XENTRY Passthru and XDOS Installation Secrets Revealed for Dummies 2018
- Download this document, you need 5 Gallons
here is how to install xentry passthru and xdos for dummies 2018.
it is simple but it is worth thousands dollar. Biggrin
1. prepare windows sp1 x86 or x64
2. run setup.exe
notes for xdos installation in win x86 32bit
Extract xdos 2017-12 iso.
Replace Xentry Diagnostics OpenShell.msi in folder 'data'
Download: Xentry Diagnostics OpenShell
3. copy xentry missing pictures
x86 32bit
c:\program files\mercedes-benz\
x64 64bit
c:\program files (x86)\mercedes-benz\
Download: Xentry missing pictures.rar
4. install block check keys to daimler server
purpose: to avoid "no access authorization code" after using internet
x86 32bit
c:\program files\mercedes-benz\AppServ
x64 64bit
c:\program files (x86)\mercedes-benz\AppServ
Download: appserv.rar
5. install old keys loader for configassist (or startkeycenter if you use it)
purpose: to make configassit or startkeycenter accept keys from old xentry/das developer keygen ( it is called 'old keys'). Select according to your win OS.
x86 32bit
c:\windows\system32
x64 64bit
c:\windows\SysWOW64
Download Old key loader for configassist or startkeycenter.rar
6. install 2221-45 error fix
purpose: fix xentry error 2221-45.
x86 32bit
c:\program files\mercedes-benz\xentry\fusuko\eclipse\plugins
x64 64bit
c:\program files (x86)\mercedes-benz\xentry\fusuko\eclipse\plugins
Download 2221-45 Fix for Xentry Passthru or OpenShell 2017.12.rar
7. install 3.91 error fix
purpose: fix xentry error 3.91
x86 32bit
c:\program files\mercedes-benz\xentry\Kontexte\Allgemeine_Ablaeufe\Public_Functions
x64 64bit
c:\program files (x86)\mercedes-benz\xentry\Kontexte\Allgemeine_Ablaeufe\Public_Functions
First Method: decrypt "db2mv.gmf", edit and encrypt it again
other Method: just delete "db2mv.gmf"
8. install das license 0 day fix
purpose: fix DAS license 0 day error (not for MB Bus). you can use this along with DAS Standalone full size.
x86 32bit
c:\program files\mercedes-benz\DAS\bin
x64 64bit
c:\program files (x86)\mercedes-benz\DAS\bin
- maximum 5 attachment per thread limitation. Lipssealed 1087
9a. install passthru device driver for xentry passthru
9b. xentry and das blacklist
2. run setup.exe
x86 32bit
x64 64bit
x86 32bit
x64 64bit
x86 32bit
c:\windows\system32
x64 64bit
c:\windows\SysWOW64
x86 32bit
x64 64bit
x86 32bit
x64 64bit
x86 32bit
x64 64bit
- Mercedes Benz WIS/EPC Net Keygen
- Mercedes-Benz STAR Finder 2016 Full
- Mercedes-Benz WIS-ASRA NET [11.2018] FULL + Instruction
- Mercedes-Benz WIS-ASRA NET [03.2017] FULL + Instruction
- Mercedes-Benz EPC [11.2018] Full
- Mercedes-Benz WIS-ASRA NET [01.2016] Full + Instruction
- Mercedes-Benz EPC [04.2017] Full + Instruction + KG
- Mercedes Password Calculator + FDOK
- MERCEDES EPC AND WIS KG FOR ALL VERSION
- Mercedes-Benz WIS-ASRA NET [10.2020] Full DVD
- Mercedes-Benz EPC [09.2018] Full
- Mercedes ECU Editor V1.67 HD Key
- Mercedes-Benz WIS-ASRA NET [09/2018] FULL
- Mercedes-Benz WIS-ASRA NET 04.2017
- Mercedes-Benz EPC [04.2018] Full + Instruction + KG
