White Tractor Row Crop_Wheatland_Rice Special G1000 Parts Catalog R2112B00
Brand: White
Type of Machine: Tractor Row Crop, Wheatland, Rice
Model:
White Special G1000 Tractor Row Crop
White Special G1000 Wheatland
White Special G1000 Rice
Part Number: R2112B00
Number of Pages: 177 Pages
Crankcase (For 504a-6 Gas And Lp Gas Engine)
Crankcase (For D504a-6 Diesel Engine)
Gear Case And Water Pump
Base Pan, Oil Filter And Oil Pump
Cylinder Block, Cylinder Head, And Breather
Cylinder Block, Cylinder Head, Energy Cells And Breather
Camshaft, Rocker Arms, Valves, Push Rods, And Tappets
Crankshaft, Connecting Rod, Pistons, Rings, And Flywheel
Crankshaft, Connecting Rod, Pistons, Rings And Flywheel
Gas Manifold And Muffler
Air Cleaner
Gasoline Carburetor
Carburetor And Regulator (Lp-Gas)
Fuel Tank, Valves And Supports For Lp-Gas Tractors
Roosa-Master Fuel Injection Pump
Fuel Filter For Diesel Tractor
Gasoline And Diesel Fuel Tank And Supports
Electric Gasoline Fuel Pump And Filter
Governor And Control Rod - Group 1
Governor And Control - Group 2
Governor And Control Rod - Gasoline - Group 3
Throttle Controls (Ratchet Type)
Distributor, Ignition Coil, Cables And Spark Plugs
Hood And Grille - Group 1
Hood And Grille - Group 2
Fan And Hub
Water Manifolds And Thermostat
Instrument Panel And Instruments - Group 1
Instrument Panel And Instruments - Group 2
Alternator, Starting Motor And Battery Boxes
Lamps And Wires
Clutch And Clutch Shifting
Upper Sliding Gear Shaft, Pinion And Reverse Gears
1.905 Ratio Ampli-Torc Drive - Group 1
1.905 Ratio Ampli-Torc Drive - Group 2
1.46 Ratio Ampli-Torc Drive (14r326) - Group 3
Transmission Case
Gear Shifting
Rear Axle And Bull Gear
Brakes
Rear Power Take-Off
Lube Pump - Rear - Group 1
Lube Pump - Rear - Group 2
Transmission Lube Cooler
Steering Gear Housing
Power Steering Pump
Steering Motor
Steering Motor And Lines
Front Axle And Wheels For Type E Tractors
Type U Front Axle And Wheels
Standard Front Axle (Wheatland)
Wheel Guard And Platform (Row Crop Tractors)
Wheel Guards And Dust Shields (Wheatland Tractors)
Platform (Wheatland Tractors)
Hydraulic And Oil Strainer Lines - Group 1
Hydraulic And Oil Strainer Lines - Group 2
Reservoir For Tractors With Tel-O-Flo Hydraulic System
Cylinder And Linkage
Hand Controls And Linkage
Valve Asy. For Tractors With Tel-O-Flo Hydraulic System
Depth Limit Control
3 Point Hitch For Tractors With Tel-O-Flo Hydraulic System
Hydraulic Oil Lines - Type F Hydraulic System
Type F Hydraulic System - Single Control Valve
Type F Hydraulic System - Dual Control Valve
Main Control Valve
Remote Mounted Jack And Depth Stop
Tool Box And Tools (Not Illustrated)
20 Deg. Swinging Drawbar For 3- Point Hitch
Semi-Mounted Plow Hitch (Quick Coupler)
Decals And Ornaments (Not Illus.)
Brand: White
Model:
Air Cleaner
Gasoline Carburetor
Fan And Hub
Lamps And Wires
Transmission Case
Gear Shifting
Brakes
Rear Power Take-Off
Power Steering Pump
Steering Motor
Depth Limit Control
Main Control Valve
