Driver
128
487,981
Yale Forklift G878E GP60VX to GP80SVX Parts Manual 550213085 05-2024
Brand: Yale
Type of Machine: Forklift
Model: GP60VX, GLP60VX, GDP60VX, GP70VX, GLP70VX, GDP70VX, GP70VXS6, GP70VXS9, GP70SVX, GP70SVX9, GP80VX, GP80SVX (G878)
Part Number: 550213085
Publication Date: 05-2024
Number of Pages: 1048 Pages
GENERAL TRUCK
OPERATOR COMPARTMENT PLATFORM
COWL MOUNT
HOOD ASSEMBLY
HOOD ASSEMBLY RAISED COUNTERWEIGHT
HOOD LINERS RAISED COUNTERWEIGHT
FLOORPLATES, STEPS AND COVERS
COUNTERWEIGHTS AND REAR FENDERS
INTERIOR PANELS AND COVERS WITH OVERHEAD GUARD
INTERIOR PANELS AND COVERS WITH CAB
OVERHEAD GUARD
CAB ATTACHING PARTS
CAB WINDOWS AND WINDOW WIPER SYSTEM
CAB MAIN ASSEMBLY
CAB STEEL DOORS - LEFT AND RIGHT
CAB SLIDING WINDOW ASSEMBLY - LEFT AND RIGHT DOOR
CAB HEADLINER ASSEMBLY
CAB SEAT RESTRICTION
SEAT PAN AND COVERS WITH CAB
CAB HEATER AND HOSES - PSI 4.3L LPG
CAB HEATER AND HOSES KUBOTA DIESEL WITHOUT SCR
CAB HEATER AND HOSES KUBOTA DIESEL WITH SCR
CAB HEATER - WITHOUT AIR CONDITIONING
CAB HEATER CONTROL - WITHOUT AIR CONDITIONING
CAB HEATER - WITH AIR CONDITIONING
CAB HEATER CONTROL - WITH AIR CONDITIONING
CAB AIR CONDITIONING SYSTEM - 3.8L DIESEL DOC AND SCR
CAB AIR CONDITIONING SYSTEM - 3.6L DIESEL
CONDENSER ASSEMBLY
NON SUSPENSION SEAT WITHOUT ELECTRONIC CONTROLS
FULL SUSPENSION SEAT MANUAL AND ELECTRO-HYDRAULICS - SWIVEL AND NON SWIVEL - SHEET 1 OF 4
FULL SUSPENSION SEAT RECLINER AND DAMPER KITS - SHEET 2 OF 4
FULL SUSPENSION SEAT SERVICE KITS FOR NON SWIVEL AND SWIVEL - SHEET 3 OF 4
SEAT ATTACHING PARTS NOT INCLUDED WITH SEAT - SHEET 4 OF 4
FULL SUSPENSION SEAT HIGH BACK WITH LUMBAR ADJUSTMENT - PAGE 1 OF 2
FULL SUSPENSION SEAT HIGH BACK WITH LUMBAR ADJUSTMENT - PAGE 2 OF 2
SEAT SCISSORS HEAVY DUTY - SWIVEL AND NON-SWIVEL SEATS
ARMREST SLIDER ASSEMBLY
SOUND ABATEMENT
LABELS MINI LEVER MODULES - SINGLE FUNCTION
LABELS HYDRAULIC CONTROL LABELS - CONTROL LEVER
LABELS EXTERIOR
LABELS INTERIOR
LABELS RADIATOR
LOAD BACKREST EXTENSION
FORKS BOLZONI
FORKS CASCADE - OPTIONAL
REAR SUBFRAME WELDMENT STEER AXLE
REAR LIFTING EYE
ENGINE ASSEMBLY - DIESEL - 55KW - STAGE V
DIESEL PARTICULATE FILTER PAGE 1 OF 3 - STAGE 5
DIESEL PARTICULATE FILTER PAGE 2 OF 3 - STAGE 5
DIESEL PARTICULATE FILTER PAGE 3 OF 3 - STAGE 5
OVERHEAD EXHAUST 3.8L KUBOTA DIESEL WITH DPF - STAGE 5 W/ DPF
COUNTERWEIGHT EXHAUST 3.8L KUBOTA DIESEL WITH DPF - STAGE 5 W/ DPF
COOLING SQUARE WAVE RADIATOR KUBOTA DIESEL - STAGE 5 W/ DPF
RADIATOR ASSEMBLY SQUARE WAVE RADIATOR KUBOTA 3.8L DIESEL - STAGE 5 W/ DPF
ENGINE MOUNTING AND TORQUE CONVERTER
FLYWHEEL AND HOUSING KUBOTA DIESEL 3.8L
FAN PULLY KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
CYLINDER BLOCK KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
COVER BEARING CASE KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
OIL COOLER KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
OIL SEPARATOR KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
DIPSTICK KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
CYLINDER HEAD COVER KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
CYLINDER HEAD KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
INLET AND EXHAUST VALVES KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
ROCKER ARM SHAFT KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
PISTON AND CRANKSHAFT KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
FUEL RAIL KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
INJECTION PIPE KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
INJECTOR HARNESS KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
FUEL INJECTION PUMP KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
INLET MANIFOLD KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
EGR VALVE KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
EGR COOLER KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
EXHAUST MANIFOLD KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
TURBOCHARGER KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
BREATHER AND SEPARATOR PIPES KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
CLOSED CRANKCASE BREATHER HEATER STAGE 5 W/ DPF
TURBO INLET PIPE KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
TURBOCHARGER OIL PLUMBING KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
OIL PAN KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
GEAR CASE KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
CAMSHAFT AND IDLE GEAR SHAFT KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
ALTERNATOR AND PULLEY KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
WIRE HARNESS BRACKET KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
SENSORS KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
WATER PUMP FLANGE AND THERMOSTAT KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
WATER PUMP KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
AIR CLEANER FLANGE AND THROTTLE VALVE STAGE 5 W/ DPF
STARTER KUBOTA DIESEL 3.8L - STAGE 5 W/ DPF
ENGINE ASSEMBLY - DIESEL - 82KW - STAGE V
EXHAUST SYSTEM WITH SCR
DIESEL PARTICULATE FILTER PAGE 1 OF 3 - STAGE V (→ PENDING PER ECN 68905-63)
DIESEL PARTICULATE FILTER PAGE 2 OF 3 - STAGE V (→ PENDING PER ECN 68905-63)
DIESEL PARTICULATE FILTER PAGE 3 OF 3 - STAGE V (→ PENDING PER ECN 68905-63)
SCR MUFFLER ASSEMBLY
SCR MUFFLER MOUNTING
AIR CLEANER FLANGE AND THROTTLE VALVE KUBOTA 3.8L DIESEL
FAN PULLEY KUBOTA 3.8L DIESEL
BEARING CASE COVER KUBOTA DIESEL 3.8L
SUPPLY PUMP KUBOTA DIESEL 3.8L
FUEL PIPE KUBOTA 3.8L DIESEL
SENSORS 3.8L KUBOTA DIESEL WITH DPF
OIL SEPARATOR KUBOTA 3.8L DIESEL
BREATHER AND SEPARATOR PIPES KUBOTA 3.8L DIESEL
CLOSED CRANKCASE BREATHER HEATER KUBOTA 3.8L DIESEL
REMOTE OIL FILTER, HOSES, AND ATTACHING PARTS KUBOTA DIESEL 3.8L
COOLING SYSTEM KUBOTA DIESEL 3.6L
RADIATOR ASSEMBLY KUBOTA 3.6L DIESEL
OVERHEAD EXHAUST SYSTEM KUBOTA 3.6L DIESEL
ENGINE MOUNTING AND TORQUE CONVERTER KUBOTA DIESEL
CYLINDER BLOCK KUBOTA DIESEL 3.6L
DIPSTICK KUBOTA DIESEL - 3.6L
OIL PAN KUBOTA DIESEL - 3.6L
BEARING CASE COVER KUBOTA DIESEL - 3.6L
CYLINDER HEAD KUBOTA DIESEL - 3.6L
ROCKER ARM ASSEMBLY WITH INLET AND EXHAUST VALVES - KUBOTA DIESEL 3.6L
PISTON AND CRANKSHAFT KUBOTA DIESEL - 3.6L
CYLINDER HEAD COVER KUBOTA DIESEL - 3.6L
GEAR CASE KUBOTA DIESEL - 3.6L
CAMSHAFT AND IDLE GEAR SHAFT KUBOTA DIESEL - 3.6L
FLYWHEEL AND HOUSING KUBOTA DIESEL - 3.6L
FUEL PUMP KUBOTA DIESEL - 3.6L
FUEL FILTER KUBOTA DIESEL - 3.6L
FUEL INJECTION AND GLOW PLUG KUBOTA DIESEL - 3.6L
INJECTION PUMP HOUSING KUBOTA DIESEL - 3.6L
INJECTION PUMP KUBOTA DIESEL - 3.6L
GOVERNOR KUBOTA DIESEL - 3.6L
GOVERNOR ACTUATOR AND PLUG KUBOTA DIESEL - 3.6L
ALTERNATOR AND PULLEY KUBOTA DIESEL - 3.6L
STARTER KUBOTA DIESEL - 3.6L
WATER PUMP FLANGE AND THERMOSTAT KUBOTA DIESEL - 3.6L
WATER PUMP KUBOTA DIESEL - 3.6L
INLET MANIFOLD KUBOTA DIESEL - 3.6L
EXHAUST MANIFOLD KUBOTA DIESEL - 3.6L
TURBOCHARGER KUBOTA DIESEL - 3.6L
TURBOCHARGER OIL PLUMBING KUBOTA DIESEL - 3.6L
OIL COOLER KUBOTA DIESEL - 3.6L
ENGINE ASSEMBLY - KUBOTA 3.8L DIESEL WITH DOC
COOLING SYSTEM KUBOTA DIESEL 3.8L
RADIATOR ASSEMBLY KUBOTA 3.8L DIESEL
EXHAUST SYSTEM KUBOTA 3.8L DIESEL T4F
OVERHEAD EXHAUST EXHAUST STACK - RAISED COUNTERWEIGHT
DIESEL OXIDATION CATALYST MUFFLER KUBOTA DIESEL 3.8L T4F
CHARGE AIR COOLER GROUP KUBOTA DIESEL 3.8L
AIR CLEANER FLANGE AND THROTTLE VALVE KUBOTA 3.8L DIESEL T4
FAN PULLEY KUBOTA 3.8L DIESEL T4F
CYLINDER BLOCK KUBOTA DIESEL 3.8L T4F
DIPSTICK KUBOTA DIESEL 3.8L T4F
OIL PAN KUBOTA DIESEL 3.8L T4F
BEARING CASE COVER KUBOTA DIESEL 3.8L T4F
CYLINDER HEAD KUBOTA DIESEL 3.8L T4F
INLET AND EXHAUST VALVES KUBOTA DIESEL 3.8L T4F
ROCKER ARM SHAFT KUBOTA DIESEL 3.8L T4F
PISTON AND CRANKSHAFT KUBOTA DIESEL 3.8L T4F
CYLINDER HEAD COVER KUBOTA DIESEL 3.8L T4F
GEAR CASE KUBOTA DIESEL 3.8L T4F
CAMSHAFT AND IDLE GEAR SHAFT KUBOTA DIESEL 3.8L T4F
FLYWHEEL AND HOUSING KUBOTA DIESEL 3.8L T4F
SUPPLY PUMP KUBOTA DIESEL 3.8L T4F
FUEL PIPE KUBOTA 3.8L DIESEL T4F
INJECTION PIPE KUBOTA DIESEL 3.8L T4F
FUEL RAIL KUBOTA DIESEL 3.8L T4F
ALTERNATOR AND PULLEY KUBOTA DIESEL 3.8L T4F
STARTER KUBOTA DIESEL 3.8L T4F
WATER PUMP FLANGE AND THERMOSTAT KUBOTA DIESEL 3.8L T4F
WATER PUMP KUBOTA DIESEL 3.8L T4F
INLET MANIFOLD KUBOTA DIESEL 3.8L T4F
EXHAUST MANIFOLD KUBOTA DIESEL 3.8L T4F
TURBOCHARGER KUBOTA DIESEL 3.8L T4F
TURBOCHARGER OIL PLUMBING KUBOTA DIESEL 3.8L T4F
OIL COOLER KUBOTA DIESEL 3.8L T4F
EGR VALVE KUBOTA DIESEL 3.8L T4F
EGR COOLER KUBOTA DIESEL 3.8L T4F
INJECTOR HARNESS KUBOTA DIESEL 3.8L T4F
SENSORS 3.8L KUBOTA DIESEL T4 WITH DOC
OIL SEPARATOR KUBOTA 3.8L DIESEL T4F
BREATHER AND SEPARATOR PIPES KUBOTA 3.8L DIESEL T4F
ENGINE ASSEMBLY-PSI
RADIATOR ASSEMBLY PSI 4.3L LPG
COOLING SYSTEM PSI 4.3L LPG
EXHAUST SYSTEM PSI 4.3L LPG
ENGINE MOUNTING PSI 4.3L LPG
LIFTING EYE PSI 4.3L LPG
VALVE COVER PSI 4.3L LPG
ROCKER ARM PSI 4.3L LPG
CAMSHAFT PSI 4.3L LPG
PISTONS AND CRANKCASE PSI 4.3L LPG
CRANKSHAFT PSI 4.3L LPG
CRANKSHAFT BALANCER PSI 4.3L LPG
CRANKSHAFT PULLEY PSI 4.3L LPG
CYLINDER HEAD PSI 4.3L LPG
CYLINDER BLOCK PSI 4.3L LPG
SPARK PLUG AND COIL WIRES PSI 4.3L LPG
HI FAN MOUNT PSI 4.3L LPG
PULLEY AND TENSIONER PSI 4.3L LPG
ALTERNATOR PSI 4.3L LPG
WATER PUMP PSI 4.3L LPG
MIXER PSI 4.3L LPG
LOCK-OFF VALVE PSI 4.3L LPG
THROTTLE BODY AND ATTACHING PARTS PSI 4.3L LPG
INTAKE MANIFOLD PSI 4.3L LPG
EXHAUST MANIFOLD PSI 4.3L LPG
OIL PAN PSI 4.3L LPG
OIL PUMP PSI 4.3L LPG
TIMING COVER PSI 4.3L LPG
TIMING CHAIN PSI 4.3L LPG
DIPSTICK AND TUBE PSI 4.3L LPG
IGNITION COIL PSI 4.3L LPG
LPG FUEL REGULATORING SYSTEM PSI 4.3L LPG
DISTRIBUTOR PSI 4.3L LPG
FLYWHEEL AND HOUSING PSI 4.3L LPG
STARTER PSI 4.3L LPG
ENGINE ASSEMBLY - DIESEL - NON CERT
EXHAUST SYSTEM KUBOTA DIESEL - NON CERT
ENGINE ATTACHING PARTS - KUBOTA DIESEL 3.8L NON CERT
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - CYLINDER BLOCK
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - OIL PAN
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - DIPSTICK
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - CYLINDER HEAD PAGE 1 OF 2
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - CYLINDER HEAD PAGE 2 OF 2
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - ROCKER ARM SHAFT
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - CYLINDER HEAD COVER
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - GEAR CASE
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - PISTON AND CRANKSHAFT
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - CAMSHAFT AND IDLE GEAR SHAFT
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - FLYWHEEL AND BEARING CASE COVER
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - SUPPLY PUMP
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - INJECTION PIPE
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - FUEL RAIL
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - ALTERNATOR AND PULLEY
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - STARTER
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - SENSORS AND ECU
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - WATER FLANGE, WATER PUMP AND THERMOSTAT
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - FAN PULLEY
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - INLET AND EXHAUST MANIFOLD WITH TURBO CHARGER
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - AIR CLEANER AND THROTTLE VALVE
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - TURBO CHARGER OIL PLUMBING
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - OIL COOLER
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - UPPER GASKET KIT
ENGINE ASSEMBLY KUBOTA DIESEL - NON CERT - LOWER GASKET KIT
FUEL SYSTEM-DIESEL
AIR INTAKE KUBOTA DIESEL 3.6L
AIR INTAKE KUBOTA DIESEL 3.8L
AIR FILTER
THROTTLE PEDAL ASSEMBLY AND ATTACHING PARTS FDC PEDAL - DIESEL
FUEL SYSTEM KUBOTA 3.6L DIESEL
FUEL SYSTEM KUBOTA 3.8L DIESEL
LIFT PUMP ASSEMBLY
E-THROTTLE LINKAGE KUBOTA 3.6L DIESEL
DIESEL EXHAUST FLUID SYSTEM GROUP KUBOTA DIESEL 3.8L
DIESEL EXHAUST FLUID TANK ASSEMBLY KUBOTA DIESEL 3.8L
DEF SYSTEM FLUID TEMPERATURE CONTROL - WITH CAB
DEF SYSTEM FLUID TEMPERATURE CONTROL - WITH OVERHEAD GUARD
FUEL CAP DIESEL
FUEL SYSTEM-LPG
AIR INLET PSI 4.3L LPG
AIR INLET PSI 4.3L LPG RAISED COUNTERWEIGHT
AIR FILTER PSI 4.3L LPG
FUEL SYSTEM PSI 4.3L LPG
FUEL SYSTEM PSI 4.3L LPG - SWING OUT TANK BRACKET
LPG REGULATOR AND MIXER PSI 4.3L
THROTTLE PEDAL ASSEMBLY AND ATTACHING PARTS STANDARD PEDAL
SINGLE AND DUAL LPG TANK BRACKETS
LPG TANK BRACKET SWING OUT
LPG BRACKET SWING OUT - RAISED COUNTERWEIGHT
ELECTRICAL SYSTEM
ALTERNATOR ELECTRICAL KUBOTA DIESEL - STANDARD ALTERNATOR
BATTERY CABLES PSI 4.3L LPG
BATTERY CABLES KUBOTA DIESEL 3.6L
BATTERY CABLES KUBOTA DIESEL 3.8L
BATTERY AND CONTROL CABLE DISCONNECT SWITCH KUBOTA DIESEL
COWL ELECTRICAL MANUAL HYDRAULIC
COWL ELECTRICAL ELECTRO-HYDRAULIC
DISPLAY DIESEL PARTICULATE FILTER
ELECTRICAL SYSTEM RIGHT HAND CHASSIS
ENGINE ELECTRICAL SYSTEM PSI 4.3L LPG
ENGINE ELECTRICAL SYSTEM KUBOTA 3.6L DIESEL
ENGINE ELECTRICAL SYSTEM KUBOTA 3.8L DIESEL
ENGINE ELECTRICAL KUBOTA 3.8L ENGINE WITH DPF
ENGINE CONTROL MODULE AND SENSORS PSI 4.3L LPG
ECU MOUNTING GROUP KUBOTA V3800, 6-9T PNEU - STAGE V W/ DPF
ENGINE ELECTRICAL SYSTEM KUBOTA 3.8L WITH DPF
IMPACT SENSOR
INSTRUMENT CLUSTER
LIGHTS BRAKE, TAIL, BACKUP, SIDE, TURN SIGNALS, WORK, STROBE - WITH CAB
LIGHTS BRAKE, TAIL, BACKUP, SIDE, TURN SIGNALS, WORK, STROBE - WITH OVERHEAD GUARD
LOAD WEIGH ELECTRICAL
MINI-LEVER CONTROLS THREE FUNCTION - WITHOUT RTST
MINI-LEVER CONTROLS THREE FUNCTION - WITH RTST
MINI-LEVER CONTROLS FOUR FUNCTION - WITHOUT RTST
MINI-LEVER CONTROLS FOUR FUNCTION - WITH RTST
POWER DISTRIBUTION MODULE
SEAT BELT SWITCH ADAPTER
TILT SENSOR
TRANSMISSION ELECTRICAL SYSTEM THREE SPEED - PROGRAMMABLE TE-08 (→ PENDING PER ECN 17195701)
TRANSMISSION ELECTRICAL SYSTEM THREE SPEED TRANSMISSION (PENDING PER ECN 17195701 →)
TRANSMISSION ELECTRICAL SYSTEM TWO SPEED TRANSMISSION
WIRE HARNESS (COWL) WITH RETURN TO SET TILT - MANUAL HYDRAULICS WITH FDC PEDAL
WIRE HARNESS (COWL) WITH RETURN TO SET TILT - ELECTRO-HYDRAULICS WITH FDC PEDAL
WIRE HARNESS (COWL) WITHOUT RETURN TO SET TILT - MANUAL HYDRAULICS WITH FORWARD/REVERSE
WIRE HARNESS (COWL) WITHOUT RETURN TO SET TILT - ELECTRO-HYDRAULICS WITH FORWARD/REVERSE
WIRE HARNESS DPF DISPLAY
WIRE HARNESS ELECTRONIC CONTROL VALVE - THREE FUNCTION
WIRE HARNESS ELECTRONIC CONTROL VALVE - FOUR FUNCTION
WIRE HARNESS (ENGINE) PSI 4.3L LPG
WIRE HARNESS ENGINE - KUBOTA DIESEL 3.6L
WIRE HARNESS ENGINE (SHEET 1 OF 2) - KUBOTA DIESEL 3.8L WITH SCR
WIRE HARNESS ENGINE (SHEET 2 OF 2) - KUBOTA DIESEL 3.8L WITH SCR
WIRE HARNESS (ENGINE) KUBOTA 3.8L DIESEL WITH DOC
WIRE HARNESS ENGINE KUBOTA - WITH DPF
WIRE HARNESS LIGHTS WITH OVERHEAD GUARD
WIRE HARNESS REAR - PSI AND KUBOTA 3.6L
WIRE HARNESS REAR - KUBOTA 3.8L
WIRE HARNESS (AIR CONDITIONING)
WIRE HARNESS RH CHASSIS - KUBOTA 3.8L AND PSI
WIRE HARNESS RH CHASSIS - KUBOTA 3.6L DIESEL
WIRE HARNESS TRANSMISSION STANDARD THREE SPEED - USED ONLY ON TE-08 CONTROLLER (→ PENDING PER ECN 17195701)
WIRE HARNESS TRANSMISSION-THREE SPEED - PSI 4.3L LPG AND KUBOTA DIESEL (PENDING PER ECN 17195701 →)
WIRE HARNESS TRANSMISSION-THREE SPEED - WITH E-THROTTLE (PENDING PER ECN 17195701 →)
WIRE HARNESS TRANSMISSION-TWO SPEED WITH TISS SENSOR - KUBOTA 3.6L DIESEL
WIRE HARNESS TRANSMISSION-TWO SPEED WITH TISS SENSOR - PSI 4.3L LPG AND KUBOTA DIESEL
STEERING SYSTEM
STEER AXLE
STEER BRAKE TURN ASSIST - FORCE LIMITING SYSTEM
STEER CYLINDER
STEERING COLUMN ASSEMBLY DIESEL
STEERING WHEEL AND COLUMN DIESEL
STEERING WHEEL AND COLUMN LPG
STEERING COLUMN ASSEMBLY LPG
STEERING CONTROL UNIT
STEER TIRE AND WHEEL
BRAKE SYSTEM
BRAKE LINKAGE SINGLE PEDAL - WET BRAKE
BRAKE COOLING SYSTEM SINGLE AND DUAL PEDAL
BRAKE MASTER CYLINDER ASSEMBLY
PARK BRAKE ASSEMBLY
Drive Axle
DRIVE AXLE AND ATTACHING PARTS WET BRAKE
DRIVE AXLE HOUSING AND HUB
DIFFERENTIAL
WET BRAKE ASSEMBLY
DRIVE TIRE AND WHEEL DUAL - 8.25 X 15
DRIVE TIRE AND WHEEL ASSEMBLY SOLID
TRANSMISSION
TRANSMISSION COOLING
TRANSMISSION MOUNT
TORQUE CONVERTER PSI 4.3L GASOLINE AND LPG
OIL BAFFLE KUBOTA DIESEL
TRANSMISSION ASSEMBLY THREE SPEED - SHEET 1 OF 2
TRANSMISSION ASSEMBLY THREE SPEED - SHEET 2 OF 2
FORWARD CLUTCH LOW AND SECOND SHAFT THREE SPEED TRANSMISSION - FWD1, RANGE2
FORWARD CLUTCH HIGH AND OUTPUT SHAFT THREE SPEED TRANSMISSION - FWD2
REVERSE CLUTCH AND FIRST SHAFT THREE SPEED TRANSMISSION - REV1, RANGE 1
TRANSMISSION ASSEMBLY TWO SPEED - SHEET 1 OF 2
TRANSMISSION ASSEMBLY TWO SPEED - SHEET 2 OF 2
FORWARD CLUTCH LOW TWO SPEED TRANSMISSION
REVERSE CLUTCH TWO SPEED TRANSMISSION
OUTPUT SHAFT TWO SPEED TRANSMISSION
CONTROL VALVE THREE SPEED TRANSMISSION
CONTROL VALVE TWO SPEED TRANSMISSION
CHARGE PUMP
PUMP DRIVE
HYDRAULIC SYSTEM
HYDRAULIC SUPPLY AND RETURN MANUAL HYDRAULICS - 60VX - 70VXS
HYDRAULIC SUPPLY AND RETURN ELECTRONIC HYDRAULICS - 70VXS - 80VX
HYDRAULIC SUPPLY AND RETURN ELECTRONIC HYDRAULICS - 80VX WITH 3.8L DSL
HYDRAULIC FILTER
GEAR PUMP ASSEMBLY
GEAR PUMP ASSEMBLY 3.6L DIESEL
STEERING GEAR PUMP
HYDRAULIC HOSES STEERING
HAND LEVERS THREE FUNCTION - WITH DETENTED LEVERS
HAND LEVERS THREE FUNCTION - WITHOUT DETENTED LEVERS
HAND LEVERS FOUR FUNCTION - WITH DETENTED LEVERS
HAND LEVERS FOUR FUNCTION - WITHOUT DETENTED LEVERS
CONTROL VALVE LOCKOUT GROUP MANUAL CONTROL VALVE
HYDRAULIC CONTROL VALVE MANUAL HYDRAULICS
HYDRAULIC CONTROL VALVE ELECTRONIC HYDRAULICS - THREE AND FOUR FUNCTION (60VX - 80VX)
HYDRAULIC CONTROL VALVE WITH STEERING UNIT ASSEMBLY ELECTRONIC HYDRAULICS - THREE FOUR FUNCTION (70VXS9 - 80VX WITH 3.8L DSL)
SEAL KITS HYDRAULIC CONTROL VALVE - ELECTRONIC HYDRAULICS
MID INLET SECTION ELECTRONIC CONTROL VALVE - THREE AND FOUR FUNCTION
LIFT AND LOWER SECTION ELECTRONIC CONTROL VALVE - THREE AND FOUR FUNCTION
TILT SECTION ELECTRONIC CONTROL VALVE - THREE AND FOUR FUNCTION
ELECTRO HYDRAULIC POPPET VALVE ELECTRONIC CONTROL VALVE - THREE AND FOUR FUNCTION
AUXILIARY ONE SECTION ELECTRONIC CONTROL VALVE - THREE AND FOUR FUNCTION
AUXILIARY TWO SECTION ELECTRONIC CONTROL VALVE - FOUR FUNCTION
HOIST HOSE AND ATTACHING PARTS 60VX - 70VXS6
HOIST HOSE AND ATTACHING PARTS 70VXS9 - 80VX
TILT CYLINDER AND MAST INSTALLATION
TILT CYLINDERS 5 FWD / 6 BACK AND 5 FWD / 10 BACK
TILT CYLINDERS 5 FWD / 6 BACK AND 5 FWD / 9 BACK
TILT HYDRAULICS 60VXS - 70VXS9
TILT HYDRAULICS 70VXS - 80VX
VENT LINES
AUXILIARY FUNCTION HOSES
UNLOADER VALVE
Mast-Two Stage Limited Free-Lift
MAST AND ATTACHING PARTS TWO STAGE LIMITED FREE-LIFT - F70/A6M3
MAST ASSEMBLY TWO STAGE LIMITED FREE-LIFT - F70/A6M3
MAST AND CARRIAGE ASSEMBLY TWO STAGE LIMITED FREE-LIFT - F80 MAST SERIES
MAST AND CARRIAGE ASSEMBLY TWO STAGE LIMITED FREE- LIFT (F80) - 5500 AND 6000 MM WITH ISS CARRIAGE
OUTER MAST TWO STAGE LIMITED FREE-LIFT - F80 MAST SERIES
OUTER MAST TWO STAGE LIMITED FREE-LIFT - F80 MAST SERIES WITHOUT CARRIAGE
INNER MAST TWO STAGE LIMITED FREE-LIFT - F80 MAST SERIES
INNER MAST TWO STAGE LIMITED FREE-LIFT - F80 MAST SERIES WITHOUT CARRIAGE
MAIN LIFT CYLINDER TWO STAGE LIMITED FREE-LIFT - F80 MAST SERIES
HEADER HOSES TWO STAGE LIMITED FREE-LIFT - F70/A6M3
HEADER HOSES (F80 MAST SERIES) TWO STAGE LIMITED FREE- LIFT
HEADER HOSES (F80 MAST SERIES) TWO STAGE LIMITED FREE LIFT - LIFT HEIGHT 5500MM AND 6000MM
HEADER HOSES (F80 MAST SERIES) TWO STAGE LIMITED FREE LIFT - 5500 AND 6000 MM WITH ISS CARRIAGE
CARRIAGE STANDARD - WITHOUT LOAD BACK REST
CARRIAGE SIDE-SHIFT
CARRIAGE STANDARD HOOK - ELECAR
CARRIAGE HOOK TYPE
FORK POSITIONER ASSEMBLY
Mast-Three Stage Full Free-Lift
MAST ASSEMBLY THREE STAGE FULL FREE- LIFT - WITH STANDARD HOOK CARRIAGE
MAST ASSEMBLY THREE STAGE FULL FREE-LIFT - ISS CARRIAGE WITH FORK POSITIONER
MAST ASSEMBLY THREE STAGE FULL FREE-LIFT - F70TV MAST W/O CARRIAGE
ISS CARRIAGE ASSEMBLY THREE STAGE FULL FREE-LIFT
CARRIAGE STANDARD - F70TV MAST W/O CARRIAGE
HEADER HOSE THREE STAGE FFL
FORK POSITIONER THREE STAGE FULL FREE-LIFT
OPTIONS
REAR HANDLE OHG AND CAB
REAR CAMERA AND DISPLAY
DUAL MIRRORS WITH CAB
DUAL MIRRORS WITH OVERHEAD GUARD
MIRROR REAR MOUNTED
LIFTING EYE REAR
BACK-UP ALARM
FIRE EXTINGUISHER WITH CAB
FIRE EXTINGUISHER WITH OVERHEAD GUARD
ACCUMULATOR
ACCUMULATOR SHORT WHEEL BASE
ACCUMULATOR LONG WHEEL BASE
LPG REGULATOR DRAIN KIT
RAIN TOP
HANG-ON SIDE-SHIFT CARRIAGE AND HOSES BOLZONI
HANG-ON SIDE-SHIFT CARRIAGE CYLINDER ASSEMBLY - BOLZONI
HANG-ON SIDE-SHIFT CARRIAGE AND HOSES WITH BACKREST AND FORK POSITIONER - CASCADE
SIDE-SHIFT CYLINDER WITH FORK POSITIONER - CASCADE
ATTACHMENT CARRIAGE WITH FORK POSITIONER AND BACKREST - CASCADE
ATTACHMENT CARRIAGE VALVE AND HOSES - CASCADE
FORK POSITIONER ASSEMBLY CASCADE
CARRIER ASSEMBLY CASCADE
BACKREST WITH FORK POSITIONER - CASCADE
FIELD CONVERSION KITS
CONVERSION KITS TRANSMISSION CONTROLLER - APC214 TO APC312
SEAT CONVERSION KITS
ELECTRICAL CONVERSION KITS
STEER CONVERSION KITS
HYDRAULIC CONVERSION KITS
ENGINE CONVERSION KITS
GENERAL TRUCK ADD-ON OPTION AND REPLACEMENT KITS
ELECTRICAL ADD-ON OPTION AND REPLACEMENT KITS
LIGHTS ADD-ON OPTION AND REPLACEMENT KITS
STEER ADD-ON OPTION AND REPLACEMENT KITS
HYDRAULIC ADD-ON OPTION AND REPLACEMENT KITS
ENGINE AND FUEL ADD-ON OPTION AND REPLACEMENT KITS
TRANSMISSION ADD-ON OPTION AND REPLACEMENT KITS
REPAIR KITS MISCELLANEOUS
NUMERICAL INDEX
USER SUPPORT INFORMATION
