off.
    Audi Cabriolet
    With ignition off, press and hold the middle button on the right hand side of the instrument panel. Turn ignition on, release button. ‘Service’ or ‘Service In xxxx MI’ will appear in display. Press right hand button on right side of instrument panel until display clears. Turn off ignition.
    Audi S4 - 1998, 1999
    Press and hold button on the right side of instrument panel. Turn ignition to the ‘on’ position. ‘Oil’ or ‘Service Oil’ will appear in the display. Release the button and then pull out the button on the left side of the instrument panel unit ‘----‘ or ‘service----‘ appears. Turn ignition off.
    Audi S4 - 2000, 2001, 2002
    With ignition off, press and hold the button on the right hand side of instrument panel. Turn ignition to on, release the button, then ‘service’ or ‘service in xxx mi’ will appear in the display. Turn the button on the left side of the instrument panel to the left until the display clears. Turn ignition on.
    Audi S4 - 2004, 2005, 2006
    With ignition off, press and hold the middle button on the right hand side of the instrument panel. Turn ignition to on, release button, ‘service’ or ‘service in xxx mi’ will appear. Press right hand button on right hand side of instrument panel until the display clears. Turn ignition off.
    Audi S6 - 2002, 2003
    With ignition off, press and hold the button on the right hand side of the instrument panel, turn ignition on and then release the button. ‘service’ or ‘service in xxx mi’ will appear in the display, press button on the left side of the instrument panel to the left until the display clears. Turn ignition off.
    Audi TT - 2000, 2001, 2002, 2003, 2004, 2005, 2006
    With the ignition off press and hold the button on the right side of the instrument panel, turn ignition on and release button. ‘Service’ or ‘service in xxxx mi’ will appear in the display. Turn the button on the left side of the instrument panel to the left until the display clears. Turn ignition off.
BMW - 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009
    Ignition off and then press and hold the trip odometer button while turning key to position 1 Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display*
Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 seconds
Note: that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset *Note: On vehicles with "High" cluster, you will also see the amount of fuel remaining until next service
    BMW E60
    Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (this step is critical, otherwise you get to the "Service" menu).
    1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
    2. Press the odometer-reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
    3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
    4. If you want to reset the Brake Fluid interval for another 2 years
then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
    5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
    6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
    7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
    Hints & Tips: before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again.
    BMW E90
    1. Insert key into slot
    2. Press start/stop button without depressing clutch/brake and wait for the service reminder to dissapear.
    3. Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
    4. You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
    5. When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
    6. You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
    BMW E46
    - Press and hold trip meter button down and turn ignitiion key to accesory position.
    - Hold until you see 'reset'.
    - Release and immediately press and hold again for 5 seconds, until 'reset' flashes.
    - Release and press again.
    Citroen C4
Switch off the ignition and then turn key to position S, steering lock Press control 1 - keep pressed
Switch on the ignition
Keep control 1 pressed until the zero appears and the maintenance symbol disappears
*Control 1 is the "Trip" button on the top of the dash in front of the speedo
    Ford Galaxy
    • With the ignition off, press the reset button under the mileage counter
• Hold in reset button whilst turning the ignition on • After about 4 or 5 seconds (up to 30 seconds in some cases) the
display should reset itself • Release the button and turn the ignition off • It may be necessary to repeat this process
    Ford Mondeo Mk4
    1. Close all doors.
    2. Turn the ignition key to position II.
    3. Simultaneously press the accelerator pedal and the brake pedal and hold for a minimum of 15 seconds.
    4. The oil change reminder indicator will turn off. This confirms that the reset procedure has been correctly completed.
    Ford Transit
    -turn contact off.
    -press brake and accelerator at the same time
    -hold for 30 secs, when the service lamp starts blinking, release pedals and the light goes off until your next oil change is due.
    Ford Transit
    Turn your ignition of .Then press the brake pedal and Accel pedal right down .Turn your ignition back on but do not start the engine KEEP THE PEDALS PRESSED the service spanner will go out still keep the pedals pressed and about twenty seconds later it will pop back on and flash.
Take your feet of the pedals turn the ignition of then back on your service light will go out and stay of for another 15000 miles.
    Mercedes Benz 300 Series
    Switch ignition on. The standard display of the control system appears. Press the up or down button on the multifunction steering wheel until the FSS indicator appears in the multifunction display.
    Press the reset button for about four seconds. This message will appear in the multifunction display: SERVICE INTERVAL? RESET WITH R BUTTON FOR 3 SEC.
    To confirm, fold down the reset button for about four seconds. The service indicator will now display the reset interval.
    Mercedes A Class
    Turn the key to position 2 in the ignition lock and immediately press
    button 000.0 twice within the space of one second.
    Turn the key to position 0 in the ignition lock.
    Press and hold button 000.0 Turn the key to position 2 in the
    ignition lock. Keep button 000.0 pressed.
    Service message with current remaining distance or remaining time
    appears.
    After about 10 seconds, an acoustic signal will sound and the service
    display with the new starting distance or starting time appears for
    about 10 seconds.
    Release button 000.0
    Mercedes C Class
    Turn key to position 2. press the button to show the service due light. release button. turn key off. press and hold the same button to view the service light, within 2 second turn key to position 2. wait up to 10 second and the light will reset to show new service. This may take a couple of trys (make sure the doors are shut).
    Mercedes Sprinter
    - Switch ignition on to position one, (first click clockwise);
    - "Outside temperature" should be displayed, if not move to it (You have to be in this display to go further);
    - Press the trip odometer, "reset", knob three times consecutively ( The Voltage display will appear);
    - Press Down Arrow to enter the "Service Menu". "Service Data" submenu below will be highlighted.
    - Press right page to enter the Service data submenu. (Left page goes up in menus, -+ selects items displayed)
    - Press - three times on right of wheel to highlight "Confirmation".
    - Use right page to select to display sub-menu as to what to confirm.
    - Select "Full Service" (No need to use -+.) to confirm this choice
    - Press right page to confirm. (Delay is about 3 seconds.)
    - Press left page twice to exit the menu system, or turn off the ignition switch.
    - Turn off ignition. Turn back on. The display should show that it is recalculating the mileage and days. This takes about 60 seconds so be patient.
    Mercedes Vito
Immediately press button M once (sometimes needs pressing twice)
Within ten seconds turn key back to 0
Press button M again and hold while turning key back to 2
Keep button pressed till you hear long beep and new service interval is displayed
Mercedes C-Class, E-Class, S-Class, CLK
    Using the button located on the left hand side of instrument cluster. Switch ignition on and immediately press button twice. Switch ignition off. Press and hold button while switching ignition on. After 10 seconds the new interval will appear in the display. Release button.
    Nissan Movano:
    The procedure for this re set is as follows: Switch the ignition ON.
Press and HOLD the accelerator pedal fully down. Then - Press the brake pedal 3 times.
The service indicator will now clear. Release pedals and switch IGN OFF.
    Peugeot 206
    Switch off ignition.
    Hold in the button under the rev counter (Trip reset button) and turn ignition key to first 'on' position without starting the engine.
    Hold the button for about 10 seconds and a countdown should show and run from 10 to 0 then spanner symbol service light should go off. Release button and trip meter will read 0.0.
    Peugeot 306
    hold down the mileage reset button, switch ignition to the first click, should count down from 10 to 0, service light is reset.
    Renault Clio III 2006>
    1. Switch ignition ON.
    2. Press and release display reset button A or B on the tip of the wiper lever until
the ‘Distance Before Next’ service information is displayed.
    3. Continue to depress the button for 10 seconds until the display shows the distance to next service permanently. The indicator will then show the appropriate service interval (e.g. 6000 miles/10000 km).
    4. Release the reset button.
    5. Switch ignition OFF.
    Renault Scenic II 2003>
    Scroll through the trip computer using the button on the end of the right hand stalk control until you get to the miles till service indicator (or the "change oil soon message" will appear if due)
    Then press and hold the same button in and hold it.. The miles indicator will then flash then change to 18000, keep the button pressed until the 18000 stops flashing..
    Seat Altea
    press mileage reset button and hold it while turning ignition on
turn left/right (for days remaining/spammer) and hold the button for 2 seconds until reset to 0 is indicated
wait for 5 seconds and then turn the ignition on and start car – light should now be out
    Vauxhall - 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009
    • Turn Ignition Off • Hold Trip Reset In • Turn Ignition On • Still Holding Trip Reset wait for three dashes • Turn off Ignition • Turn on Ignition to confirm
    Reset service indicator on Vectra C, Astra H, Corsa C & D
Simply press the trip reset button on the dash at the same time press the brake pedal then switch on the ignition, keep brake and trip pressed for 10 to 12
    Vauxhall Vivaro:
    To reset the engine oil life monitor: The procedure must be completed within 10 seconds after switching on ignition.
1. Switch on the ignition, but do not start the engine,
2. Depress accelerator pedal fully and hold in this position,
3. Depress foot brake three times consecutively,
4. Release accelerator pedal and then turn off ignition.
    Volkswagen VW (with digital Odometer)
    The code on the mileage display when you start the car will read "IN01", "IN02" or similar. To clear this, use the following procedure (this should work on any VW with a digital odometer):
    With the key out of the ignition press the odometer reset button and hold it down Turn the ignition on (warning lights come on) wait about 10-15 sec until most or the lights are off (still pressing odometer reset button) Turn ignition off (button still pressed) and remove the key
Release reset button Interval should now be reset. If this is not the case, repeat the above procedure
    Volvo 1999, 2000 - S / V / C70 Models
    Press and Hold odometer reset button Turn ignition switch to "run" position After SRL flashes, release odometer reset button Turn ignition off Turn ignition back on to confirm reset
    Volvo 1998 - S80 Models
    Turn ignition switch to position 1 Press and hold the odometer reset button Turn ignition switch to position 2 Wait until service light blinks and then release odometer button
    Volvo 1999, 2000 - S80 Models
    Turn ignition switch to position 1 Press and hold "day counter reset button" Turn ignition switch to position 2 Continue holding day counter for approx. 10 seconds After SRL flashes, release day counter button Should hear "beep-beep" to confirm command accepted
    Volvo 2001 - XC 70 Models
    The following steps must be completed with no longer than 5 seconds between each step:
Make sure the trip meter is in T-1 Turn ignition key to position 1 Press and hold trip meter button until zero is shown While still holding the trip meter, turn key to position 2 When original trip mileage returns, release the trip reset button Turn key to off
  2. Karstein Eriksen
    Karstein Eriksen
    Nov 17, 2016
    1
    1
    Gender:
    Male
    Eina
    Is there no repair manual for Opel Vectra C (2004)?
Share This Page
If you get any error about link download please contact us: autorepairmanuals.ws@gmail.com
