White Tractor G1355 2270 Parts Catalog 43322500
Brand: White
Model:
White G1355 Tractor
White 2270 Tractor
Part Number: 43322500
Number of Pages: 317 Pages
Emblem, Decal Sets And Name Plate (Not Illus.)
Cylinder Block, Cylinder Head And Breather - 504b-6 Lp Gas
Cylinder Block, Cylinder Head And Breather - D585-6 Diesel
Camshaft, Rocker Arms, Valves, Push Rods And Tappets -
Crankcase - 504b-6 Lp Gas
Crankcase - D585-6 Diesel
Crankcase, Connecting Rod, Pistons, Rings And Flywheel -
Gear Case And Water Pump
Base Pan And Oil Filter (S N 236440 - 249066)
Base Pan - D585-6 Diesel (S N 249067 -)
Oil Cooler (S N 236440 - 249066)
Oil Cooler And Filter - D585-6 Diesel (S N 249067 -)
Oil Pump - 504b-6 Lp Gas
Oil Pump - D585-6 Diesel (S N 236440 - 249066)
Oil Pump - D585-6 Diesel (S N 249067 -)
Oil Pressure Gauge
Gas Manifolds - 504b-6 Lp Gas
Manifolds - D585-6 Diesel
Muffler
Manifold Preheater - Diesel
Air Cleaner - 504b-6 Lp Gas
Precleaner - Aspirator - 504b-6 Lp Gas
Air Cleaner - D585-6 Diesel
Precleaner - Aspirator - D585-6 Diesel
Coolant Heater - Diesel
Lp Gas Tank, Valves And Filter
Lp Gas Filter
Carburetor And Regulator
Carburetor
Regulator
Distributor, Ignition Coil, Cables And Spark Plugs
Distributor
Governor And Control Rod
Throttle Controls - Common (S N 236440 - 247283)
Throttle Controls - Common (S N 247284 -)
Throttle Controls - Lp Gas
Throttle Controls - Diesel
Main Fuel Tank - Diesel
Main Fuel Tank Lines And Filter - Diesel
Wheel Guard Fuel Tanks - Diesel
Fender Fuel Tanks - With Cab - Diesel
Wheel Guard And Fender Fuel Tank Lines - Diesel
Fuel Injection Pump
Ignition And Starter
Starting Motor - Lp Gas
Starting Motor - Diesel
Starting Motor
Battery Box And Cables
Water Manifolds And Thermostat - 504b-6 Lp Gas
Water Manifolds And Thermostat - D585-6 Diesel
Fan And Hub
Transmission Lube Pump
Transmission Pressure Lube System
Center Frame
Rear Main Frame
Gear Shift
Brake Controls (S N 236440 - 247283)
Brake Valve And Lines (S N 247284 -)
Brake Pedals And Linkage (S N 247284 -)
Brake Valve
Hand Brake
Brakes
Over Under Hydraul-Shift Cover, Filter And Pump
Over Under Hydraul-Shift Lever And Linkage
Over Under Hydraul-Shift Oil Pump
Over Under Oil Cooler
Power Take-Off
Power Take-Off Clutch And Drive
Valve - Power Take-Off
Hydraulic Housing And Cover
Hydraulic Pump, Filter And Lines
Hydraulic Oil Filter
Unloading Valve
Pressure Valve
Pressure Detent Valve
Servo Valve
Float Valve
Hydraulic External Draft Sensitivity
Cylinder, Hoses And Connections
Depth Stop Cylinder - 4 Inch
Depth Stop Cylinder - 3-1 2 Inch
Lift Cylinder
Hydraulic Oil Cooler (S N 236440 - 248125)
Hydraulic Oil Cooler And Lines (S N 248126 -)
Pressure Lube, Hydraulic And Cooler Pump Drive (S N 248126-)
Pump - Hydraulic Oil Cooler (S N 236440 - 248125)
Rear Wheels And Rims
Dual Wheels
Front Wheels
Lights - Without Cab
Lights - With Cab
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Drawbar
Wide Drawbar
6000 Lb. Lift Hitch (Category 3)
Clutch And Drive
Clutch Pedal And Linkage (S N 236440 - 247283)
Clutch Pedal And Linkage (S N 247284 -)
Clutch Cover - 14
Rear Axle - Planetary Drive
Planetary Hub
Wheel Guards And Platforms
Platform (S N 247284 -)
Wheel Guard Panels
Step
Suspension
Roll Bar And Seat Belt
Front Frame Weights
Power Steering
Steering Column
Control Unit - 2wd
Power Steering Cylinder And Lines
Steering Shaft Housing
Steering Mechanism
Tie Rod
Front Axle
Hood, Side Panels And Grille
Instrument Panel (S N 236440 - 247283)
Instrument Panel (S N 247284 -)
Speedometer
Tachourmeter
Tool Box
Cab - Rops
Cab Door And Windows - Rops
Cab Air Filter, Blower And Control Panel - Rops
Cab Roof And Miscellaneous - Rops
Cab Glass Specifications - Rops
Cab Air Conditioner - Rops
Air Conditioner Compressor And Drive Pulley
Cab Heater
Brand: White
Model:
White G1355 Tractor
White 2270 Tractor
Oil Pressure Gauge
Muffler
Lp Gas Filter
Carburetor
Regulator
Distributor
Fuel Injection Pump
Starting Motor
Fan And Hub
Center Frame
Rear Main Frame
Gear Shift
Brake Valve
Hand Brake
Brakes
Power Take-Off
Unloading Valve
Pressure Valve
Servo Valve
Float Valve
Lift Cylinder
Dual Wheels
Front Wheels
Lights - With Cab
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Drawbar
Wide Drawbar
Clutch And Drive
Clutch Cover - 14
Planetary Hub
Wheel Guard Panels
Step
Suspension
Front Frame Weights
Power Steering
Steering Column
Control Unit - 2wd
Steering Mechanism
Tie Rod
Front Axle
Speedometer
Tachourmeter
Tool Box
Cab - Rops
Cab Heater
