704,032
White Tractor G955 1870 Parts Catalog 43323000
Brand: White
Model:
White G955 Tractor
White 1870 Tractor
Part Number: 43323000
Number of Pages: 302 Pages
Emblem, Decal Sets And Name Plate (Not Illustrated)
Cylinder Block, Cylinder Head And Breather - 425c-6 Lp Gas
Cylinder Block, Cylinder Head And Breather - D451-6 Diesel
Camshaft, Rocker Arms, Valves, Push Rods And Tappets
Crankcase - 425c-6lp Gas
Crankcase - 451-6 Diesel
Crankshaft, Connecting Rods, Pistons, Rings And Flywheel
Gear Case And Water Pump
Base Pan, Oil Filter And Oil Pump
Oil Pressure Gauge
Gas Manifolds
Muffler
Manifold Preheater
Air Cleaner
Air Cleaner - 504b-6 Lp Gas
Precleaner Screener
Lp Gas Tank, Valves And Filter
Lp Gas Filter
Carburetor And Regulator - Lp Gas
Carburetor
Regulator
Distributor, Ignition Coil, Cables And Spark Plugs
Distributor
Governor And Control Rod - Lp Gas
Throttle Controls - Common (S N 239825 - 247283)
Throttle Controls - Common (S N 247284 -)
Throttle Controls - Lp Gas
Throttle Controls - Diesel
Main Fuel Tank - Diesel
Main Fuel Tank Lines And Filter - Diesel
Wheel Guard Fuel Tanks - Diesel
Fender Fuel Tanks - With Cab - Diesel
Wheel Guard And Fender Fuel Tank Line - Diesel
Fuel Injection Pump
Ignition And Starter
Starting Motor - Lp Gas
Starting Motor
Battery Box And Cables
Coolant Heater
Water Manifolds And Thermostat
Fan And Hub
Transmission Lube Pump
Transmission Pressure Lube System
Center Frame
Rear Main Frame
Gear Shift
Brake Controls (S N 239825 - 247283)
Brake Valve And Lines (S N 247284 -)
Brake Pedals And Linkage (S N 247284 -)
Brake Valve
Hand Brake
Brakes
Over Under Hydraul-Shift Cover, Filter And Pump
Over Under Hydraul-Shift Oil Pump
Over Under Oil Cooler
Power Take-Off
Power Take-Off - Clutch And Drive
Valve - Power Take-Off
Hydraulic Housing And Cover
Hydraulic Pump, Filter And Lines
Hydraulic Oil Filter
Unloading Valve
Pressure Valve
Hydraulic Hand Controls
Pressure Detent Valve
Servo Valve
Float Valve
Hydraulic Internal Draft Sensitivity - Category 2
Hydraulic External Draft Sensitivity - Category 3
Cylinder, Hoses And Connections
Depth Stop Cylinder - 4 Inch
Depth Stop Cylinder - 3-1 2 Inch
Lift Cylinder
Hydraulic Cooler (S N 239825 - 248125)
Hydraulic Oil Cooler And Lines
Pressure Lube, Hydraulic And Cooler Pump Drive (S N 248126-)
Pump - Hydraulic Oil Cooler (S N 239825 - 248125)
Front Wheels
Rear Wheel Weights
Rear Wheel Rims
Lights - Without Cab
Lights - With Cab
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Drawbar
Wide Drawbar
Three-Point Hitch - Category 2
6,000 Lb Lift Hitch - Category 3
Clutch And Drive
Clutch Pedal And Linkage (S N 239825 - 247283)
Clutch Pedal And Linkage (S N 247284 -)
Clutch Cover - 14 Inch
Rear Axle
Wheel Guard And Platforms
Platform (S N 247284 -)
Wheel Guard Panels
Step
Suspension
Roll Bar And Seat Belt
Front Frame Weights
Power Steering
Steering Column
Control Unit - 2wd
Power Steering Cylinder And Lines
Steering Shaft Housing
Steering Mechanism
Tie Rod
Front Axle
Hood, Side Panels And Grille
Instrument Panel (S N 239825 - 247283)
Instrument Panel (S N 247284 -)
Speedometer
Tachourmeter
Tool Box
Cab Rops
Cab Door And Windows - Rops
Cab Air Filter, Blower And Control Panel - Rops
Cab Roof And Miscellaneous - Rops
Cab Glass Specifications - Rops
Cab Air Conditioner - Rops
Air Conditioner Compressor And Drive Pulley
Cab Heater
