James Rodrigues
Super Moderator
79
600,597
Volvo Techtool PTT 2.8.51 & APCI 05.2021 Diagnostic Program Software DVD
If you download this document, you will be lost 0 Gallons
Size: 15.2 GB (Winrar Files)
Type of software: Diagnostic Software
Brand: Volvo
Region: WorldWide
Version: PTT APP 2.8.51 07.2021 & APCI 05.2021
Interface-Languages: Slovak, Danish, Deutsch, English, Spanish, French, Italian, Dutch, Latvia, Lithuania, Hungary, Polish, Portuguese, Rumani, Russian, Egyptian, Turkish, Arabic, Finnish, Swedish, Tai, Korean, Japenese, Chinese
Os: Windows 7, Windows 8 Windows 10 32 & 64bit (Tested on window 10 pro-1607 64 bit)
Amount of disks: 1 DVD
Medicine: Present
Instruction: Present
Print Functions: Present
Installation: Multiple PCs
High-Speed Link Download
Communication Unit
- VOCOM I
- VOCOM II
Connection Mode:
- USB
- WLan
Unit:
- Metric
- U.S
Product: Tech Tool
Version: 2.8.51
User ID: XX78911
Database: Development
Last updated:
Last updated: APCI (-M) 06/04/2021 19:18:54
Last updated: APCI+ (-M) 24/05/2021 12:48:17
***Included Versions***
APCI (-A)
APCI (-M) 000.009.001.0
APCI+ (-A) 0.5.1.0
APCI+ (-M) 0.5.1.0
GX Application 2.8.40.1
GX Content 2.8.51.1
GX Content Texts 2.8.50.3
Tech Tool Branding 2.8.15.0
Tech Tool Core 2.8.51.0
Tech Tool Development Content 2.8.0.38
Tech Tool Help 2.8.0.43
Tech Tool Normal Content 2.8.0.37
VCADS Pro 2.8.0.38
VCADS Pro Development Content 2.8.50.1
VCADS Pro Normal Content 2.8.50.1
VCADS Pro Toolbox 2.8.0.38
Volvo Premium Tech Tool v2.8.51 is the OEM software. It's a part of the dealer diagnostic kit. Premium Tech Tool allows performing all the tests the dealerships can. Such as fault codes check, DPF regen, Injector Cut-out tests and much more. The PTT communicates with both Mack and Volvo Trucks.
The PTT software comes as a set of installation files/components. You can download the files from our server or we will send the product on DVDs via AirMail.
Note: Tech Tool does NOT support Windows XP and Windows Home Edition. The full Hardware requirements image is available in the product screenshots section.
Please take into account the connection to the central systems is not available.
Volvo VOCOM II 88894000 and VOCOM are the recommended devices.
Both Adapters are work with Windows 7, 8.1, and 10 (pro) versions. Moreover, all vehicle electrical systems and vehicle production dates are covered.
The latest version of the Nexiq USB Link adapters is also compatible with the PTT 2.8.60 but with some limitations - no high-speed programming for electrical system v2,3.
The same information is absolutely valid for Mack trucks.
With this tool, you can diagnose, test, calibrate and program - in one word - reliable and high-quality service of your truck. The program also provides features for updating the tool, communication with the product and other external applications. A set of plug-ins, user authorization, and languages are configured to provide each user with what they need.
To work with the diagnostic tool, users need to install software ECU, and then with this tool, you can make it usable for any dealer ID and customer ID. The basic workflow in this tool is the same for all products: identify a product, to history information, diagnose a selected product, a select product, program a selected item and calibrate a selected product.
Electrical systems and compatible brands:
- Volvo Trucks (the older system, the vehicle \ 98, Version parameter programming)
- Volvo Truck (Version 4-FH4/FM4)
- Volvo buses (conventional multiplexed v2 ... v3)
- Volvo construction equipment (v2 .. v3)
- Volvo Penta (v2 ... v3)
- Volvo OEM client component (v2 ... v3)
- Trucks MAC (v-MAC I\ II\ III, ITC, IV)
- Renault Trucks (v2 v3 v4)
- UD Trucks (v2 v3)
Support
Administrator
67
393,196
#8
does parameter programming work on this version or is it like the other 2.8 tech tools floating around?
Dear friend, it's working fine, many users downloaded & used it normally, please read clearly content, functions of this program on this post, regards!
