Hyundai
80
157,770
ZF Transmission CP190 CP210 CP230 Stage 3 Repair Instructions Manual
Brand: ZF
Type of Machine: Transmission
Type of Manual: Repair Instructions Manual
Model: ZF CP190 CP210 CP230 Stage 3 Transmission
Number of Pages: 190 Pages
1 Preface
1.1 Document overview​
2 Safety
2.1 Signal words and symbols​
2.2 General safety instructions​
2.3 Product-specific safety instructions​
3 Notes on Repairs and Assembly
3.1 General Notes​
3.2 Cleaning the ZF product​
3.3 Dismantling the ZF product​
3.4 Assembling the ZF product​
3.5 Cleaning parts​
3.6 Reusing parts​
3.7 Replacing parts​
3.8 Reworking parts​
3.9 Cleanliness specifications for transmissions with hydraulic components​
4 Technical Data
4.1 Oil​
4.2 Type plate​
5 Settings
6 Tightening Torques
7 Workshop Equipment
7.1 Special tools​
7.2 Standard tools and fixtures​
7.3 Operating supplies and auxiliary materials​
8 Preparatory Activities
8.1 Clamping transmission​
8.2 Draining oil​
9 Dismantling
9.1 Removing the parking brake​
9.2 Removing the pressure filters​
9.3 Removing the control unit​
9.4 Remove and dismantle shift system​
9.5 Remove and dismantle duct plate​
9.6 Removing the speed sensors​
9.7 Removing the cover plates​
9.8 Removing the hydraulic oil pump​
9.9 Removing the engine connection​
9.10 Removing the output flanges​
9.11 Remove hydrostatic unit​
9.12 Removing the oil level indicator and the cover plate​
9.13 Disassembling the front and the rear sections of the housing​
9.14 Removing and dismantling the output shaft​
9.15 Removing and dismantling the power take-off​
9.16 Remove and dismantle clutches, planetary drive and shaft​
9.17 Dismantling the housing rear section​
9.18 Dismantling the housing front section​
10 Assembly
10.1 Assembling the housing front section​
10.2 Assembling the housing rear section​
10.3 Assemble and install planetary drive, shaft and clutches​
10.4 Assembling and installing the power take-off​
10.5 Mounting and installing the output shaft​
10.6 Assembling the housing front and rear section​
10.7 Installing the cover plate​
10.8 Installing the oil level indicator​
10.9 Install hydrostatic unit​
10.10 Installing the output flanges​
10.11 Installing the engine connection​
10.12 Installing the hydraulic oil pump​
10.13 Installing the cover plates​
10.14 Installing the speed sensors​
10.15 Assemble and install duct plate.​
10.16 Assemble and install shift system​
10.17 Installing the control unit​
10.18 Installing the filter heads and the pressure filters​
10.19 Installing the parking brake​
10.20 Adding oil​
11 Annex
11.1 Overview of revisions​
