Hyundai
Driver
26
66,203
Yale Forklift A390 GLP20MX to GDP35MX Parts Catalog
Brand: Yale
Type of Machine: Forklift
Model: Yale GLP20MX, GDP20MX, GLP25MX, GDP25MX, GDP35MX, GLP35MX (A390)
Publication Date: 2024
Number of Pages: 654 Pages
A390 GLP20MX
A390 GDP35MX
A390 GLP20MX
A390 GDP20MX
A390 GLP25MX
A390 GDP25MX
A390 GDP35MX
A390 GLP35MX
GLP20MX A390
GDP35MX A390
GLP20MX A390
GDP20MX A390
GLP25MX A390
GDP25MX A390
GDP35MX A390
GLP35MX A390
GENERAL TRUCK
COUNTERWEIGHT​
OVERHEAD GUARD​
COWL MOUNT​
HOOD ASSEMBLY​
PVC DOOR KIT AND TOP SCREEN - FOR RAISED OVERHEAD GUARD​
PVC DOOR KIT MEDIUM OHG​
FRONT SCREEN KIT FOR RAISED OVERHEAD GUARD (→ PENDING PER ECN 16256117)​
FRONT SCREEN KIT FOR RAISED OVERHEAD GUARD (PENDING PER ECN 16256117 →)​
FRONT SCREEN KIT MEDIUM OHG - WITH ADAPTATION KIT (→ S/N A390B03814T)​
FRONT SCREEN KIT MEDIUM OHG - WITH ADAPTATION KIT (S/N A390B03815T →)​
TOP SCREEN KIT​
REAR SCREEN KIT MEDIUM OHG​
REAR SCREEN KIT FOR RAISED OVERHEAD GUARD​
REAR SCREEN ADAPTATION KIT - RAISED OHG​
STEEL DOORS MEDIUM OHG​
STEEL DOORS LEFT AND RIGHT DOOR - MEDIUM OHG​
STEEL DOORS RAISED OHG​
STEEL DOOR LH RAISED OHG​
STEEL DOOR RH RAISED OHG​
SLIDING WINDOW KIT​
CAB HEATER​
HEATER AND HOSES PSI ENGINE​
HEATER AND HOSES YANMAR ENGINE​
NON SUSPENSION SEAT​
SEMI-SUSPENSION SEAT​
FULL-SUSPENSION SEAT PAGE 1 OF 4​
FULL SUSPENSION SEAT RECLINER KIT - PAGE 2 OF 4​
FULL SUSPENSION SEAT SERVICE KITS FOR NON-SWIVEL - PAGE 3 OF 4​
FULL SUSPENSION SEAT MANUAL HYDRAULIC NON-SWIVEL - PAGE 4 OF 4​
FULL-SUSPENSION SEAT OPTIONAL SEAT - PAGE 1 OF 2​
FULL SUSPENSION SEAT OPTIONAL SEAT - PAGE 2 OF 2​
SEAT SCISSORS HEAVY DUTY - SWIVEL AND NON-SWIVEL SEATS​
ARMREST SLIDER ASSEMBLY​
FLOORPLATES AND COVERS LPG​
FLOORPLATES AND COVERS DIESEL AND BI-FUEL​
INTERIOR PANELS AND COVERS​
SOUND ABATEMENT​
SOUND ABATEMENT HOOD LINERS​
STATIC STRAP INSTALLATION​
FENDER EXTENSIONS​
LOAD BACKREST EXTENSION​
FORKS STANDARD​
FORKS OPTIONAL​
NAMEPLATES AND LABELS PAGE 1 OF 2​
NAMEPLATES AND LABELS PAGE 2 OF 2​
LABELS RADIATOR​
ENGINE ASSEMBLY - DIESEL
ENGINE MOUNTING YANMAR ENGINE​
COOLING SYSTEM YANMAR STANDARD AND ANTI-CLOG - WITHOUT SILENCER​
COOLING SYSTEM YANMAR STANDARD AND ANTI-CLOG - WITH SILENCER​
OVERHEAD EXHAUST YANMAR 2.6L AND 3.3L​
COUNTERWEIGHT EXHAUST YANMAR 2.6L AND 3.3L DIESEL​
OIL PAN AND FLYWHEEL HOUSING YANMAR 2.6L AND 3.3L​
CYLINDER BLOCK YANMAR 2.6 AND 3.3L - DIESEL​
CYLINDER HEAD YANMAR 2.6L AND 3.3L - DIESEL​
CRANKSHAFT AND PISTONS YANMAR 2.6L AND 3.3L - DIESEL​
LUBRICATION SYSTEM YANMAR 2.6 AND 3.3L​
INTAKE AND EXHAUST MANIFOLD YANMAR 2.6L AND 3.3L​
CAMSHAFT AND DRIVE GEAR YANMAR 2.6L AND 3.3L​
WATER SEPARATOR YANMAR 2.6 AND 3.3L DIESEL​
INJECTION PUMP YANMAR 2.6L AND 3.3L DIESEL​
FUEL INJECTION SYSTEM YANMAR 2.6 AND 3.3L DIESEL​
WATER COOLING SYSTEM YANMAR 2.6L AND 3.3L DIESEL​
GEAR HOUSING YANMAR 2.6 AND 3.3L DIESEL​
FLYWHEEL MOUNTING HARDWARE YANMAR 2.6 AND 3.3L DIESEL​
ALTERNATOR YANMAR 2.6 AND 3.3L DIESEL​
STARTER YANMAR 2.6 AND 3.3L DIESEL​
ENGINE GASKET KIT YANMAR 2.6 AND 3.3L DIESEL​
ENGINE ASSEMBLY - LPG
COOLING SYSTEM PSI STANDARD​
COOLING SYSTEM PSI ANTI-CLOG​
OVERHEAD EXHAUST WITH CATALYTIC CONVERTER - PSI 2.4L LPG AND 2.4L BI-FUEL​
OVERHEAD EXHAUST WITHOUT CATALYTIC CONVERTER - PSI 2.4L LPG AND 2.4L BI-FUEL​
COUNTERWEIGHT EXHAUST WITH CATALYTIC CONVERTER - PSI 2.4L LPG AND 2.4L BI-FUEL​
COUNTERWEIGHT EXHAUST WITHOUT CATALYTIC CONVERTER - PSI 2.4L LPG AND 2.4L BI-FUEL​
ENGINE CONTROL MODULE MOUNTING PSI 2.4L​
ENGINE AND ATTACHING PARTS PSI 2.4L LPG AND 2.4L BI-FUEL​
ELECTRICAL SENSORS PSI 2.4L LPG AND 2.4L BI-FUEL​
TRANSMISSION FLEX PLATE PSI 2.4L​
FLYWHEEL MOUNTING HARDWARE PSI 2.4L LPG AND 2.4L BI-FUEL​
FAN ASSEMBLY​
HI-FAN ASSEMBLY PSI 2.4L LPG AND 2.4L BI-FUEL​
ENGINE MOUNTING PSI ENGINE​
CYLINDER BLOCK PSI 2.4L​
CYLINDER HEAD PSI 2.4L​
CAMSHAFT AND VALVES PSI 2.4L​
ROCKER COVER PSI 2.4L​
PISTON AND CRANKSHAFT PSI 2.4L​
IGNITION COIL PSI 2.4L​
BALANCER PSI 2.4L​
STARTER PSI 2.4L​
ALTERNATOR PSI 2.4L​
CAB HEATER COOLANT PSI 2.4L​
EXHAUST MANIFOLD PSI 2.4L​
INTAKE MANIFOLD PSI 2.4L LPG AND 2.4L BI-FUEL​
FRONT COVER AND OIL PAN PSI 2.4L​
OIL PUMP AND ATTACHING PARTS PSI 2.4L​
PUMP MOUNT BRACKET PSI 2.4L LPG AND 2.4L BI-FUEL​
DIPSTICK AND TUBE PSI 2.4L LPG​
WATER OUTLET WITHOUT CAB HEATER - PSI 2.4L LPG AND 2.4L BI-FUEL​
ENGINE COOLING SYSTEM THERMOSTAT AND DRS CIRCUIT - PSI 2.4L LPG AND 2.4L BI-FUEL​
WATER PUMP PSI 2.4L​
EXCLUDER SHIELD PSI 2.4L​
FUEL SYSTEM-DIESEL
AIR INTAKE SYSTEM WITHOUT SILENCER - YANMAR 2.6L AND 3.3L DIESEL​
AIR INTAKE SYSTEM WITH SILENCER - YANMAR 2.6L AND 3.3L DIESEL​
AIR INTAKE SILENCER YANMAR 2.6L AND 3.3L DIESEL​
AIR INTAKE SYSTEM PRE-CLEANER​
FUEL SYSTEM YANMAR 2.6 AND 3.3L DIESEL​
THROTTLE CABLE YANMAR​
THROTTLE PEDAL ASSEMBLY AND ATTACHING PARTS STANDARD PEDAL YANMAR DIESEL (→ S/N A390B02092R)​
THROTTLE PEDAL ASSEMBLY AND ATTACHING PARTS STANDARD PEDAL YANMAR DIESEL (S/N A390B02093R →)​
THROTTLE PEDAL ASSEMBLY AND ATTACHING PARTS FOOT DIRECTIONAL PEDAL YANMAR DIESEL (→ S/N A390B02092R)​
THROTTLE PEDAL ASSEMBLY AND ATTACHING PARTS FOOT DIRECTIONAL PEDAL YANMAR DIESEL (S/N A390B02093R →)​
FUEL SYSTEM-LPG
AIR INTAKE PSI ENGINE​
AIR FILTER ASSEMBLY SINGLE ELEMENT​
AIR FILTER ASSEMBLY DUAL ELEMENT​
LPG FUEL TANK AND MOUNTING WITH FIXED FABRIC STRAP​
LPG TANK BRACKET SWING OUT WITH FABRIC STRAP​
LPG BRACKET SWING OUT WITH TWIN STEEL STRAPS​
FUEL REGULATING SYSTEM PSI 2.4L LPG AND 2.4L BI-FUEL​
LPG LOCK-OFF PSI 2.4L​
THROTTLE BODY PSI 2.4L​
FUEL SYSTEM PSI 2.4L BI-FUEL​
FUEL SENDER AND ATTACHING PARTS PSI 2.4L BI-FUEL (S/N A390B01512P →)​
FUEL SENDER AND ATTACHING PARTS MANUFACTURING OPTION GASOLINE FUEL SENDER - PSI 2.4L BI-FUEL​
MIXER/EPR AND PCV AIR HOSES PSI 2.4L LPG AND 2.4L BI-FUEL​
FUEL RAIL PSI 2.4L BI-FUEL​
THROTTLE PEDAL ASSEMBLY AND ATTACHING PARTS PSI - STANDARD PEDAL (→ S/N A390B02092R)​
THROTTLE PEDAL ASSEMBLY AND ATTACHING PARTS PSI - STANDARD PEDAL (S/N A390B02093R →)​
THROTTLE PEDAL ASSEMBLY AND ATTACHING PARTS PSI ENGINE WITH FOOT DIRECTIONAL CONTROL (→ S/N A390B02092R)​
THROTTLE PEDAL ASSEMBLY AND ATTACHING PARTS PSI - FOOT DIRECTIONAL CONTROL PEDAL (S/N A390B02093R →)​
ELECTRICAL SYSTEM
ELECTRICAL ARRANGEMENT FRAME - PSI 2.4L LPG AND 2.4L BI-FUEL​
ELECTRICAL ARRANGEMENT FRAME - YANMAR DIESEL​
HARNESS GROUP FRAME - PSI 2.4L LPG AND 2.4L BI-FUEL​
HARNESS GROUP FRAME - YANMAR DIESEL (→ 2/2017)​
HARNESS GROUP FRAME - YANMAR DIESEL (2/2017 →)​
COWL ELECTRICAL FORWARD AND REVERSE LEVER​
COWL ELECTRICAL FOOT DIRECTIONAL CONTROL​
POWER DISTRIBUTION MODULE​
INSTRUMENT PANEL ASSEMBLY​
BATTERY AND DISCONNECT SWITCH PSI BI-FUEL​
BATTERY AND DISCONNECT SWITCH YANMAR DIESEL​
BATTERY CABLES​
BATTERY CABLES DIESEL​
CAB WIRING​
LIGHT GROUP TAIL, BRAKE, BACKUP, TURN, SIDE MARKER, WORK AND STROBE LIGHTS​
LIGHT GROUP BLUE SPOTLIGHT WITH REAR WORK LIGHT​
HARNESS ARRANGEMENT LIGHTS​
WIRE HARNESS CAB HEATER​
WIRE HARNESS ENGINE - PSI 2.4L LPG AND 2.4L BI-FUEL​
WIRE HARNESS HAZARD LIGHT​
WIRE HARNESS COWL - FORWARD AND REVERSE LEVER​
WIRE HARNESS COWL - FOOT DIRECTIONAL CONTROL PEDAL​
WIRE HARNESS FRAME - PSI 2.4L LPG AND 2.4L BI-FUEL​
WIRE HARNESS FRAME - PSI 2.4L LPG AND 2.4L BI-FUEL W/FDC​
WIRE HARNESS FRAME - YANMAR DIESEL​
WIRE HARNESS SPEED LIMITER​
WIRE HARNESS TELEMETRY FM1A AND FM1B​
LOAD WEIGH ELECTRICAL​
STEERING SYSTEM
STEER AXLE​
STEER AXLE​
STEER CYLINDER​
STEERING COLUMN AND ATTACHING PARTS​
STEER CONTROL UNIT AND ATTACHING STEER HOSES​
STEER TIRES AND WHEELS RADIAL - TRELLEBORG​
STEER TIRES AND WHEELS RADIAL - CONTINENTAL​
STEER TIRES AND WHEELS SOLID PNEUMATIC TYRE - TRELLEBORG​
STEER TIRES AND WHEELS PNEUMATIC 6.00X9-12 PR - TRELLEBORG​
STEER TIRES AND WHEELS PNEUMATIC BIAS-PLY - TRELLEBORG​
STEER TIRES AND WHEELS DIVIDED WHEEL SOLID TIRE - ORCA​
BRAKE SYSTEM
BRAKE ASSEMBLY GP20MX, GP25MX​
BRAKE ASSEMBLY GP30MX​
BRAKE LINKAGE, SINGLE PEDAL​
BRAKE PEDAL SINGLE PEDAL (S/N A390B03288S →)​
PARK BRAKE ATTACHING PARTS​
PARK BRAKE ASSEMBLY​
BRAKE MASTER CYLINDER​
Drive Axle
DRIVE AXLE AND ATTACHING PARTS GP20-25MX (→ 10/2018)​
DRIVE AXLE AND ATTACHING PARTS GP20-25MX (10/2018 →)​
DRIVE AXLE AND ATTACHING PARTS GP30MX​
DRIVE AXLE CENTER SECTION AND HUB ASSY GP20-30MX (→ 10/2018 GP20-25MX)​
DRIVE SHAFT WITH COVER​
DRIVE TIRES AND WHEELS SINGLE​
DRIVE TIRES AND WHEELS SOLID​
DRIVE TIRES AND WHEELS DIVIDED SOLID TIRE​
DRIVE TIRES AND WHEELS RADIAL TIRE​
DRIVE TIRES AND WHEELS RADIAL TIRE - OPTIONAL​
DRIVE TIRES AND WHEELS SOLID PNEUMATIC - GP30XM 7.00 X 15 RIM​
DRIVE TIRES AND WHEELS SOLID PNEUMATIC - GP20-25 XM 5.00 x 12 RIM​
TRANSMISSION
TRANSMISSION COOLING​
TRANSMISSION HOUSING AND ASSEMBLY​
INPUT/FORWARD CLUTCH​
COUNTER/REVERSE CLUTCH​
TORQUE CONVERTER HOUSING AND ATTACHING PARTS​
INCHING VALVE AND ATTACHING PART​
INCHING VALVE ASSEMBLY​
HYDRAULIC SYSTEM
HYDRAULIC SUPPLY AND RETURN​
HYDRAULIC SUPPLY AND RETURN DIESEL, 24cc​
HYDRAULIC HOSES 3 AND 4 FUNCTION (→ 5/2017)​
HYDRAULIC HOSES 3 AND 4 FUNCTION - WITH MAN-HYD (5/2017 →)​
PUMP DRIVE ASSEMBLY​
GEAR PUMP​
HAND LEVERS TWO, THREE AND FOUR FUNCTION​
HAND LEVERS THREE AND FOUR FUNCTION WITH DETENT​
HAND LEVERS TWO, THREE AND FOUR FUNCTION WITH RTST​
HYDRAULIC CONTROL VALVE MANUAL CONTROLS - TWO, THREE AND FOUR FUNCTION​
HYDRAULIC CONTROL VALVE INLET SECTION - MANUAL CONTROLS​
HYDRAULIC CONTROL VALVE LIFT SECTION - MANUAL CONTROLS​
HYDRAULIC CONTROL VALVE TILT SECTION - MANUAL CONTROLS​
HYDRAULIC CONTROL VALVE AUXILIARY SECTION - MANUAL CONTROLS​
HYDRAULIC CONTROL VALVE OUTLET SECTION - MANUAL CONTROLS​
TILT HYDRAULICS AND ACCUMULATOR​
TILT CYLINDER AND MAST INSTALLATION​
TILT CYLINDERS​
Mast-Two Stage Limited Free-Lift
OUTER MAST ASSEMBLY THREE STAGE FULL FREE- LIFT - A389​
MAIN LIFT CYLINDER TWO STAGE LIMITED FREE LIFT - A389​
OUTER MAST ASSEMBLY TWO STAGE LIMITED FREE LIFT - A399​
MAIN LIFT CYLINDER TWO STAGE LIMITED FREE LIFT - A399​
CARRIAGE TWO STAGE LIMITED FREE-LIFT​
HEADER HOSE AND ATTACHING PARTS TWO STAGE LIMITED FREE LIFT​
Mast-Three Stage Full Free-Lift
OUTER MAST ASSEMBLY THREE STAGE FULL FREE LIFT - A387 MAST SERIES (→ 8/2017)​
OUTER MAST ASSEMBLY THREE STAGE FULL FREE LIFT - A387 MAST SERIES (8/2017 →)​
INTERMEDIATE MAST AND MAIN-LIFT THREE STAGE FULL FREE LIFT - A387 MAST SERIES (→ 8/2017)​
INTERMEDIATE MAST AND MAIN-LIFT THREE STAGE FULL FREE LIFT - A387 MAST SERIES (8/2017 →)​
INNER MAST AND FREE-LIFT THREE STAGE FULL FREE- LIFT - A387 MAST SERIES (→ 8/2017)​
INNER MAST AND FREE-LIFT THREE STAGE FULL FREE LIFT - A387 MAST SERIES (8/2017 →)​
MAIN LIFT CYLINDER THREE STAGE FULL FREE-LIFT - A387 MAST SERIES​
FREE-LIFT CYLINDER THREE STAGE FULL FREE-LIFT - A387 MAST SERIES​
OUTER MAST ASSEMBLY THREE STAGE FULL FREE- LIFT - A397 MAST SERIES (→ 8/2017)​
OUTER MAST ASSEMBLY THREE STAGE FULL FREE-LIFT - A397 MAST SERIES (8/2017 →)​
INTERMEDIATE MAST AND MAIN-LIFT THREE STAGE FULL FREE- LIFT - A397 MAST SERIES (→ 8/2017)​
INTERMEDIATE MAST AND MAIN-LIFT THREE STAGE FULL FREE LIFT - A397 MAST SERIES (8/2017 →)​
INNER MAST AND FREE-LIFT THREE STAGE FULL FREE- LIFT - A397 MAST SERIES (→ 8/2017)​
INNER MAST AND FREE-LIFT THREE STAGE FULL FREE LIFT - A397 MAST SERIES (8/2017 →)​
MAIN LIFT CYLINDER THREE STAGE FULL FREE-LIFT - A397 MAST SERIES​
FREE-LIFT CYLINDER THREE STAGE FULL FREE-LIFT - A397 MAST SERIES​
HEADER HOSE AND ATTACHING PARTS​
FREELIFT TUBE GROUP 3 AND 4 FUNCTION​
CARRIAGE THREE STAGE FULL FREE-LIFT​
OPTIONS
CONTROLLER RTST GROUP​
BACKUP ALARM​
MIRRORS​
ALTERED COUNTERWEIGHT WITH LIFTING EYE​
OVERHEAD GUARD SPECIAL LOWERED​
DOCUMENT CLIP WITHOUT HOOD BLANKET​
DOCUMENT CLIP W/ HOOD BLANKET​
UNDERCARRIAGE SCREEN​
ACCUMULATOR THREE STAGE FFL/TWO STAGE LFL​
STROBE LIGHT LED​
AUXILIARY TUBE EXTENSIONS ISS ONLY FOUR FUNCTION - THREE STAGE FULL FREE-LIFT​
INTEGRAL SIDE-SHIFT CARRIAGE TWO STAGE LIMITED FREE-LIFT - 1067mm (12/2016 →)​
INTEGRAL SIDE-SHIFT CARRIAGE TWO STAGE LIMITED FREE-LIFT - 1219mm (12/2016 →)​
INTEGRAL SIDE-SHIFT HYDRAULIC HOSES TWO STAGE LIMITED FREE-LIFT (12/2016 →)​
INTEGRAL SIDE-SHIFT CARRIAGE ASSEMBLY THREE STAGE FULL FREE-LIFT - CLASS II AND III​
INTEGRAL SIDE-SHIFT CYLINDER​
INTEGRAL SIDE-SHIFT FORK POSITIONER - TWO STAGE LIMITED FREE-LIFT (12/2016 →)​
INTEGRAL SIDE-SHIFT FORK POSITIONER - THREE STAGE FULL FREE-LIFT (12/2016 →)​
FORK POSITIONER ASSEMBLY​
TELEMETRY LEVEL 1 GSM​
TELEMETRY LEVEL 2 HARNESS GROUP (→ 3/2017)​
TELEMETRY LEVEL 1 AND 2 WITH ANTENNA (3/2017 →)​
TELEMETRY LEVEL 3 DISPLAY (→ 8/2019)​
TELEMETRY LEVEL 3 DISPLAY (8/2019 →)​
TELEMETRY CARD READER​
POWER OUTLET 12V DC​
TRACTION SPEED LIMITER YANMAR DIESEL​
FIELD CONVERSION KITS
ADD-ON OPTION KITS FORK POSITIONER MECHANISM​
ADD ON OPTION AND CONVERSION KITS​
ADD ON KITS HIGH TERMINATION EXT TUBES​
CAB KITS​
CONVERSION KITS MAST CONNECTION HOSE​
CONVERSION KITS DIRECTIONAL CONTROL​
CONVERSION KITS SEATS​
CONVERSION KITS MISCELLANEOUS​
HEADER HOSE CONVERSION KITS TWO STAGE LFL - A389 MAST SERIES​
HEADER HOSE CONVERSION KITS TWO STAGE LFL - A399 MAST SERIES​
HEADER HOSE CONVERSION KITS THREE STAGE FFL - A387 MAST SERIES​
HEADER HOSE CONVERSION KITS THREE STAGE FFL - A397 MAST SERIES​
HYDRAULIC CONTROL CONVERSION KITS​
LIGHT KITS​
NUMERICAL INDEX
USER SUPPORT INFORMATION
