704,032
White Tractor JET STAR 4-STAR 4-STAR Super Parts Catalog R2013A00
Brand: White
Model:
White JET STAR Tractor
White 4-STAR Tractor
White 4-STAR Super Tractor
Part Number: R2013A00
Number of Pages: 160 Pages
Crankcase - Group 1 - For 206l - 4 Engine
Crankcase - Group 2 - For D206-4 (Diesel) Engine
Cylinder Block, Cylinder Head, And Breather - Group 1
Cylinder Block, Cylinder Head, And Breather - Group 2
Camshaft, Rocker Arms, Valves, Push Rods And Tappets
Crankshaft, Connecting Rods, Pistons, Rings And Flywheel
Gas Manifold, Air Cleaner And Muffler
Carburetor (Gasoline)
Carburetor (Lp Gas)
Governor And Controls - Governor And Controls See Supplement D Page 105 For The Jet Star 2 Tractors.
Fuel Tank And Strainer (For Gasoline Or Diesel)
Fuel Tank And Filter (Lp Gas)
Fuel Filter And Fuel Lines For Diesel Tractors
Fuel Injection Pump, Nozzles, Holders And Tubes
Grille And Service Panel 4-Star And 4-Star Super
Grille And Service Panels Jet Star
Distributor, Coil And Spark Plugs
Water Pump And Fan
Oil Pump And Oil Filter - Oil Pump And Oil Filter See Supplement D Page 105 For The Jet Star 2 Tractors.
Generator, Starting Motor And Battery Supports
Lamps And Wires - Lamps And Wires See Supplement B Page 104 For The Jet Star, 4 Star And 4 Star Super Tractors.
Decals And Emblems
Instrument Panel (Jet Star)
Instrument Panel And Instruments
Clutch, Clutch Shaft And Clutch Pedal
Upper Sliding Gear Shaft, Pinion, Gears And Reverse Gears
Ampli-Torc Drive
Transmission Case - Transmission Case See Supplement B Page 104 For The Jet Star, 4 Star And 4 Star Super Tractors.
Gear Shifting
Differential Case - Differential Case See Supplement B Page 104 For The Jet Star, 4 Star And 4 Star Super Tractors.
Rear Wheels (For 4-Star Or 4-Star Super)
Brakes - Brakes See Supplement D Page 105 For The Jet Star 2 Tractors.
Belt Pulley
Rear Power Take-Off - Rear Power Take-Off See Supplement B Page 104 For The Jet Star, 4 Star And 4 Star Super Tractors.
Front Power Take-Off
Radiator And Thermostat - Radiator And Thermostat See Supplement D Page 105 For The Jet Star 2 Tractors.
Steering Gear Housing And Controls
Steering Wheel And Linkage
Supplement B - Steering Wheel And Shafts (Not Illus.)
Steering Wheel And Shafts (4-Star And 4-Star Super)
Front Axle And Front Wheels (For Jet Star Tractor)
Type E Front Axle And Wheels (For 4-Star Or 4-Star Super)
Supplement B - 5,000 Pound Front Axle And Wheels
Wheel Guard And Platform - Wheel Guard And Platform See Supplement D Page 105 For The Jet Star 2 Tractors.
Seat - Seat See Supplement B Page 104 For The Jet Star, 4 Star And 4 Star Super Tractors.
20 Deg. Swinging Drawbar For 3-Point Hitch
3-Point Hitch Stabilizer
Hydraulic Pump - Hydraulic Pump See Supplement B Page 104 And Page 86 For The Jet Star, 4 Star And 4 Star Super Tractors.
Supplement B - Hydraulic Pump
Control And Damper Valve
Supplement D - Control And Damper Valve - Jet Star 2
Reservoir - For Tractors With Type B Hydraulic System
Reservoir - For Tractors With Type C Hydraulic System
Cylinder And Linkage - For Tractors With Type B
Reservoir And Cylinder For Tractors With Type C
Supplement B - Reservoir And Cylinder For Tractors With Type
Supplement D - Type E Hydraulic System (Not Illustrated)
Supplement D - Roosa-Master Fuel Injection Pump
Supplement D - Fuel Filter (Diesel)
Valve Assembly And Filter
Supplement B - Valve Assembly And Filter
Supplement D - Mechanical Reverse Shuttle
Remote Mounted Jack And Depth Control Valve
Selective Lift
3-Point Hitch (4-Star Or 4-Star Super Tractor)
3-Point Hitch (For Jet Star Tractor)
Supplement B To Repair Catalog R-2013a
Supplement D To Repair Catalog R-2013a
