Approved "WESTERN UNION" Transaction on forum- Newest Software Full Updated 08.2017 - Mercedes-Benz EPC [07.2017] - Mercedes-Benz WIS-ASRA NET [07.2017] - Scania Multi [05.2017] - Subaru EPC USA [03.2017] - Subaru EPC EUR & GEN LHD & RHD [05.2017] - Multiecuscan 3.7 [07.2017] - Prosecco Multi KG V4 + ProSecCo Activator - Terex Fuchs Service Manual Diagnostic [02.2016] DE - Deutz Serpic 2012 [02.2012] - Mitsubishi Forklift Trucks Eparts 5.10 [06.2013] - Toyota Techstream V12.20.024 [07.2017] - Man Mantis v558 EPC [03.2017] - Clark ForkLift Parts Pro Plus v454 [07.2017] - Hyundai Microcat [05.2017] - Liebherr Full Shop Manual DVD - Tadano Full Shop Manual DVD - Takeuchi Full Set Manual DVD - Terex Crane Full Manual DVD - Hyundai E-Catalogue [01.2015] - Clark ForkLift Parts Pro Plus v452 [06.2017] - Honda EPC General [05.2016] - BMW ETK [07.2017] - Renault CAN CLiP v169 [06.2017] - Heavy Equipment and Truck Full Set Download 2017 - MITSUBISHI Forklift Truck Full DVD - TOYOTA Forklift Truck Full DVD - Clark Forklift Truck Full DVD - Toyota Industrial Equipment EPC v1.99 [06.2017] - TruckCom BT TE 2.10.6 [05.2016] - VOLVO PROSIS [02.2017] Full - Cummins InCal Unpacker 2016 v4- Perkins SPI2 2016A [01.2016] - Perkins SPI2 v2016A License - Challenger - Fendt - Massey Ferguson [06.2017] - Jaguar EPC + VIN [06.2017] - TOYOTA & LEXUS EPC [04.2017] - Microcat KIA [04.2017]- Nissan & Infiniti Fast EPC [06.2017]- Mazda EPC II [01.2017]- Volvo Penta EPC [06.2017]
Renault CAN CLiP v169 [06.2017] Full Patch + Instruction
Discussion in 'Automotive Manuals, Softwares' started by auto, Jul 11, 2017.
  1. auto
    auto S-Mod
    Sep 3, 2012
    1,780
    458
    83
    If you download this document, you will be lost 1000 Gallons
    CLICK HERE DOWNLOAD
    Email Support : autorepairmanuals.ws@gmail.com
    Type: Renault Diagnostic Tool.
    Region: All Region
    Language: English (Multilangual)
    Version: v168
    Developer: SPX
    Platform: WinXP, Vista, Windows7
    Year: 05.2017
    Medicine: Present
    Pass: THANKS + PM Email "autorepairmanuals.ws@gmail.com"
    Renault CLIP - the latest diagnostic tool from Renault. It contains all the latest diagnostic technology and information base to address all issues.
    Extras. Info: If the primary installation, follow the instructions, which is attached. If you already have an earlier version, it is recommended to uninstall and then follow the installation instructions.
    It only works with original CLIP adapter or with a Chinese clone, no adapters and KL KKL is not supported.
    Renault has developed a diagnosis system called Valise Clip. Hooked up to the car through OBD2 connector, it runs a complete test automatically, checking a series of parameters and identifying problems that can then be solved.
    Program dealer car diagnostics Renault, Dacia, Samsung.
    1. After Instalaltion finish DO NOT run your CLiP!
    1st replace the original RSWin.exe file (backup 1st your original file!!!)
    with the Cracked .exe file in C:\CLIP_X91\Lib\Application\
    2. Now from the SAME location as you are (C:\CLIP_X91\Lib\Application\) run the RSWin.exe,
    choose "Register me now" and in the next window select "NO"!
    3. Use this Key for Registration: 333DEF-111DEF-111DEF-222DEF-221DEF-000DEF
    It will work till 31/12/2020
    4. Now as you are, RESTORE your original RSWin.exe and REMOVE the patched one!
    (Just keep a backup from the patched file somewhere...)
    5. From your Desktop anymore, run your CLiP, accept the Terms and CLiP it will load.
    You Done! :)
    SPECIAL NOTES:
    Maybe when you try to make your 1st REAL Diagnosis you received an "Error" (about CLiP Damaged...)
    try to Update your PC with ALL the Latest Windows Updates! IF again the SAME "Error"
    then use 1x other PC or Roll-Back to Version V116! CLiP it seems, she no likes some PC's!
    Also when you will make your Registration, try to have your PC On-Line to the Internet!
    IF you NOT able to use 1x other PC and you insist to use this Latest Release,
    then you can post your S/N and you will got your personal Registartion Key.
    For this workaround you will need to use your ORIGINAL RSRWin.exe and also 1st of all to
    DELETE these 2x files: "reg.xml" & "ntuser.dat" from your:
    C:\Documents and Settings\All Users (Windows XP)
    C:\ProgramData (Windows 7 32Bit)
    NOTE: BEFORE to delete your reg.xml file, open it & note somewhere your COMPLETE S/N!
    Enjoy & Good Clipping!
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    gaga1978 likes this.
  2. Loading...
    Similar Threads
    1. auto
      2
      502
    2. auto
      2
      565
    3. auto
      2
      1,457
    4. truck
      2
      888
    5. truck
      2
      952
    6. truck
      2
      620
    7. truck
      2
      776
    8. truck
      3
      1,370
    9. truck
      8
      1,707
    10. auto
      1
      1,026
  3. fordauto
    fordauto
    Nov 25, 2015
    61
    1
    8
    Thanks for your sharing. It is full and usefull for me.
  4. softall
    softall
    Sep 29, 2012
    541
    31
    28
    Thanks for your sharing !
  5. Hyundai
    Hyundai <img src="/images/title/JuniorMember.png">
    May 25, 2014
    200
    3
    18
    Dear you thanks for coming please download it if you need
  6. Poloni
    Poloni
    Sep 18, 2013
    577
    77
    28
    I really need it thanks.
  7. terexvn
    terexvn
    Jun 29, 2015
    546
    3
    18
    Good job thanks for coming.
Share This Page
If you get any error about link download please contact us: autorepairmanuals.ws@gmail.com
